Question about Freezers
Freezer switces off sporadically after periods of 20 to 10 days.
Bauknecht GKEA 305 OPTIMA
After 3 years use from new the freezer switched off and unfroze during our absence. There had been no interruption of the mains supply and the dot of light on the control panel showed that the freezer was still connected. It restarted and ran for 9 days then the indicator panel showed a flashing series of 3 lines like - - one above the other interspersed with a rapid indication of the set temperature with a 1 second cycle and loud click. The freezer was disconnected and allowed to warm to -12°C and then reconnected and started and is now behaving normally again and has reached the set temperature. It responds normally to changes in the set temperature..
  • 828 Answers
If this is a frost free refrigerator have the defrost timing unit checked out. It may well be sticking in the defrost position.
Posted on Nov 29, 2008
Freezer runs for approx. four days with operation normal. Then the temp. panel of front door displays a symbol that looks like a short L followed by a period. Then the temp. gauge and the interior light...
From what I read, the "L." that you see on the control panel indicated that the controls have been locked. According to the manual if you hold down the "alarm reset" button for 3 seconds the "L." will disappear allowing you to control the temperature again. I don't as of yet know what is causing your overall problem though...
Nov 04, 2013 | GE FUF14SVRWW Upright Freezer
I have a Bauknecht Fridge freezer with icemaker (type E25SSA) and the icemaker has stopped working. Is there a registered Bauknecht repair agent who can call out to Northwich. The repair is covered under...
dear sir i have the model ksn6500 and when we oen the door we hear something thinking like something want to start,the fridge is working properly but the noise is continous
Jan 17, 2011 | Freezers
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    I recently bought a norfrost chest freezer model c6aew,the freezer did not come with a manual or guide.i switched on the freezer set the dial to seven waited 24hrs and put some food into the freezer to...
    Can't help I'm afraid, but we have exactly the same problem with exactly the same model. Ours did work for nearly 2 years, but recently only works with the boost button pressed in. I suspect the thermostat is not working as the boost button over-rides the thermostat to give max cooling. Your freezer is new so get it exchanged; it certainly doesn't need to be full to work!
    May 29, 2010 | Freezers
    Upright Frigidaire Freezer, Model#: MFU14F3GW9 It's approximately a 7-9 year old upright freezer. I believe the door may have been left cracked for an extended period of time, but I'm not positive....
    if the doors shut okay,and there is no frost,and it is maintaining a steady internal temp(-18C to -20C) why worry.......anything else is going to cost money.......
    Apr 05, 2010 | Freezers
    Excessive fosting in the freezer compartment
    may have a bad drain line heater or a bad defrost heater, thermostat, or timer.
    Oct 09, 2009 | Freezers
    MCCF7W Runs, but won't freeze....
    Sounds like the refrigeratnt has leaked out. It is not worth repairing. The only other possibility is the cold control but I would not buy one until a servicer has looked at it.
    Sep 05, 2009 | Magic Chef Chest Freezer MCCF5WBX
    New freezer. 15 days old. mildew smell in the
    There is a curing process for the foam used to insulate these. It can give off a pungent odor until it is fully cured. Only experienced it a couple times in the last 20 years. eric
    Jul 08, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
    Freezers Logo
    111 people viewed this question
    Top Freezers Experts
    Dennis Boxerman
    Charles T Nevin
    Charles T Nevin
    AJMAL KHAN
    Are you a Freezer Expert? Answer questions, earn points and help others
