Question about Intel Foxconn: Foxconn CPU Cooler For P4 478 3.4GHz CPU Cooling Kit
Could a faulty fan cause my pc not to switch on
When switching on my PC, the power light and keyboard lights come on for 1 second and go off again but my PC does not switch on. Could it be my fan that is causing this?
  • marvinm63 Nov 25, 2008
    I have tried a new power supply but the problem still persists, the fan will go on, spin but then go off immediately. There is a contineous clicking/popping (not a beeping) sound after this. What could cause this?
    Novelist:
    Scholar:
  • 85 Answers
Normally the computer will still come on even if the fan is not there but then will sometime display cpu fan warning and then sometimes turn off depending on motherboard and so on but unless the fan wires are shorted out or something this is most likely not the case
It sounds like your power supply has gone bad
Do you hear any type of winning sound or like a discharge sound that is barely noticeable when you turn it on? You would probably almost have to put your ear right next to it to hear it or listen carefully when you press power because that sound is one of the capacitors in the power supply that has gone bad and the power supply would need to be replaced
Do you have another power supply you can use to see if it works with a different one?
Posted on Nov 25, 2008
  • Darren Kessinger
    Darren Kessinger Nov 25, 2008
    oh I hate to be the barer or bad news but it is very possible that your CPU is dead.
    Try it with out the cpu in it at all and see if it does the same thing since the power supply will turn the board on and run the fans even without the cpu but that is all it will do...And if the fans spin and stay on without the CPU in it and then turn off again the same after reinstalling it then chances are CPU has problem or possibly one of the capacitors on the motherboard has gone bad see this pic for guide http://systemonenetworking.com/caps.jpg
    have you tried removing the heatsink right away and checking to see if the cpu is warm at all?
    if it is ice cold then chances are it is not working. But when the system barely turns on for a sec then turns right back off allowing the fan to only spin for a few seconds then 9 times out of 10 i have seen it being the CPU that went bad usually from overheat due to dust build up between the can and the heatsink that is usually hidden underneath the fan or a few rare occasions when caps on MB went bad
    But don’t give up yet i would recommend trying these few ideas then if still no lock i will try to help you diagnose it further.
    one more test would be if it is a P4 then try unplugging the 4 wire cpu power plug from the board and see if the fans stay on (and of course the computer will not work without that being plugged in but if it does continue running without it and then does not work the next time after plugging it back in then chances are the one of the capacitors near the cpu have gone bad. and cpu might be fine.
    i hope that all makes sense and is helpful in some way
Does not power on, but lights flash
Hi
Thank you for your query
The clicking noise you are hearing is one of 2 things
1) The CPU fan trying to turn but it cannot, therefore your PC comes on for a short period of time, overheats and switches off
2) The Hard drive is faulty and is causing a short, making the LAptop switch off
Either one will need further inspection by a qualified engineer
Please book laptop into a reputable PC shop for further diagnosis
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 15, 2010 | Dell Latitude C610 Notebook
HP dv6000 Lights up but that's it.
Re : When i press the power button, the lights all light up, the cd rom drive spins for a second and that's it. No fan, No Post, Blank Screen. After a few seconds, it shuts off and then turns back on.
That is generic hardware fault, any faulty device can cause the problem.
The motherboard must be started with a minimal set of devices to troubleshoot.
Start motherboard with only CPU, power adapter connected (faulty battery can cause the problem), heathsink, display and one memory stick. Keep unplugged HD, optical units, keyboard, minipci cards etc.
If problem persists, eventually test the motherboard using a post card(PCI & ISA PC Diagnostic POST CARD MOTHERBOARD TEST CARD) to ensure that new motherboard is not faulty, and then if cpu has not been replaced with the motherboard, replace CPU.
Jul 18, 2009 | HP Pavilion dv6000t Notebook
PC will not power up. No fans, lights, anything.
Have you tried a different power cord? (longshot, I know, but it is one of the variables that you don't mention)
Have you tried a different A/C outlet?
