Question about Miele Washing Machines
Hi - we have a Miele T284 tumble drier which is 2 weeks old and seems to have developed a fault. The machine stops after about 30 seconds with the buzzer going and Finish/anti crease light on. This is with laundry in. Have checked the vents are OK, no fluff in filters. Only works on the 30 min warm air setting. Any help appreciated
    Scholar:
  • 131 Answers
If this unit is only two weeks old,its safe to say its under warranty ,if you can't remedy this yourself by consulting the owners manual,contact the place of purchase &/or the manufacture,i'm sure they will be glad to repair or replace the dryer.any attempt by you or any unqualified person to repair this will void your warranty.hope this helps.thanx for using fix-ya
Posted on Nov 26, 2008
Just purchased 2nd hand Miele novotronic w310. Does machine automatically stop? Cycle ends, anti crease light on and machine just tumbles clothes makes odd noise, then tumbles again. Is the normal?
NORMALLY WHEN A DRYER COMPLETES IT'S DRYING TIME IT WILL GO THROUGH A COOLING DOWN CYCLE,
DRYER WILL START TURNING WITH FAN ON ONLY FOR A FEW SECONDS THEN STOP, AFTER A SHORT PERIOD IT WILL DO IT AGAIN AND AGAIN UNTIL UNIT HAS COOLED DOWN, HOPE THIS IS WHAT YOU ARE EXPERIENCING
GOOD LUCK
Sep 22, 2016 | Miele Washing Machines
TUMBLE DRIER STOPPED HEATING
Gas dryer?
If so, probably bad gas solenoid valves. They can safely be replaced without fear of releasing gas. Two phillips screws, two pull off wire plugs. That's it. Cost about $30 bucks depending on where you buy them. They are a universal part and will fit 99.9% of machines.
www.repairclinic.com
Best of luck...
May 18, 2015 | Dryers
Error code 1477 on Miele T8322 Drier. What does this mean?
not sure bout the code. but it seems to indicate that the dryer is shutting down at certain heat levels. Thus u may have issues with ur cycling thermostat or thermal cut off or even ur venting and duct system.
Jan 28, 2015 | Miele Dryers
When not in use Miele washing machine tapping noise
Hi.
I need more info from you.
What model is this machine? How old is it?
It is possible that the sound comes from the water dispenser valve selector. If you could give me more info about your Miele machine, it would be helpfull.
/ Geir
Miele Technical Engineer
Sep 27, 2014 | Miele Washing Machines
Why is my Tumble Drier keeps beeping without stopping a few minutes into the drying program?
It sounds like the carbon brushes are probably worn down - they ride on the drum (in the top ) and determine the amount of moisture left in the clothes for drying - they connect to the drum and the metal bar inside the dryer - A wet clothing item conducts between the two giving the dryer an idea of how much moisture is left in the load - equal to how much time / heat is needed to dry load as required. These brushes wear out and need to be replaced over time
Aug 03, 2014 | Miele Washing Machines
Miele novotronic wt 945 door release button not responding wash functions not responding when turned on and off only drier light is on no actual response from drier section cannot open the machine Is...
Sorry but I would strongly suggest that sending any part to Miele and paying Miele for fixing the fault would cost considerably more that a 'local' service engineer ;-0(
Also Miele would not necessarily accept someone sending parts or all of a washer to it.
'Local' Service engineers are available for exactly the purpose of avoiding customers having to send suspected faulty equipment back to the factory. Also factories are not normally set up for carrying out retail repairs.
So, sorry again. Call your local repair man who should have the equipment to diagnose and cure the fault ;-0)
Good luck,
John C
Mar 06, 2011 | Washing Machines
My door for a hotpoint ctd40 tumble drier wont stay closed. The spring latch seems ok but not holding dooe closed. Any ideas since it dont say anything in my manual about it and its 2 yrs old. cheers andy
Hi andy.
the fault is likely to be in the roller catch mechanism. Hotpoint have modified these. Part Number is C00257618.
It includes both door latch and catch.
If you have problems obtaining one please email me on: aardvark.repairs@btinternet.com or call me on 01733 307019
Regards
aardvark repairs
Nov 18, 2009 | Hotpoint Dryers
I have a zwd12270w. Seven second after pressing
The problem is with the tumble drier heating element. If you remove the top of the machine (disconnect it from the electricity supply first!) you will find a big metal oblong "bar" that runs from the front to the rear of the machine. At the rear there are 4 white wires connected to the metal "bar". Make a note of where they go and remove them. You may need pliers to get a good grip of them. Once removed, the washing machine should work just fine but obviously the tumble drier will not. This is a well known fault and it may be worth contacting Zanussi as they MUST know about it!
Jun 28, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
HELLO, I a 6mth old Miele washer dryer and i the last two weeks on two occasions the water protection system has activated which shuts the system down and a small amount of water has been left on the...
It sounds more like a pump problem than the float. They normally do not faulter but hey wonders do still excist. Unfortunately the machine is still under warranty and that makes it hard as you can not open the machine yourself.
May 13, 2008 | Washing Machines
Washing Machines Logo
264 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
