Question about Hoover Washing Machines
Re hoover washer model no select 1600 hspf 167. The three baffles(?) inside the drum are loose, how do i gain access to tighten them ?
    Sergeant:
    Champion:
  • 291 Answers
You have to pull the tub
Posted on Nov 25, 2008
Hi I have a hoover washing machine model HSPF 167. Please can you tell me how to remove the lid? The buttons that control the machine have all gone inside the machine Thank you Mandy
Normally the screws are at the back, and the top panel comes off completely. The front panel is screwed in from inside. Hope this helps
Jan 12, 2018 | Hoover Washing Machines
Baffle is loose in dryer,how do I tighten it
Gain access from the top. tighten up baffle with 1/4 nutdriver i believe.
Feb 07, 2011 | Dryers
Inside the dryer there are 3 bars that stick out to help tumble the clothes. One of them has come loose and I'm not sure how to tighten it. It appears to be attached with screws that come thru the drum...
With the front off look up in the top left and right corners for some screws that hold the top of the dryer to the side panels. Depending on your model, there can be different styles. The old maytags used 3/8 in screws up inside the corners and the newer models had 5/16 screws right up front.
Once you get the front of the top loose you will be able to lift it like the hood on a car to gain access to the drum.
Rotate the drum by hand to put your loose fin at the top and tighten up your screws. Sometimes the screws will round out the holes on the drum too much and you may want to put a washer on the screw to secure it better.
Oct 07, 2010 | Maytag Dryers
One of the baffle fins are loose inside my Kenmore HE2 dryer. How can I tighten?
you can lid or remove the lid to gain access to the screws on the drum vanes.turn the drum by hand to get all the screws tight
Apr 21, 2010 | Kenmore Dryers
Fin on gas dryer loose.
The model number is generally inside the door or door jamb area. The top must be removed to access the drum to tighten the screws to the fin
Apr 15, 2010 | Maytag SDG4606A Gas Dryer
Short baffle is loose
You can pop the top with a drywall putty knife there is two tabs on each side. This will allow you to access the drum. Then tighten the screws holding the baffle in place.
Jan 22, 2010 | Maytag Dryers
Baffle is loose on drum. How do we get access to fix the baffle
The screws that hold the drum baffles in place are located along the outside of the drum. Usually, you need to lift the dryer top in order to access them, and they can be tightened without removing any components. However, all dryers are not contructed the same and access to the drum can vary. If you would please post a brand name and model number it would help in being able to determine exactly how your dryer is configured.
Aug 31, 2009 | Dryers
HNT 2135 Top Load Washer drum locked and can't
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2009 | Washing Machines
Baffle came loose from drum...how do I
there are 3 Tork screrws on the back panel that will allow for you to slide the top back and get access to the top of the drum
May 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
161 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
