sorry, your wrong. problem caused by change in formating of dvd by different manufactureressorry, your wrong. problem caused by change in formating of dvd by different manufactureres
You can't post conmments that contain an email address.
They look the same, but CDs and DVDs are two different media, and a combination drive essentially has two separate optical systems in one package. What sometimes happens is that the laser that reads and writes one kind of disc stops working, while the other format isn't affected. If the DVD problem is happening on every disc you try, the failure is complete. Sometimes in its early stages some discs read fine but others don't. Sometimes the problem may occur on dual-layer DVDs only but not single-layer ones. In any case, there's no way to repair the drive other than by replacing it. You can find replacements online for most laptops, but they can be expensive. If you don't mind carrying an extra piece in your computer case, you can get a USB external drive and just leave the bad one in place.
Do follow steps, 1) change your DVD disk :- if it's work, don't worry about the driver. 2) go to Device Manager & check the DVD/CD ROM driver's property, check weather it has been disabled. 3) change your OS or Upgrade current OS 4) if above steps are not worked, then you have to bring your laptop to a service provider...
if you are in warranty period don't remove any parts of it, they will replaced a another DVD driver
You need to either replace the drive with a working drive or replace the laser within your current drive. If you change drives you will first need to obtain your dvd-key and then flash it into your new drives firmware.
1. Completely remove any dvd/cd player/burner softwares (i.e. Nero, Power DVD, etc.).
2. Go to device manager and remove your DVD/CD device from the device list
3. Restart you laptop
4. Windows will then try to reinstall the device drivers again for the DVD drive.
5. After another restart, then reinstall your dvd softwares again.
