Question about SuperMicro (SYS-5014C-T) (SYS5014CT) Server
Beep sound in the server - SuperMicro (SYS-5014C-T) (SYS5014CT) Server
  • 1,913 Answers
Check *********** server is not infected of heat.
also check power supply.
also check ups is working properly.
Posted on Nov 25, 2008
Hi iam trouble my server hp dl 380 g7 no dislpy continue sound beeb
i need to know how many beeps long beeps, short beeps,
both short and long beeps, and how many times it happens.
than email me and i will help you resolve the issue
thank you rod
Mar 03, 2015 | HP Computers & Internet
Dose the server beep sound no display
If you only hear beep sounds but no display on your monitor it might mean a los of different issues.
Chech if your monitor works, connect it to another computer. If it woeks count how many beep sounds do you hear when you turn on your computer., go to google and input "meaning of beep sounds" Depending on numbre of beeps, you can get a fast diagnosis. Probably you have ahardware issue. If it is not tne monitor, it is your server and I suggest you should take it to a reapir shop
Sep 21, 2014 | Computers & Internet
Beep sound problem in server SR2612URR?
it could be the memory or video card,if it has onboard video,then its most likly the memory,remove then 1 at a time clean contacts then reseat them.
Jul 29, 2014 | Intel SR2612URRNA 2U Barebone Server
Dell PE 1800 showed one SCSI 73G non critical state on a RAID 5 array of 3 disks. Shutdown the server, removed the SCSI disk and booted, server booted but continous beep sound, trying to rebuild the array...
Hi, try to renew the drivers and firmware from here:
Continuous beep related to ram ,try to remove ram and insert it, and if u still get beep change your ram.
Continious beeb sound is ram or cpu failure. Is the cpu fan spinning ??
If not the cpu is over heating.
Try to remove the ram modules and clean the contact points
with a piece of paper. Be very carefull when you do that !!!!!
And blow the dust out of your server, with a high pressure can.
Hope this was helpfull.
Mar 28, 2011 | Dell PowerEdge 1800 Server
How to turn off Beeping sound
Not sure what the beeping sound is but if it is an error code beep, go into your BIOS at startup and disable audiable alarm for boot errors.
Good Luck
Jul 09, 2010 | Dell PowerEdge 6650 Server
Error beep sound on server, conf:Intel server motherboard se7520bd2 2 gb ram scsi harddrive problum:long beep sound in LSI LOGIC CARD
I don't think SCSI card give beep error codes. If you listed this item, most likely this is the problem and your MB is telling u this. Your SCSI card is most likely damaged. Try to make sure it is inserted in the pci slot properly. If it a new one. We rarely use SCSI cards any longer as most Servers have plenty of HDD space and the Hot Swappable options make them easy to replace if they get damaged.
As a tech, I would first check the Mother Board (BIOS) Beep Error codes to determine exactly what the problem is. Those beeps tell u what hardware is malfunctioning.
Jun 06, 2009 | Intel Xeon, 3.6 GHz (bx80546kg3600ep)...
Beep sound
Could be memory. Does it sound like beep codes? If so its probably the memory.
Mar 11, 2009 | Acer Altos G500 Server
HP Proliant ML370 Server i have problems solving this server problem. When you turn on the server it tries to initialize and come up. But after a while it gives a beep sound, this sound is like that of a...
Remove all the cards except dispaly from the slots,disconnect all  hdds and start the server in minimum hardware and check.reset bios .Is there any LEDs in the mother board is glowing amber or red colour??Please try these diagnostics.
Oct 29, 2008 | HP Compaq ProLiant ML530 Server
HP Proliant ML370 Server: Very Urgent Please
Open the system cover and check whether any LEDs showing amber or Red colour
Beep sound
This problem is due to the mix of registered and unregistered DIMMs. 64Mb and 128 Mb DIMM's are unregistered memory technology 256MB is registered memory technology.
A mix of registered and unregistered memory prevents the server from completing startup, and results in an error beep sequence and a blank screen..Use registered memory and it will be fine..
Oct 18, 2007 | Dell PowerEdge 1600SC Server
SuperMicro (SYS-5014C-T) (SYS5014CT) Server Logo
387 people viewed this question
Top SuperMicro Computers & Internet Experts
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
