I purchased an All In One remote control and Im trying to find out what the device code is for a Vue eye LCD TV/DVD - model is a Vue 26HDDVD.
Many thanks
SOURCE: Vizio VW32L HDTV10A stopped responding with Vizio
Change the batteries in your remote. If your cat was laying on a button it could have drained them.
Here's tip - you can use your camera on your cell phone to see the IR signal coming out of your remote. Point the remote at your cam and press "On" or any button. You should see a bright flash with every key stroke.
SOURCE: Ive got a vue eye 48cm LCD tv model : 19B07 and
Did you find a solution to your problem. I have the same problem and any suggestion would be appreciated.
Thanks.
SOURCE: I have a Vizio GV47L LCD TV, and my SR605 could
Try these from onkyo: 10864, 10885, 11755, 11756,
11758
SOURCE: Have a Vue eye TV
HI:
First thing is to make sure the remote is bad, using ur cell phone in camera mode point the remote at the camers of your cell phone while pushing a button, it you see the infred light from the remote then the remote is functional. You may have a bad IR receiver in the television instead. If the remote is bad then try the remoteguy.com for a new or used one
SOURCE: I need the manufacturer or
From ATT website: UVERSE remote codes:
http://www.att.com/support_media/images/pdf/uverse/set-up-code-list.pdf
I see for VIZIO codes listed as 1429, 1433, 1439, 1489
Hi George. I have just bought a Vue eye Tv plasma and it is an all red picture on all inputs. Do you know why, could it be one of my settings?
jaime
Never heard of your tv look on the back and look where the serial number is and see if you can find a different name.
