Question about Konica Hexar Silver 35mm Point and Shoot Camera
EEE error on my Konica Hexar AF
All of a sudden I have an EEE appears on my Konica Hexar AF screen. I have tried to remove the batteries and turn the camera on again, but it does not help. Can you advise on this problem? Do I need to send camera for repair? What will be approx cost of it?
thank you very much in advance,
Alexander
  • Konica Master
  • 19,396 Answers
If you are using Windows xp , download the UVC driver update from http://www.microsoft.com/downloads/deta … laylang=en.
If that is not enough follow the threads below about EEE and USB drivers.
EeeUser ASUS Eee PC Forum
EeeUser ASUS Eee PC Forum / Camera drivers
Posted on May 30, 2009
I have a asus eee pc 900hd, and all of a sudden when the computer starts up, the screen immediately is black with a blinking white cursor. Any suggestions on the problem?
Hello..
Either you have an operating system problem.or memory issue.
First, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date.
If still a problem, disconnect all cables. Remove the battery. Remove the memory cover. Try reseating (removing and reinserting) your memory (try one module at a time to test). Reinsert the battery. Connect all cables and boot.
Hope this helps.
Apr 09, 2011 | ASUS Eee PC 900HD Netbook
Digital camera
Hello, the problem in your camera can be the CCD. Please contact your nearest Sony dealer (they are now in charge for KonicaMinolta cameras. Please ask the dealer for the repair price estimate. Best regards, Arpi If you want more info, please advice.
Jul 10, 2007 | Konica Minolta DiMAGE Z3 Digital Camera
Hello, I have fuji finepix F50fd camera. It suddenly takes blurred pictures. The lens is clean and there are no messages on the screen. Can't remeber dropping it or damaging it in any way. Regards, Sofia
Welcome to FixYa.
There are three reasons why do you get a blurred images.
1. The camera lens is dirty
- clean the lens with soft and dry cloth
2. AF frame (lit red) and !AF appeared when taking pictures.
- check the focus on the subject and take pictures
3. A small camera icon appeared when taking pictures
- It may cause camera shae. Hold the camera steadily.Use flash photography. A tripod may be recommended, depending on the scene and mode.
Feel free to send us comments or suggestions if this solution was helpful.
Thank you for using FixYa.
Apr 08, 2011 | Fuji Finepix F50FD Digital Camera
AF error will not go away after cleaning vent and lint filters
Thank you for contacting Fixya.com.
AF is an error that will flash if a restricted air flow is sensed by the dryer control. If three consecutive cycles have low airflow the control will flash the AF error.
The AF error code can be cleared by pressing the Drying Temp pad for 5 seconds while in stand-by mode. AF will flash in the display for 1 second then "on" will appear in the display. If you press Drying Temp again and "of" will appear in the display indicating the AF error display has been turned off. Try this procedure and see if the "of" error goes away. If the "of" came up in the display by itself then the keypad may be stuck. However After cleaning the dryer's lint screen, ensure that the exterior exhaust hood connected to the dryer is unblocked, ensure that the vent connecting the dryer to the wall is clear and see that the vent is cleaned professionally.
Please get back to us if you have any further query.
Nov 29, 2010 | Kenmore 67062 Dryer
HEXAR RF - I WAS CHECKING THE SHUTTER SPEEDS AND THEN THE SHUTTER STOPPED WORKING AND THE NUMBER 11 NOW SHOWS UP AND BLINKS IN THE FILM COUNT INDICATOR
The Hexar RF is a very expensive film camera with an electronic shutter. Make sure the battery and contacts are clean. Remove the batteries and see if that resets the camera. If not, it is time for professional repair. This camera takes high quality Hexar lenses in a KM mount. This is not an old camera, so repair should be easy.
Oct 23, 2010 | Konica Hexar RF 35mm Rangefinder Camera
I'm having a problem with my Konica Hexar RF. Today I was shooting , the camera was working fine, then '10' appeared on the top screen. Now it wont work at all. I just see '10' even with new batteries.
It seems a common error with this film camera. There are parts, but they are replacing the entire shutter at times from the research I have found. That can be an expensive repair against the cost of a different camera. Rangefinder used to be extreamly reliable, it seems this model had production problems.
Aug 09, 2010 | Konica Hexar RF 35mm Rangefinder Camera
Err c 0500
This error code is a fuser problem and maybe in my experience a morning problem.
Try to clear the error the error with this procedure:
Hold down utility counter for 3 seconds and in the screen will appear a trouble reset, then touch it and turn off and on the main, it will clear the error code.
If it does not see if you have fuser problems with the termisotrs and also check the power.
Jul 21, 2010 | Konica Minolta Bizhub 222 Black and White...
Auto focus suddenly stopped working
This may not be the same as your issue, but our AF stopped working as well. I tried all the recommended fixes - removing the card and battery, recharging the latter, removing the lens and cleaning the contacts, etc. None of those things worked. However, I then switched to MF, requiring me to turn the barrel, and I realized it was stuck and just needed a little force to get unstuck. Might have been the humidity. Anyway, our problem was solved - AF was back to normal after that.
Jan 11, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Focusing ring looseness on 50/1.2 M-Hexanon
did you see any rubber gasket on the ring.. this could be the one turn out to be loosen,
did you dropped or any kind of incident happened on the lens.
Nov 06, 2008 | Cameras
Konica Hexar Silver 35mm Point and Shoot Camera Logo
692 people viewed this question
Top Konica Cameras Experts
myxelpyxel
Level 1 Expert
Lawrence Oravetz
Are you a Konica Camera Expert? Answer questions, earn points and help others
