Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Error code is E000003-0000
I am a beginner. pl solve my problen with easy understandable solution.
  • thilagavathy Dec 11, 2008
    i got my problem solved. thank u.
  • 168 Answers
Thats a fuser error do this in this order additinol function key then the 2 and the 8 key and the same time then additional func key again screen should change to service mode then touch in this order copier function clear err ok turn off with main switch turm back on if it doesnt clear you have a bad fuser
Posted on Dec 08, 2008
Which online Poker sites are good for beginners?
If you are a beginner and want to play poker online, then firstly you should know all the aspect of poker. Then I would suggest you choose a site that has no advanced features, so that you can better understand all the rules and regulation to play poker online.
This site has a very good response. It is fast and secure as compared to another poker site. Its user interface is simpler and attractive.
Oct 11, 2017 | Furniture
Should a beginner use RubyMine for Ruby on Rails development?
We work on Ruby on Rails professionally for many years and loved.
Ruby on Rails knows, really well
For beginners, then main advantages are that it:
  • reports syntax errors (better than any other tool I've used)
  • color codes local variables separately from method calls
  • jumps to source code very accurately (CMD+ Click on mac)
  • highlights common code style issues
  • has amazing rename variable / method tools that differentiate between method calls and local variables, understand Ruby scope etc...
  • shows you your gems right along with your source code, in case you want to see what's happening under the hood
allows you to run ruby files from within Ruby on Rails, minimizing windows / tabbing around different apps
For more details, visit us:http://www.rubyonrail.net
Ruby on Rails development company in USA Hire Ruby on Rails Developer
Feb 13, 2017 | Ruby Computers & Internet
How to Use Notepad++?
Notepad++ Is A Beginner Friendly Code Editor When you start learning to program you will need somewhere to write your code. If you want to get all of the bells and whistles from the very start then you might like to look at popular 'Integrated Development Environment' (IDE) software such as Eclipse. But IDEs can take time to learn, and if you are just starting out as a programmer then you have enough to learn already without having to navigate your way around a complex new piece of software before you can even begin. Also, large IDEs like Eclipse can sometimes use a lot of computing power to run, so if you don't have a high spec machine to run it on then you may experience some performance issues.
If you want a beginner friendly way to start programming, which is easy to pick up and will have all of the features that a beginner needs, then a simpler 'code editor' may be just the thing for you. A good quality code editor like Notepad++, which is the most popular product for Windows and is my own preferred software, comes with a wide range of useful features and can be extended using plugins.
How To Install Notepad++ Installing your code editor shouldn't be any harder than installing any piece of software! Software products aimed at developers often have many different versions available to download, without any easily accessible information about how to choose which version to use. This is fine for seasoned developers who know exactly what they want and understand all the technical terms, but when you are just starting out it can be a headache.
You can visit this link also for more knowledge
Beginners Guide to Notepad
Oct 19, 2016 | Computers & Internet
Error display hc551 for Ricoh Aficio MP1600le, pl help me how it solve the problem.
Error code: 551 - Fusing thermistor open (rear)
The fusing temperature detected by the thermistor is below 71C and is not corrected after the main power switch is turned on.
Causes:
- Fusing thermistor defective or out of position
- Power supply board defective
- Loose connectors
Apr 29, 2015 | Ricoh Office Equipment & Supplies
Error code 51099 comes up on the console on the Ds
hi,
Error code 51099 is one common problem but is repairable. All you need is a good Nintendo Repair Guide that would help you solve your problem within no time. This fix manual is very easy to understand and saves you cost and time. It comes in CHEAPER prices and is highly useful. I hope it would solve your problem. Take care and good luck :)
Aug 04, 2011 | Nintendo Video Game Consoles & Games
Error code 5400
You must be using Canon printer.
It is called e5 error which cannont be solved currently.
If you used refilled cartridge especially color one, it is not readabel from printer.
In this case, well the only solution would be replace your cartridge with new one.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 19, 2011 | Office Equipment & Supplies
How to setup visual basic 6.0
  1. One of the first and best things to do is begin to understand the Visual Basic IDE (Integrated Development Environment). By understanding the IDE you will be able to develop VB programs quickly and effectively. Start by reading the Getting to know the VB6 IDE tutorial
  2. The classic first program in any language is the Hello World tutorial. As a beginner you should make sure you write this program to get your feet wet. Check out the Simple Hello World VB6 tutorial
  3. Good programmers figure out how to use a consistent naming scheme when they develop applications. The quickest way to graduate out of the beginner VB6 level is to check out the Object Types and Naming Scheme VB tutorial
  4. Variables are used in any real development. Make sure you visit the Quick Variable tutorial to see how variables work in Visual Basic 6
  5. (Optional) More In Depth Understanding variables and types in VB6
  6. When you need to make comparisons or have your program choose between options you will need to understand Visual Basic's if statements. Luckily there's a beginners tutorial that explains just that: Understanding the if conditional statement
  7. Once you grasp the basics check out this next beginner VB6 tutorial that goes more in depth into conditional statements: Understanding if statements and conditionals in VB6
  8. Need to do something repeatedly? Need to iterate through a list of things? Need to count from 1 to 1 Billion by 3's? You need to understand loops! Understanding For, Do, and while Loops
  9. Once a beginner understands how to use functions and subroutines he or she is on the road to being a full fledged VB6 guru. A solid grasp on functions and subroutines allows you to reuse code and functionality throughout your program and in future programs.Functions and Subroutines in VB6 tutorial
  10. Last but not least, begin to learn how to use all the great controls Visual Basic offers and create a great User Interface for your clients to use. Basic Graphical User Interfaces in VB6 - Tutorial
Once you have finished these tutorials you should have a very good understanding of the fundamentals of the Visual Basic 6 language and development environment. Feel free to download some more advanced tutorials and continue learning on your own. If you have any questions or comments related to this Visual Basic 6 guide please post them below.
Jan 27, 2010 | Microsoft Visual Basic 6.0 for PC
Finding the reason and solving the problem
You must be informed and know want you want... so get some brochures, error code details,...
Nov 28, 2008 | Canon MF8180C Color Laser MFC Printer
Error 16
Dear Rashid,
I understand that this errors occurs in POST mode. You can always refer to service manual or troubleshooting guide of your machine upon purchase especially it displays error code. However not all error codes are not servicable for ordinary users due to risk. To give you an idea in solving the problem; present this error code to authorized service center and offer them to purchase the defective parts regarding this error, or you can troubleshoot by detaching or removing running parts one at a time. We'll see if the error changes. Contact me if there are progress, I can help you pin-point the problem somehow I can resell parts soonest with this type of printers.
Best regards,
Rosener Guyano
Jan 27, 2008 | Epson DFX-9000 Matrix Printer
Format error in mp3 player
You posted an iPod question in the PSP section. I recommend posting your question in the iPod section of the site.
Also, please re-word your question to be more clear. It's hard to understand what your exact problem is from the description.
Dec 10, 2007 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
451 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
