Question about Acer AL1715s (Silver) 17" LCD Monitor
Trailing of discolouration when mouse moved
I hooked up a new LCD to my old PIII PC and got a trailing of discoloured pixels whenever I move my mouse. It will only clear when a new window is opened over it. Could it be power supple problem?
Got it working by adjusting the hardware acceleration.
Posted on Dec 07, 2008
Tv picture trailing
it may be your antenna system or the way you have pluged it in check the plugs in the back
Jan 12, 2014 | Televison & Video
Hi Guys, I have a SHARP LC37AD5EBK LCD TV. The problem is the picture is pixelated and discoloured (Orange Mostly), if you pull up a menu from the sat box or TV itself the picture is fine. It seems to only...
If you are using a five wire, component connecting cable rather than an HDMI cable, check all of your connections from the satellite receiver to the TV. You could be missing the blue connection from either end. If you are not using this type of cable then I'm scratching my head.
Could you submit a picture ?
Oct 12, 2017 | Sharp LC32AD5EBK 32 in. LCD TV
Samsung LN52B750 LCD TV image smear/trailing
It transfer the universal image signal of TTL and LVDS signal to specific TFT LCD.
No offense, but it is a very complex subject.
Unless you're an EE.
Apr 09, 2010 | Samsung LN52B750 52 in. LCD TV
1985 ignition timin on mazda rx7 13b
There are 2, the leading you turn the dist to line up the mark, then the trailing you move the trailing vac advance to line up the mark (about 10mm after the first mark. It usually never needs to be adjusted unless someone has messed with it. Its hard to describe without a diagram.
Mar 12, 2010 | 1985 Mazda RX-7
There seems to be waves on my desktop screen whenever I move my mouse. I can see the waves more clear when the background is darker.
The 'waves' might be your pointer trails: it can be disabled by going to your 'Mouse Properties' under the category of 'Visibility' , untick 'Display pointer trails'.
Hope it helps!
Dec 30, 2009 | Computers & Internet
KDL 40V2500 two Dark horizontal bands on lower third of monitor
pixel thin are almost always the lcd panel. you could try opening the tv an reseating (un hook and rehook) the cables that go to the screen. there is a board at the top of the back of lcd panel that drives the video. it has connections in and out that i would reseat. if this doesn't resolve, that board could be bad but unlikely. most likely needs a new panel, sorry for the news. :(
Dec 08, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Screen
Two possibilities can cause the issue .
1. A lose hinge assembly
2. A faulty LCD cable.or the LCD lamp
Try following the instructions given in the following wizard
http://tinyurl.com/6ojva6
In case your system is out of warranty and you need help opening parts , refer to the following
http://tinyurl.com/5w9nsv
Apr 09, 2008 | Computers & Internet
CANON PIXMA MP 460: PRINTING PHOTO- COLOUR PROBLEM.
change the print cartridge for color if yhat doesn't fix it get a new print head. Bob
Mar 28, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Text on screen trailing to the right
Check the VGA plug and lead between the monitor and computer.
Does it get worse or better while you move the lead around?
Oct 20, 2007 | Philips 170S7FS 17" LCD Monitor
CRT discoloured
If it's a deguass problem, you can glue some very small magnets to the sides of the crt tube itself, it could be the shadow mask, inside the monitor, and if it is then nothing will fix it, if you can get a deguass coil from somewhere that would tell the story real quickly
Nov 04, 2006 | LaCie Electron 22blue II 22" CRT Monitor
Acer AL1715s (Silver) 17" LCD Monitor Logo
87 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
