Question about Canon MX700 Office All-In-One InkJet Printer
Paper jammed this is three times in two days this time the paper wont come out it is jammed
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Nov 25, 2008
The orange light flashes three times and it cant print and there's no paper jam
Did you remember to open the door for the paper to exit? Otherwise, if there's no paper jam check the paper path for debris; the sensor(s) might be gunked up.
Mar 03, 2015 | Canon Office Equipment & Supplies
I have a Laserjet p4014dn printer. it warms normally but once it picks up paper, it jams. i have dried clearing jam several times but on starting to print it jams
Three areas you need to check.1.Pick up area: While pick up roller picking up the paper,delay pick or no pick causes paper jam..
2.Registration assembly area: Once paper picked from the tray, paper leading edge registered by the paper sensor located under the registration assembly.. In case this sensor dusty malfunction or flag damage, paper wont sense. result paper damage..
3.Fusing area. If the paper travels up to fuser area, check paper jammed before entering in fuser(Teflon not rotating properly, replace teflon sleeve) or just crossed?(check paper sensors in fuser unit, clean the sensors & check flags,flag springs.
Aug 31, 2012 | HP P4014DN Laserjet Printer
Printer printed yesterday. Now it will not print and beeps three times.
First of all please check the ink cartridge if the cartridge is OK and secondly check the paper feeder and tray if there is no jam.
Let us know further.
Thanks for joining us. Have a nice day.
Dec 06, 2010 | Dell Office Equipment & Supplies
Paper jam
Dear sir,
i am giving u setp to solved your problem,
Step one: Remove any loose paper.
Step two: Clear the jam from the back of the All-in-One
Step three: Clear the paper jam from the front of the All-in-One Step four: Clear the jam from the automatic document feeder Step five: Print a self-test report Thanks For Your Time,
Apr 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
My Ip90 won't feed paper when I try to print a job.
If the paper does not feed properly it could be due to the follwong causes.
Cause 1 : Inappropriate paper type used
Action : * Check to see if the paper you are printing on is too thick or curled.
* Check if the paper exceeds the load limit mark, if it exceeds, load less paper.
Cause 2 : Paper Feed Roller is dirty.
Action : Follow the steps described below to clean the Paper Feed Rollers.
If envelopes or post cards do not feed properly, even after correctly any paper curl, clean the Paper Feed Roller.
1) Ensure that the printer is turned on and there is no paper loaded in the printer.
2) Hold the RESUME/CANCEL button down and release after the POWER lamp flashed there three times.
The paper roller rotates as it cleans.
3) Repeat this cleaning operation one more time.
4) Load a sheet of plain paper in the printer.
5) Hold the RESUME/CANCEL button down and release after the POWER lamp flashes three times, then feed a sheet of paper.
Cause 3 : Paper jams.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Output Slot Cover, whichever is easier.
* If the paper tears and a piece remains inside the printer, open the Print Head Cover and remove it.
Caution: Be careful not to touch any components inside the printer.
* If you cannot pull the paper out, turn the printer off and turn it on again.
The paper will be ejected automatically.
2) Reload the paper into the printer and press the RESUME/ CANCEL button.
If you cannot remove the paper or if the paper tears inside the printer or if the Paper Jam error continues after removing the paper, contact the Customer care center.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 03, 2009 | Canon PIXMA iP90 Mobile Printer
Power and alarm lamp lit error code e 3 flashes indicating a paper jam but no paper is jammed power flashing green 3 times then stays green and alarm lamp flashers orange three time then gos off over and...
Try a hard reset first - Unplug printer from AC power source for a minutes and from PC. After a minute, reconnect everything and power up and see if it works..
Oct 12, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Paper/tape jam
Get a pair of scissor and cut through the tape. IF it is rapped up too tight where you can't get a pair of scissor through it, then get an exacto knife or razor blade to cut the paper. Just remember not to press too hard so you don't cut through the rubber roller beneath it.
After cutting the paper, then press the paper advance and start taking the pieces of paper out.
Good luck.
If you still have problems, feel free to repost again.
Have a good day.
Mac =)
Mar 25, 2008 | Sharp EL-2196BL Calculator
Printer jams
i suggest that you replace the feed rollers, cleaning them automatically tells you that they are worn.They should be tacky to pick up the paper, not matter what type.
Apr 13, 2007 | HP LaserJet 8150n Printer
Canon MX700 Office All-In-One InkJet Printer Logo
74 people viewed this question
old marine
old marine
