Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
After a powerfailure the machine does not work at all.
Whirlpool top loader washing machine, 11kg
    President:
  • Whirlpool Master
  • 2,651 Answers
Check the outlet its plugged into, at the very least, with power you should fill with water
Posted on Nov 25, 2008
How do I take the top off a Whirlpool washing machine to repair/replace the lid switch?
The link is a great general disassembly video that includes several top loader design,
Whirlpool Washing Machine Repair
Depending on your specific model it can be simply removing two screws on the top and then removing the two spring clips and the lid plug.
Hope this helps?
Aug 25, 2016 | Whirlpool Washing Machines
I am having whirlpool washing machine model-whitemagic FSAN652 during washing machine suddenly stopped working and an error PE is displayed pl give me suggestion to rectify
whirlpool have a good fault code list on the net
go google and type in whirlpool top loader model------ and look for pdf version of manual or fault codes.
Jun 28, 2015 | Whirlpool Washing Machines
Top loader washing machine model sm8281115 leaking when filling loader whirlpool gold washing machine
The leak could be the filler tube, the soap dish, the water valve. You have to do some detective work to figure out where it is.
Jul 24, 2013 | Washing Machines
Hi. I have a Whirlpool 6th sense front loader 11kg washing machine (AWM 1008). After some very cold weather I now have an error code of FA. Do you know what this means and what I need to do? Thanks
Solution from a previous post i found for you.
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Most of the solutions i found for this same error were very similar. If all else fails read the manual or get a new washer when possible.
Feb 17, 2012 | Whirlpool Washing Machines
Toshiba washing machine with error code e7-4
Toshiba top washer machine with error code e7-4. What the problem and how to solve.
Oct 08, 2011 | Washing Machines
Water will not drain machine runs on wash cycle
If this is a top loader you have a bad lid switch.
If this is a front loader I suspect something is in the pump filter.
I took the time to write a tip about both and am going to include both:
Top loader woes
Front Loader woes
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 30, 2010 | Whirlpool Washing Machines
How do I change the drive belt on a top loader whirlpool washing machine
WITH THAT MODEL NUMBER, IT'S A FRONT LOADER YOU MEAN. THERE'S A PANEL IN THE BACK TO ACCESS THE BELT
Jan 24, 2010 | Whirlpool GHW9300 Duet Washer
Whirlpool top-loader LSQ9200LQ0
Im no expert, just pretty handy with all things mechanical...hope this helps:
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Washing-Machine-Parts/Whirlpool-Parts-LSQ9200LQ0/Whirlpool-Parts-82574.cfm
Jan 26, 2009 | Whirlpool LXR9445JT Top Load Washer
Whirlpool washing machine feels unbalance, loose, and licks water.
Nov 11, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
43 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
