I have a Philips Stremium WAC700 wireless music centre with two WAS700 remote stations. One of the stations will not connect to the centre. I have removed this station from the Centre and tried to re-install it, but it keeps showing me the message 'cannot connect to centre'. I think it needs to be restored to factory settings in order to start again, but it won't allow me into the menu to do this. As soon as it is turned on it shows the above message and does nothing else. Anmy ideas?
Phillips wac700 says booting up has not been used for a while
Hello
Just unplug the device from AC mains socket and replug it after 3 minutes and see whether it helps you. If not, a firware upgrade will be necessary. The supplied PC installer CD contains Media Manager [DMM] software. it will help you to upgrade for WAC700 center. For details see DMMs' help file. Refer to the manual CONNECT YOUR PC to learn how to install the software. OK.
Jan 16, 2012 | Philips WACS700 Shelf System
How do you connect an ipod or mp3 to the waC700 wireless music centre?
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input. Get a cable like the one described here:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
Feb 20, 2011 | Audio Players & Recorders
How to connect Music Match Jukebox and Philips Stremium WAC7000
Hi, I went to a free forum where they don't milead you - ;-)))
Oct 17, 2009 | Computers & Internet
Connect my center wireless via my route to my pc, but i have no
If you open the CD contents in a folder and run the Setup in XP compatibility mode, and the software should work. <div><br /></div> <div>Good luck from there! I still can't get my PC to recognize the music center.</div>
Aug 02, 2009 | Philips WACS700 Shelf System
WACS700 NOT CONNECTING TO STATION
Mine did the same, the station was trying to connect on channel 1 wi-fi where the centre was on channel 11, check under information and wi-fi for both. I then did a restore on the station, put both into installation mode and they found each other after a few mins.
Hope this helps
Jul 08, 2008 | Philips WACS700 Shelf System
Streamium Remote control
Use new batteries for the remote.
May 31, 2008 | Audio Players & Recorders
Wireless connection
Go to the Setitings menu on the Centre and all Stations. Select restore.
They will all revert to factory settings, so you can install them again.
When the centre has found all the stations, press stop on the centre, as they cannot connect until the centre has stopped searching.
Feb 21, 2008 | Philips WACS700 Shelf System
WACS700/05 Wireless Music Centre will not Boot up
tried to hold source and stop got message firmware damaged retriving copy from backup. power turn off, hold down source only power on comes up booting up please wait but in the lite up mode, 30 seconds later everything back on
Aug 20, 2007 | Philips WACS700 Shelf System
50 people viewed this question
 Grubhead
Grubhead