Dec 22, 2009 | Computers & Internet
Green light next to power button stays on - no response from computer, totally frozen for up to 12 hrs, then green light goes off, computer suddenly comes on for 5-10 min then freezes again.
Good day sir, hi, You need a thorough check on your PC.
But first try testing the Motherboard, Processor and Memory module.
As this point you need a friend, that knows how to tinker with your PC
Or you may need to do this.
1. memory testing:
Try replacing a new memory ram module on your PC, get the modules out of the memory slot, and let it be tested on another PC. if good,
2. power supply
Test for the power supply box, remove the 20/24 pin power connector from the mainboard and short the green and any black wire, your fan should blow out air.
3. Test for motherboard.
remove all coonections from the motherboard, except the 20/24 pin power connector, and the 12v 4-pin molex power connector, connect the pc speaker or the thumb speaker on the speaker port, connect a keyboard, clear the CMOS, (or remove the battery temporarily), connect the header panel (power switch, reset, power led) place the processor and memory (the tested good one). power on.
You should hear a beep (good) The keyboard will light up the three leds, then a few seconds, the numlock led.
If you hear 1 long and 2 or 3 short beeps, problem with the display section. Reseat any graphics card. test again.
If you hear continous beeps, reseat the memory, if the beeping persist, replace your motherboard.
If you hear nothing? only fan blowing, replace your motherboard.
I can only give you instructions, you need a someone who knows how to service a PC.
Dec 17, 2009 | Compaq Presario 5000 PC Desktop
My computer will not power on
brand and model of the computer would be good.... as well there is a switch on the back of the computer on the power supply. toggle it to the other position and try again
Robert
Sep 08, 2008 | Dell OptiPlex SX270 PC Desktop
My computer lights
hello,
i assume you know how to open your pc...
Solution (1)
1. make sure your computer is not plugged in
2. open the side panel
3. remove the memory card
4. plug in you computer
5. switch on your pc. you should hear a beep. this is to check whether your pc is still working.
6. unplug pc
7. re-install the memory card. make sure that it is firmly attached to the memory slot.
8. switch on again. this should do it.
else
Solution (2)
Try replacing your power supply unit (PSU). faulty PSU may not be able to supply enough power to your motherboard or other peripherals which is attached to your PC.
hope this post can help you :)
Aug 05, 2008 | Computers & Internet
Gateway gt5648e desktop power
Do you know what your system is having the Processor error if you on the system the keyboard flickers and later go away but the fan also runs for seconds and later went off then what you have to do is to detached all components attached to your system then only the system unit alone .
Use a good power connector cable and a good constructed socket then put it on and wait and hear the sounds it brings and the signals or error is going show then if it comes on and go off remove the fan and replace with new one if the problem persist then change the processor with new one and then your system should be back to life and if anything happened then post your difficulties so i can help you. ok
rate this solution.
Jul 01, 2008 | Gateway GT5408 PC Desktop
Gateway 504GR wont fully poot up
I too had this problem, I had to disconnedct the main power to the PC, give it 30 seconds to bleed any residual capacitor charge and then plugged back in and hit the main power switch and it booted normally.
Jun 27, 2008 | Gateway 500GR PC Desktop
No response from Monitor, Mouse and Keyboard
Definitely a "faulty" motherboard. If fans on PC do not turn, no lights come on and dead screen.
If lights come on, and fans turn, try to reset the BIOS by removing your CMOS (and setting the jumper to clear for about 5 minutes, then put the jumper to normal again) battery for 5 minutes.
Sometimes the bios just "stuffs" up and you'll get no response from your pc at all. So all you do is "CLEAR THE CMOS/BIOS"
Apr 16, 2008 | Dell Dimension 3000 PC Desktop
Power of
This happens because your CPU is overheating, open your PC and blow any dust off the openings and CPU/Power supply fans, if you think one of the fans is not working... replace it.
Jan 24, 2008 | Computers & Internet
Computers & Internet Logo
228 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
