Question about Intel DG31PR Motherboard
Line in port not woorking
While connecting audio device throgh line in port itnot working.
I connected TV tuner card audio out to the line in port.
Configured the port as Line in.
Motherboard using DG31PR
  • Bineesh Jose Nov 25, 2008
    I tried with head phone also its not working.
  • 89 Answers
I cant say that i have ever made my Line in port work... try the microphone in port. maybe that will work.
Posted on Nov 25, 2008
I conect my sony nwz162 with computer when i plag out my mp3 will not woork plz tell me waths problem in this
How are you connecting them? You should use a stereo 3.5mm plug on both ends of the cable. Plug the player audio out (not headphone) to the line in port of the audio card on the PC.
Jun 27, 2016 | Sony Audio Players & Recorders
AUDIO NOT GETTING RECORDED IN FRONTECH INTERNAL TV TUNER CARD
Dear Sir,
For every tv tuner card there is line out socket, use two sided phone plug one side of it connect it to the the audio out off tv tuner and another to the Line in socket of your PC,then go the volume properties increase the line in volume. It deffinately solves your problem.If you have any problem regarding this issue leave a feedback,we will glad to assist you
fbe63e4.gif Phone connector
Have a nice day
good luck
Sep 17, 2009 | ASUS K8V-MX Motherboard
Intex tv tuner card SAA713x and computer sound on one point
this will make your life alot easier
http://www.radioshack.com/product/index.jsp?productId=2103863
best way to do it bud
Aug 20, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
The line in is not working.. 2 audio connectors one internal and one external came with d tv tuner card. i did not find any port on board(DG31PR) to connect the internal connector.so i connected the...
YOUR MOTHERBOARD IS NOT FULLY UPDATED WITH TV AUDIBLE DRIVERS. GO TO YOUR NEAREST OUTLET ASK FOR A RECENT MOTHERBOARD CD MATCHING YOUR MOTHERBOARD SO THAT YOU COULD INSTALL THE NECESSARY MODULE.
HOWEVER, WAIT FOR MY TOMORROW'S ANSWERS IN ORDER TO GIVE YOU A BRIGDE OF MOTHERBOARD TO EASE THE AUDIO OUT.
THANKS
WONDER
Aug 11, 2009 | Computers & Internet
(Have u got a small cable with both side 3.5mm pin like head ph cable cord if not buy it) NOW FoLLOW THE STEPS 1)plug the cable between tv card jack(green slot) to line in jack (computer pink slot) 2)plug ur spker to line out jack(green slot in computer) 3) double click on small spker icon (left side to ur screen near clock) 4) click options menu>Properties>chose audio out option 4m drop box(see image)
11_2_2011_5_27_42_am.jpg5)click rear pink in >ok And all done have fun
Jun 18, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Line in problem of tv tuner with DG31PR board
u must connect speaker on tv tuner card;s jack. and go in control panel click on sound and audio device than select audio and change sound playback default device.thanx enjoy good luck plz vote on my comments
Jun 16, 2009 | Intel DG31PR Motherboard
Conexant BT878KHF Audio
Connect the audio output of the TV card to the line-in of the sound card. The connecting wire should have jacks similar to headphone jacks at both ends.
May 04, 2009 | Computers & Internet
322 dual tuner-failure to receive signal only to one TV
If you have one cable leading from the wall toward the back of the receiver you can disconnect the seperator and diplexer (if equipped) from the SAT 1 and SAT 2 ports and connect the line from the wall directly to one of the ports and run a check switch test. You should get a 1 of 2-4 depending on lnb type on the tuner you connected the line to and a 1 of 38 on the other. Perform this operation for both SAT 1 AND SAT2 as described above. If you have the 1 of 38 appearing only on the port that the line is not connected to then the receiver is good and the problem may be the seperator which is the silver device that has two wires going to the back of the receiver initally and one port connected to the SAT port of a diplexer. Disconnect the diplexer and hook the seperator to the receiver and run the SAT line from the wall to the single port of the seperator and do a check switch. If you don't get a 1 of 38 it is good and you have a bad diplexer. If your system does not use diplexers and you are experiencing the loss on TV2 you may have a bad TV2port on the receiver. You can take the wire from the TV2 PORT(in home distribution system) and place it on the 3-4 that the TV1 line is run from. Then go to TV2 and put that tv on channel 3 and see if you have picture. If the problem is at TV1 reverse the process by connecting the line on the 3-4 ut to the TV2 port and putting TV1 on chanel 60 or 73 and see if you get picture. if either produces picture on the bad tv the port to that TV is faulty. If you were still unable to get picture it may be a cabling, connector, barrel isssue that requires a tech to visit. Hope this assists you. Thanks for using Fix Ya.
Jan 03, 2009 | DISH Network 322 DTV Receiver
Intel DG31PR Motherboard Logo
85 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
