Thought it was the battery so replaced but it won't even turn over, even when we tried boosting it
SOURCE: Even with a fully charged
Here is a test you can do.. Follow the thick red cable from the battery to what is call a solenoid you will see two rods with the red wire from the batter going to it and a red wire going to the starter leaving it.. Take a screw driver and connect the metal rod to each other make sure you are touching the rubber handle of the screw driver you will see sparks because you are connecting the batter power to the starter.. if the engine turns over then you need to replace the solendoid that is your problem.. you pick them up at any auto store. If that doesnt work please let me know thanks..
SOURCE: ariens tractor has new battery and won't turn over
couple things to check start by checking the starter itself then check the starter switch... good luck
SOURCE: Tractor won't turn over. Replaced Battery,
Is the engine free to rotate? Can you move it by hand? If not, the starter can't.
If so, try removing the plug and starting it.
Gary
SOURCE: My Craftsman 21 Hp 42"
check the soleniod with the key on cross the cables out with a screw driver if it starts that way its a bet its the soleniod
