I got a NETGEAR wireless modem WPN824V2 i can get on the internet through the cable but cant get on through wireless.My wireless switch is on and it says I got excellent srength.CAN anyone can help me .THANKS
  • 728 Answers
Thanks for posting. First reset the modem by pressing the reset button, then connect to the admin page of the router, normally the gateway IP (http://192.168.1.1). The you will find the WAN (isp) settings. Enter your login info for your isp and clone your mac address, normally under advanced. __________________
Hope this helps
Mark
Posted on Dec 02, 2008
I cant get internet from my rouder
Wired or wireless? Shut down the computer. Unplug the NetGear. Unplug the ISP modem, remove battery, if applicable, Check ALL cables and connections, reseat ALL connections. plug in the ISP modem, wait for selftest. Plug in the NetGear, wait for selftest. Reboot the computer. Try connecting with a Ethernet cable if you are trying to connect wirelessly to verify. If that fails, contact your ISP to verify signal comming in. Have a ISP tech come out to analyze the signal.
Jan 06, 2013 | NetGear Computers & Internet
How do i hook this router up wpn824v2
Your router is connected between your modem (Cable or DSL) and your computer. Connect the modem output to the WAN or Internet connector on your router. Connect any of the output connectors to your computer's Network Input. Log in to the router by (with your Browser) going to 192.168.1.1 ... after logging to router (login parameters in manual) set your Network Name (SSID) and set up Wireless security. I prefer using WPS-PSK[TKIP] for its ease of setup.
Nov 11, 2009 | NetGear RangeMax WPN824 Router
Limited or no conncetivity?
Seems to be issue with the switch. If you can get internet after bypassing the switch then it is for sure an issue with the switch. try connecting the cable to other ports of the switch.
If it still does not work then it is time for you to replace the switch.
Rate it,if it helps.
Jun 29, 2009 | NetGear Computers & Internet
Cannot login and have reset....
use the console cable . By using this u can able to go inside the router and after going inside just give the respective IP and after giving the ip to the router u can access the router by using Internet Explorer .
Jun 02, 2009 | NetGear DG834G Router
Can't connect Netgear router with ATT DSL
After you hook everything up the first thing you want to do is power cycle everything. So unplug the power cord on the router and the modem, Then plug the modem back in first and once the lights all come back on then plug in your router and once those lights come up i would reboot your PC and see it that helps.
Apr 08, 2009 | NetGear RangeMax WPN824 Router
Conecting netgar wpn824v2 to cable internet
what exactly do you plug directly in the wall? what kind of connector does it use? an 'f' connector on a coax cable or RJ45 (like a phone plug? if you are using a cable connection you have to have a modem for that to work. if you are using a Ethernet cable tied directly to a jack on the wall you'll have to be sure routers are allowed to connect. or register the router with your provider. be sure your wireless router is getting an address form the internet provider. with out more details i can't give you any more specifics.
-good luck-
Will
compressionconnector.com
Feb 19, 2009 | NetGear DG834G Router
My sister has a Motorola SP4200 router with a Netgear WPN824v2 wireless router/accesspoint/switch connected to it. Previously she had the SP4200 connected to port 1 (not WAN) port on the Netgear as it is...
it might be asking for a WEP password in order for you to use it which is on the botom of the router or the game sistem is the one causing the trouble and should not be conected to any wirless or eathernet internet routers.
Jan 03, 2009 | Computers & Internet
Connection issue
put the blue cable connection with the router and cable modem first.configure wireless setup.put the desktop rj45 connection to a free router rj45port.As u are getting internet on wireless check the desktop ip configuration.obtain auto ip configuration should be clicked.
Jun 28, 2008 | NetGear FS605 - 5-Port 10/100 Network...
Netgear wpn824v2
Plug your modem into the Internet port on the router, plug in any computers that will be hard wired. Open Internet Explorer and type http://192.168.1.1 This will start up the Netgear install wizard.
May 22, 2008 | NetGear RangeMax WPN824 Wireless Router...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
