I am tryin to connect my Phillips HTS3011/05 home cinema system to my Technika LCD32-207 tv. It works fine if i watch a dvd, but it doesnt work when i play my Xbox 360 through its HD cable, or watch normal tv. I was wondering if you guys knew the correct sockets i needed to connect wires to, in order to be able to use the speakers on the xbox and TV, not just DVD's? Thanks!!!
  • Dolly_parton Nov 25, 2008
    Im not sure if it has an output port. Its just got loads or sockets in the back! Never seen so many! But yeah, i cant get it to work at all with my xbox. Quite annoying, as it worked fine with my old tv, but i dropped it and it broke, so i went out and spoilt myself with a lcd hdtv one! As my old was was just a normal one. Complicated huh! ha!
    Thanks though!
  • 89 Answers
My TV has a Output port, It is only output for sound, IF you TV has this, then you need to use those, But i dono if it would have them, If it dosent the you will not be able to use the surround for everything without Plugging it in as you use it,
Posted on Nov 25, 2008
Cant hear my digital tv through my home cinema speakers
http://www.dummies.com/how-to/content/how-to-connect-an-hdtv-to-your-sound-system-or-home-theater.html
Matthew, I found this link which covers the basic possibilities for connections. It has a video backed up by the text version as well. Hope it helps.
Dec 07, 2013 | Samsung HT-X200 Theater System
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
I cannot get surround sound to work when watching normal tv or sky,i have a samung tv and samsung home cinema system.how can i correct this
cant get surround sound through tv but works on dvd???
do ineed a component cable from dvd to tv?
tv= samsung le40c530
dvd= samsung ah68-0041oy
Feb 05, 2010 | Samsung HT-Q100 System
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
No sound through the Panasonic cinema surround sound on TV
Had a similar problem mate. I solved it by connecting the tv to the PT460 system with a scart lead. You then have to have the AV channel selected on the PT460 system to listen to the tv. You will always have to have the AV channel on the PT460 selected to listen to any sound transmitted through the tv - be it playstation/xbox or any other device that you may connect in the future with HDMI leads or otherwise. Hope this helps
Jan 04, 2009 | Panasonic Home Theater System System
I cant get my samsung home cinema system to play through my t.v
I bought the optical audio cable ($15 WalMart) and use the Digital In on the DVD player to play the sound through the surround system and turned the TV speakers off. Works great! The optial audio has square ends and looks transparent with just one round shaped cable that goes from the TV to the back of the DVD player.
Jan 01, 2009 | Samsung HT-X40 System
Surround sound ok whilst playing dvd but not working for tv
On your Sagem TV you should have two RCA ouputs (red and white connection usually marked ouput) ) Connect these to the input on the surround system using the interlink cable.
You should then be able to hear the sound from the TV by changing the SOURCE on the home cinema remote.
Better still if you have a digital out on your TV use that instead.
Nov 25, 2008 | Audio Players & Recorders
CAN ONLY GET THE SURROUND SOUND TO WORK WITH DVD'S NOT WITH NORMAL TV OR SKY?? WHY??
You should have a AUDIO menu in which you can simulate true surround sound. This should be in your owners manual. Your DVD is recorded in dolby surround sound that's why on your set it will be reproduced as recorded. I hope Samsung is using a ATSC tuner in that model?
Apr 04, 2008 | Samsung HT-Q100 System
Trying to install a new 50
a good way to go is to connect the home cinema kit staight to the tv though phono leads, see if your tv has a phono in and out this must not be a av socket. you should then connect it in to your cinema kit so what ever you watch comes though ur cinema system
hope this helps
Feb 09, 2008 | Televison & Video
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
