Question about Nu Mark Numark Cdx Table Top CD Player CD Player
Can't change the pitch on the CDX ! Freezed on +/-12%
My pitch is on +/-12% and the pitch button doesn't respone. Impossible to switch to +/-25 or +/-50. Updates, Calibration and reset didn't change anything. Do i have to open the machine??? No pleasse...
No! Yes have broken the Pitch Button On it cause if it doesn't move That your problem
Posted on Jul 10, 2007
SOURCE:
Rear ac dometic doesn't responed
check dip switches and communication cable and temp sensor
Mar 07, 2013 | Dometic Rooftop RV Air Conditioner
Pitch control doesn't work
Make sure that the "Pitch" button is turned on (LED is lit) before trying to change the pitch. If it is, make sure that it's not disabled in the settings.
May 18, 2012 | Numark CD MIX 1 Integrated Dual CD Player...
Where does the remote wire for amp go to on sony xplod cdx gt520
their should be a blue white wire on the back of the radio. this wire is called the amp turn on wire connecting to this wire will provided 12 volts when the xplod cdx gt520 is turned on but if you press the off button on the radio the 12 volts will drop to 0 volts but when the radio is turned on the 12 volts will come back.
Aug 01, 2011 | Sony CDX-GT520 FM / AM Receiver
How do you change the pitch to 10 pitch
On the L. side of the keyboard is either a slide switch or a button to push to change the pitch, 15, 12, 10 or PS.
DickyO
Aug 24, 2010 | Brother ML-500 Typewriter
When I turn off my truck and the blue lights on, it turns off but when the radios on and I turn the truck off the radio does turn off unless I hit the off button! Help sony xplod cdx-gt640
do you mean the blue light on the power button? it sounds like your radio's switched power input (usually red) is hooked up to a 12 volt constant source.
Feb 22, 2010 | Sony XPlod CD Player w/MP3 Playback...
Cd changer problem
Refer to the CD changer manual & check this code or find the reset button otherwise take it to the workshop.
Sep 20, 2009 | Pioneer CDX-FM1287 12-Disc CD Changer
Just a question...can the font size be changed?
Yes for one, smaller pitch such as a 12 pitch such as Prestige Elite or Coutier 12. You can also get a 15 pitch wheel if your machine has that feature. Ther is button the keyboard that lets you choose between 10 (Pica) 12 (Elite) or 15 Pitch. Good Luck
Jun 12, 2008 | Brother GX-6750 Typewriter
Change Size of Type (Pitch to 12)
The pitch is set by the ptintwheel. To change it install a P/W with a 12 pitch i.e. prestiege elite 12.
DickyO
May 20, 2008 | Lexmark Wheelwriter 1000 Typewriter
Pitch control center moved
Hello, Mr. Dixon.
I had the same problem and i decided it whit this procedure:
1. Restoring Factory Default Settings
2. Set the PITCH Slider to the center ( 0 ) position.
3. With the CDX-05 in the start mode displaying “no Disk” hold down EJECT and TIME/ENTER and press FILTER. The TEMP display in the LCD reads 0.0 and the procedure is complete.
Peter Petrov
Dec 08, 2007 | Vestax CDX-05 Turntable
Nu Mark Numark Cdx Table Top CD Player CD Player Logo
237 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Marvin
Marvin
Morne Olivier
 Ian Kayhan
Ian Kayhan
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
