Question about EliteGroup 661GX/800-M (661GX800M7) Motherboard
Can onboard LAN in 661GX-M MB load OS from net?
MB model is 61GX-M.
In BIOS point: first boot device - LAN . Onboard LAN is enable and can work.
There is no booting from network server at fact.
But if LAN in PCI card do it.
Can this M/b do net booting.
  • 177 Answers
Check in the bios settings if there is any LAN Boot ROM option. If yes then enable it. Now you will be able to boot from LAN provided there is Server running which supports PXE
Posted on Nov 25, 2008
Disable onboard video card on dx4870 ub318
enter your Bios then Advanced settings there should be an option to turn of onboard graphics or switch to pci..
Dec 27, 2012 | Gateway Computers & Internet
Just installed a GA-PP67A-UD4-B3 mother board because the GA-P67A-UD4 board was dfective. I am running Windows 7, 64 bit. The new MB was a replacement provided by the manufacturer. Now, the Realtek...
Please enter into the BIOS settings and verify if under Integrated Peripherals the setting for Onboard H/W LAN is Enable. As additional step select SMART LAN and see if it will detect you cable lenght and Etehrnet speed. If Smart Lan do not detect anything or you have a bad onboard LAN or the cable, hub, router has a problem.
If SMART LAN will successfully report back some information it means that the issue must be with Windows 7. If it's the case i suggest to completely remove the network card, reboot and re-install the drivers.
Please let me know if you need additional help.
Mar 19, 2011 | Intel Motherboard
Os loading problem
Press either delete or f2 during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps good luck
Sep 22, 2010 | Intel D915GAG Socket 775 Motherboard -...
ASUS P5KPL-AM SE Motherboard no land card
Make sure you have it Enabled in the Bios (from page 2-17 of the user manual):
2.4.5 Onboard Devices Configuration
Onboard PCIE 10/100M LAN [Enabled]
Allows you to enable or disable the onboard LAN controller.
Configuration options: [Enabled] [Disabled]
LAN Option ROM [Disabled]
Allows you to enable or disable the boot ROM in the onboard LAN controller. This item
appears only when the Onboard LAN item is set to Enabled. Configuration options:
[Disabled] [Enabled]
Sep 08, 2010 | ASUS P5KPL-AM SE Motherboard
I have a IBM thinkcenter 8123 model. I can't install lan due to lac of suitable driver! pls help me!
Go into the bios on your computer and shut down the onboard LAN, find a 3com or realtek LAN card and install it, windows has the drivers build in for most 3com cards, then you go to IBM site, download the drivers you need for the onboard LAN connection, remove the 3com card let the computer boot up, and when it asks for the driver point it to where you downloaded the drivers for the onboard LAN.
Jun 18, 2010 | IBM ThinkCentre M50 8187 Desktop PC -...
I downloaded my ECS 661GX-M2 sound driver but still its not working.what should i do?
go into the bios, and make sure that it has been selected to use onboard sound or onboard audio, if that does not work, and if you have the motherboard manual. look and see if it has motherboard jumper settings to use for the onboard sound. ive noticed also with alot of motherboards the built in soundcards dont perform very well but hopefully this will lead you on the right track!!
Jan 15, 2010 | EliteGroup 661GX-M Motherboard
System unable to boot and showing signs of motherboard audio device conflicts(device type realtek)
hi iasmeer,
-to just boot up without any sound device,
remove any soundcards from the PCI- slots, disable the onboard sound device in the BIOS!
It looks like you are facing IRQ conflicts, your computer cannot handle all the hardware devices installed.
to solve this,
in BIOS set IRQ management so that the BIOS handles the PCI devices(set everything to auto),
disable the plug'n'play-operation system option to prevent windows from doing the same thing again( it'll then just take the IRQ information provided by the BIOS)
now enable the onboard sound device and make sure you have all
the drivers for the onboard devices(sound, LAN-card etc.) fitting your operation system on CD or thumb-drive, boot up and install the drivers.
Restart and by chance everthing isO.K. by now.
if not, please come back with more information on the sound device(onboard or not) and the winversion, so we perhaps can find you the appropriate driver(if you don't have it on the CD you purchased together with the mainboard..?)
Good luck
Sep 07, 2009 | ASUS P5GC-MX FSB1066 Motherboard
PC won't boot if SATA drive connected, drive works fine if plugged afterward
Try Hirens Boot CD. It has a lot of programs on it to detect format etc.
I think your hard drive has a missing or corrupt MBR and it needs to be replaced.
When I have had a hard dive not recognized I hve used Super Fdisk to format and reset hard drive.
On the boot disk
Nov 03, 2008 | ASUS K8N-E Deluxe nVidia nForce3 250...
On board ethernet driver conflict with windows XP
go to the bios settings & there you can disable the onboard LAN ....
so by this you will be able to boot from your hard drive ....
you can go to the bios settings by pressing F2 (or delete key in some PC s ) at the time of the booting (before the OS loads)...
there in bios settings just search for the LAN device & disable it ...
that s all your problem will be solved ....
any doubts reply me
i am always here to assist you
thank you
rate my solution as per your satisfaction
Jul 05, 2008 | ASUS P4C800-E Deluxe Motherboard
848P neo ls
Hi hartterc, there is a bios update for the onboard integrated LAN card. The update, Set "Onboard LAN Boot ROM" to Enabled in BIOS. Bios Version 6.2 Date; 9-02-2006 File size 380KB.
Please allow MSI to run the (Live Update) program on you're system. If you allow this to run you will not need to download & flash you're bios.
That is what MSI states! Click on the link below for Live Updt.
You're mother board 848P Neo-V main web site.
Good Luck!
If you need help with something else, please post you're question here.
May 20, 2008 | MSI 848P Neo-V Motherboard
EliteGroup 661GX/800-M (661GX800M7) Motherboard Logo
233 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
