Question about Dryers
DRYER SHUTS OFF ON HIGH SETTING- FINE ON LOW HEAT
I HAVE A WHIRPOOL ELECTIC DRYER THATS ABOUT 12 YEARS OLD. I BLEW THE 30AMP FUSE, NOW ON THE HIGH HEAT SETTING IT WILL RUN FOR A FEW MINUTES THEN STOPS. BUT ON LOW HEAT IT WILL RUN THRU THE ENTIRE CYCLE?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 60 Answers
If all previous checks have not cured the problem it loks like yhe heating coils have shorted out and burned out .replacing the unit is the answer to this one
Posted on Nov 05, 2014
    Scholar:
  • 131 Answers
Lets start simple on this,first check your dryer vent for obstructions(mainly lint build up,)also check the weather flap (where your unit vents to the outside)this should swing open when the unit is in operation.either one of these can cause excessive heat build up in the unit.(this will cause the thermal limit switch to shut the unit down)thus keeping you from setting your clothes on fire.hope this helps,thanx for using fix-ya
Posted on Nov 26, 2008
I have a 2005 cavilier..it keeps blowing the main 30amp fuse when the ac is turned on..any help
you need to inspect all AC WIRING, to find the SHORT, thats causing the fuse to blow ! donot put another fuse in until you locate the shorted condition, ( bad connection, frayed wire, bare wire touching metal along this circuit, you might have a bad switch, your ac has two switches under hood, one @ high pressure side and one @ low pressure side. and your main control switch, check all wires & connections
Mar 11, 2013 | 1991 Chevrolet Cavalier
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
Maytag dryer is less than 3 years old. Blew thermal fuse. Cleaned all of the venting inside and out. dryer still overheating and blowing the thermal fuse. Replaced the thermal fuse and the high temp sensor...
Have you tried replacing the operating thermastat it's what shuts it off at the right temp and would cause the thermal fuse to go if it is not shuting.off at the right temp. It happens.
Hope this helps.
Dec 05, 2010 | Maytag PYE2300AY Electric Dryer
NO Heat
Replace the timer,the spot on the timer is burned out.
Oct 01, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore Heavy Duty 80 Series Gas Dryer won't cycle/won't heat.
if you ran this unit awhile without timer advancing,,now you blew the thermal fuse,,,re place thermal fuse and timer..
Nov 27, 2008 | Kenmore 73952 Gas Dryer
Dryer has no heat on any setting after house fuse blew.
We got the problem with our dryer figured out. After checking possible solutions on-line, we checked the power going into the dryer with a ohm tester and discovered we weren't getting full power that we expected. Just after changing the fuses in the house the first time we heard a snap sound but the fuses appeared to be fine, but no heat to the dryer. When we discovered we weren't getting full power we used the ohm tester to test the fuses indiviually and discovered one of the fuses were bad. Put in a new fuse and wala! the dryer is putting out heat. Thank you so much for the service you provide to "do-it-yourselfers" like us!
Nov 10, 2008 | Dryers
Very high heat and timer won't advance
Stop !!! You are creating a much larger problem by trying to fix this at this point.To correct the problems it has now is not going to be practical to cost.My advise is to push this aside before you have a disaster.Buy a new /used dryer that is working and when it does need a repair you let me know,do not try to repair anything your not sure of because it makes it impossible to correct the added problems at a low cost.
Apr 19, 2008 | Kenmore 62602 Electric Dryer
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Dryers Logo
115 people viewed this question
Top Dryers Experts
