Question about Canon Cameras
I have just bought a cannon 40D THE SCREEN COMES UP WITH THIS MESSAGE:CAMERAS INTERNAL TEMP IS BECOMING TO HIGH CANNOT SHOOT. i HAVE NOT USED THE CAMERA MUCH JUST LOOKED AROUND THE MENU FEATURE ETC AND TRIED TO TAKE A PHOTO IT IS THE FIRST TIME USING THIS CAMERA. i AM USING A SCANDISK 111 4 gb. i HAVE FORMATED, THERE IS NOTHING ON THE DISK ANYWAY. TAKEN THE BATTERY OUT AND REINSERTED. ??????????????
    Problem Solver:
  • 26 Answers
It appears you have a defective camera body, warranty should cover it. Go to canonusa.com and contact their service dept.
Hope this helps out. Happy Thanksgiving!
Gom
Posted on Nov 26, 2008
Charge light solid red
If you put a cool battery in a camera and the camera says it is too hot. you have a critical problem with either the battery or camera.
Sep 30, 2017 | Nikon Coolpix S6100 Digital Camera
Pictures taken are not sharp
If you are upgrading from a previous "point and shoot" digital camera, the pictures from your digital SLR may seem "soft" by comparison. This is simply a difference in the built-in processing performed by the camera. Most DSLRs output images with less sharpening applied. I believe the philosophy is that the sharpening algorithm causes data loss, so less of it is used on the high-end cameras with the assumption that you can apply more later on your PC.
You can try shooting a picture using the RAW capture mode, then editing it using a program on your PC. By applying sharpening to the RAW image, you will most likely be able to produce a very sharp image.
You can also take a JPEG image with the camera and apply additional sharpening on the PC, but this process is more lossy with regards to the original data.
May 20, 2009 | Canon EOS 40D Digital SLR Camera Digital...
Cannon 40d error99
Sorry but, i think it's probably toast.
Feb 15, 2009 | Canon EOS 40D Digital Camera
Cannon lenses
All canon EF lenses (and compatibles e.g. Sigma EX) can be used with both analog and digital  EOS-bodies. Depending on the sensor size (usually smaller than a 35 mm negative) a crop-factor due to the smaller field of view must be considered.  Example: Canon EF 50mm/1.8 lens used on a digital EOS (40D, crop factor 1.6) equals a 80mm lens (50mm x 1.6) compared to analog cameras using 35mm film. Some digital EOS-models can also use EF-S lens-series.
Nov 28, 2008 | Canon EOS 40D Digital Camera
Internal Temperature too high to shoot.
This is obviously a problem with the internal parts of the camera. There are too many things it could be to give a definitive answer, and it would be too complicated for an amateur. If you take it into a local camera shop they should be able to run diagnostics on it and replace the problem.
Best of luck to you.
Nov 07, 2008 | Canon EOS 40D Digital Camera
Canon 40D i do not know how to turn on my lcd screen so i can see through it while shooting my image, is it possible?
Prepare to Live view shooting:
1. Set the lens focus mode (on the side of the lens) switch to <MF>
2. Set the shooting mode to a Creative Zone mode
3. In menu under the settings tab, select Live View function settings and then press <SET>
4. Turn with quick control dial to select Live View shoot and press <SET>
5. Turn with the control dial to select Enable and press <SET>
With the camera ready to shoot, press <SET> - image will appear on the screen in real-time
I hope this answered your question
May 30, 2008 | Canon EOS 40D Digital Camera
CANON EOS 40D
check this site for specs. I believe that the Canon 40d will.
http://dpreview.com/
May 28, 2008 | Canon EOS 40D Digital Camera
Cameras Logo
24 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
