Question about ASUS P5GD1-VM Motherboard
Samsung hard drive problem
I cannt detact samsung hard disk in "my computer",and there is
also a sound like-chit-----chit coming from it
I have done every possible way but no result
it's containing my softwares,projects,show reals, etc
is there any solution?
    President:
  • 1,073 Answers
Is that your first disc or your second (slave), if it is an ATA disc did u changed the jumper on the disk?
If it is an sata disc no need to change jumpers.
Sata or ATA it dosent matter, you need to manage the disc manuell.
Rightclick on "my computer"
chose "manage"
a bit down on the next menu you will see "Disc management"
klick on that one
now you will see all your discs, even the disc you cant see in "my copmputer"
You now need to formate and give the disc a name (letter), like F or G or watever letter you want thats free.
After done that you will see your new disc under "My Computer"
Good luck
Posted on Nov 27, 2008
I have a Samsung 3g 2tb harddisk and it makes strange noises. sometimes it doesnt work and a my pc freezed.
Here is what you need to know about hard drives.......
Some times you don't know if your hard drive is working or not. Your external hard disk might drop on the ground, or your desktop/laptop hard drive might not be booting. Which ever the case maybe, here is how to find out the condition of your hard disk:
Put your ear close to your hard disk, if you hear your hard disk make a crackling noise, be prepared to buy another hard disk because such hard disk is damaged and cannot be fixed. Also note that it is difficult to recover files from such hard drive.
But if you don't hear a crackling sound, use your hand(s) to feel the drive, if it vibrates, it means the hard disk is in good condition.
What damages external hard drive most times is if you don't eject (safely remove) it from your computer, when it drops on the ground or hits any hard object etc
If your external hard disk stops working, firstly, check if the hard disk inside the case is in good condition by checking for crackling sounds and vibration. Once you observe that the hard disk is in good condition, this means the hard drive case is defective/the cause of the problem. Get another drive case and your drive will work again without loosing any file/data on it.
For desktop/laptop hard drive maintenance, make sure you always shut down your computer properly, don't remove the CPU's power cord while the computer is turned on. To be on a safer side, always use UPS (uninterrupted power supply) for your desktop computer.
Also, when using your laptop, makes sure its fixed at a position. Avoid any shake as the hard disk might shift from its normal position in the process.
I hope this is helpful..........
Good luck.
Mar 07, 2011 | Samsung G3 Station Desktop External Drive...
My samsung sata hard disk HM120JI is not working fine. Windows is not coming up. I have replaced the hard disk and now want to copy data from samsung sata disk to the new disk. Could you please tell me how...
You can buy a SATA dongle that plugs in to the hard drive and plugs into the USB port on you computer $20 or buy a external SATA case to put the hard drive in $40 at most computer retailers.
Feb 06, 2011 | Samsung SpinPoint M60 HM120JI 120 GB SATA...
I have a 2 GB kingston Pen Drive, I cannot format it successfully because at the end of format it shows window cannt format the drive completely.
connect it to PC then... go to My Computer icon on desk top >> right click >> manage >> Disk management >> select ur USB Flash Drive/pen drive >> right click >>format ....ok......
Sep 27, 2010 | Kingston DataPak (DP-PCM2/260) .26 GB Hard...
My hard drive is not displayed in my computer and a sound like tik tik tik tik comes from inside the drive
The hard drive is faulty. The tik sound is generally known as the "click of death".
You need to replace the hard drive, it cannot be repaired.
If you need to recover data from this hard drive, there are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Sep 11, 2010 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Hard disk recognised but not show up in my computer
Check the BIOS configuration to see if it deects the hard drive.
When you boot up the Samsung, does the hard drive spin up, if it does not spin up or makes a clicking sound the the hard drive is faulty.
To get your laptop operating again, replace the hard disk and install Windows on the new hard disk.
Jul 22, 2009 | Samsung NC10-14GW Notebook
Ps2 not detacting hard disk
Check the your connections. Make sure than your HD is properly installed.
If this does not fix the issue, you may need to send the unit to Sony.
Apr 10, 2009 | Video Game Consoles & Games
Only detact my sata rom when canect my sata hard disk dasant detact both
hello, go into the bios and set the sata+ide (hard-drive settings) configure it for bolth. exit and save settings-and it should reboot and see all drives. hope this helps! goodluck. please don't forget to rate this solution. if you need further help,reply. (f2 in post gets ito bios if you don't have the manual, be careful if you do not know what you are doing, you could make it worse) check cables+power.
Mar 31, 2009 | Asrock P4VM8 Motherboard
External hdd not detected in my computer but is in device manager
You probably still need to partition it, before you can even format it.
Try the disk manager in Windows.
In the start menu, right-click "My Computer" and in the popup menu, select "Manage".
One computer management comes up, select disk management and there you should see the disk. You can then create a partition and format it.
Jules
Mar 01, 2009 | Western Digital Passport WDXML800UE...
Not Detact
Samsung Spinpoint MP0402H 40 GB Hard Drive
Oct 03, 2008 | Computers & Internet
Samsung hd400ld
clicking noises indicate a hard drive failure
May 22, 2017 | Samsung HM160JU Hard Drive
ASUS P5GD1-VM Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
