Question about Toshiba Tecra 8000 Notebook
Inspiron 1521 green screen problem
I first noticed the problem with i accidently bumped the screen passing by it and everything on the screen with the color black turned to this neon green color. If i flipped the screen down and up a few times it eventually went back to normal. Now every once in a while it does it on its own and i dont know how to fix it, and moving the screen down doesn't work. the same problem above
green instead of black
  • lamoush Nov 26, 2008
    thank u
    President:
  • Toshiba Master
  • 1,314 Answers
Either the lcd cable is loose on the inverter board, the lcd cable is going bad, or the inverter is going bad. Usually this can be fixed by removing the power button bezel and making sure all the cables are seated properly on their connection. Removing the power button bezel varies from laptop to laptop, sometimes there are screws on the bottom of the laptop that you need to remove and sometimes there are not, it just snaps into place.
Thanks and please take a moment to rate as fixya.
Posted on Nov 25, 2008
Have a black screen on dell 1521
try taking the battery out, pull out the power cord, and push and hold down the power button for 10-15 seconds. Then put everything back and try to start normally. If the problem still continues, try turning it off and pulling the memory out of the laptop and then reseat it...sometimes this may cause the problem but without any sorts of beeping or display occurring, it's very hard to help you on this one. I'm wishing you the best though. :-)
Feb 26, 2014 | Dell Inspiron 1521 Notebook
I think faulty motherboard for Inspiron 1521
try to change your ram maybe it will work
Oct 20, 2011 | Dell Inspiron 1521 Notebook
Want to restore dell inspiron 1521 to orginal settings how to
Firstly make sure you back up all your documents - music, photo's etc as restoring it will delete everything
Then as you turn the laptop on press F2 (usually) when it says to in bottom right hand corner and follow instructions from there. Hope this helps :)
Dec 28, 2010 | Dell Inspiron 1521 Notebook
Replace screen in my Inspiron 1521 lap top
Hello
You can get gelp from this youtube video
http://www.youtube.com/watch?v=56e3fSk_XdM&feature=related
Good luck and do rate the solution if got help
Dec 25, 2010 | Dell Inspiron 1521 Laptop
My laptop is saying that it cant find the internal disk hard drive and that i would have to reseat it?i have a Dell Inspiron 1521..where do I find the internal hard disk drive on my laptop?
Internal disk drive..will be drive c:\...make sure nothing is loose on your laptop. if not. Go to control panel. Click ADD HARDWARE....and see if everything is enabled
Jan 31, 2010 | Dell Inspiron 1521 Laptop
My dell inspiron 1521 screen goes black!
Yes, most likely the inverter has failed if you can still make out the desktop but the screen is very dim. Below is the link to the service and repair manual for that model.
http://support.ap.dell.com/support/edocs/systems/ins1521/en/sm/index.htm
Jan 23, 2010 | Dell Inspiron 1521-JB Notebook
The monitor on my Dell Inspiron 1521 has lots of colored lines on it. Can this be fixed?
Generally and indication of a Failing LCD.
Press D plus the Power button to initiate the LCD test, if the lines still appear, the LCD is bad and need replacement. If the LCD passes the test without the lines, the video card is the issue and will mean a motherboard replacement
Dec 31, 2009 | Dell Inspiron 1521 Laptop
LCD Screen Repalcement
thats the screen problem u should change the screen than it gonna be alright,
Oct 10, 2009 | Dell Inspiron 1521 Laptop
Windows Error Recovery
Try booting with the disk that came with the computer and start over with a fresh install of windows
Dec 30, 2008 | Dell Inspiron 1521 Notebook
The LCD cable or the cable to the Inverter board may have come loose.
Here is a site that will show you in pictures what the LCD cable connections look like. The site also has Laptop repair hints:
http://www.laptoprepair101.com/laptop/category/lcd-screen-repair/
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 22, 2008 | Computers & Internet
Toshiba Tecra 8000 Notebook Logo
160 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
