Question about Philips Televison & Video
When Turned on the Screen says ''Locked''
My phillips TV has been locked (probably by my 18 month old) could you please advise me how to unlock it. I have the remote control.
    Scholar:
  • 188 Answers
Please post the model of your TV. 0711 is a default code to access the blocking menu items on some Phillips TVs. have you tried changing the channel. maybe it's just the one channel is blocked. More likely the TV may be in a blocked mode. If you have the manual there should be instructions to reset the blocked mode. There are manuals online. Use Google or any other search and type in your model number and "manual."
Posted on Nov 26, 2008
Blue screen and red locket sign
It is locked. Unlock it. If you wish to get some details; check the site linked here. Pull up older posts.
Unlock procedure and to override the password lock to many popular brand TVs are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
May 26, 2016 | Televison & Video
When i turn on my TV (Philips) it's shows black screen and in middle is writed Locked after 7-10sec it turns off
That's a fairly old TV...The locked means that specific circuitry is locked because if running it would cause a major problem, and that is also why it shuts off. You are going to have to find someone familiar with Phillips TV's.
Oct 29, 2013 | Philips Televison & Video
V-chip block passcode
Hello
You must have its original remote control handset to unlock your Mitsubishi tv.
After you set the lock, you must use your pass code
to view a locked program, view the locked TV, view
a locked channel, cancel the lock, or enter the Lock
menus.
If you forget your pass code, you can view the locked
TV without entering your pass code. When you are
prompted for your pass code, press the number 9 and
QV keys on the TV remote control at the same time. This
process temporarily unlocks the TV.
When entering the Lock menu, this process deletes
your old pass code and prompts you to enter a new
pass code.
• You can either enter a new pass code to open the
Lock menu and make changes or press EXIT to close
the menu.
• If any of the locks are turned on and you exit the
menus when prompted for a new code, the old
code and all lock settings are retained.
• If all locks are turned off and you exit the menus
when prompted for a new code, then the previous
code is erased.
OK.
Mar 17, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Phillips flat panel hdmi locked. all other inputs are good.
got to manufacturer website find your model tv download manual from there
Sep 10, 2009 | Televison & Video
Kids locked up the TV, need code to unlock it.
Try this: press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
Apr 21, 2009 | Jensen JER-323 Remote Control
TV locked with blue screen
Try resetting the TV to factory settings thusly:
Turn on the TV. While holding down the RESET button on the remote
control, press the POWER button on the TV. (The TV will turn itself off, then
back on again.) Release the RESET button.
Owner's manual available here:
http://www.docs.sony.com/reflib/docget.asp?manualid=9635&template_id=1&region_id=1&DL=
Mar 02, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
TV is locked
Just like a few of your other readers mentioned, we pushed the button below the AV/TV button for 3 seconds and the screen unlocked. Thanks for everyone's advise, we were ready to throw out the TV.
Feb 18, 2009 | Televison & Video
Locked
if its 1 month old call for service your under warranty
Jan 05, 2009 | Washing Machines
Phillips 28PW6006/05-Locked
First you need to get your remote working, without it you cannot unlock the tv. If the romote is not phisically broken (or smashed) make sure the battery contacts are clean and install new batteries.
Once you get the remote working (hopefully) Enter the MENU and select 'Features'. Set the Child Lock to OFF. If you cannot get the remote to work try a universal remote, setting it up with the codes for your tv provided in the setup manual for the universal remote.
Mar 17, 2008 | Televison & Video
Whirlpool duet washing machine ghw9100lw1
To turn off "Control lock" : press and hold the "End of cycle signal" button for three seconds.
Nov 17, 2007 | Washing Machines
Televison & Video Logo
174 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
