Question about ASUS P5VD2-MX SE Motherboard
P5VD2-MX/P5V-VM DH ASUS Motherboard
Everytime I startup or reboot my PC, I am faced with the "Found new Hardware Wizard" referring to an error in Device manager under "Other devices" where 8 PCI Devices are listed. Running the update driver and searching the net or inserting the motherboard CD does not solve the problem. Please help with a site where I can obtain the latest Windows XP Professional drivers for this motherboard
  • Anonymous Mar 03, 2009
    PC UL NUMI RECUNOASTE NICI UN FEL DE MICROFON SI NU IMI MAI APARE REALTECUL LA BARA DE STARE IN DREAPTA
    President:
  • 1,073 Answers
Http://support.asus.com/download/download.aspx?SLanguage=en-us
Go to ASUS downloadsite, the link above, in the box up to the left where it says "Input model To Search" put in P5VD2-MX, you will now recive 2 MoBos, chose the one you have, press enter, you will now be asked to chose OP, chose XP, all the drivers will now apear for you. Chose them you want, download them and instal them. I recomend you to instal them all since i belive that some of the drivers on your pc is old, thats why you getting that error message.
Good luck
Posted on Nov 25, 2008
E machine error on reboot problem
Two of the most common causes of I/O (Input / Output) device errors are driver based. Typically, either the device's driver is not enabled or it is out of date. The driver component has an important function, as it acts as a motor like force that propels USB/plug-and-play hardware into a driving action within the computer. It is the connecting communicating link signaling the CPU to a desired movement. And while not all I/O device error solutions are simplistic, as a good starting point, you can try troubleshooting using a few basic steps, and you might not need to attempt anything else.
Access "Control Panel" from the Start menu and then choose "Performance and Maintenance." Click "System" and then go to the Hardware tab and click on "Device Manager." Find the device that is registering an error by expanding the nodes of the appropriate category. If the device has a red "X" on the icon next to its description, the hardware is disabled; Otherwise, Go to the General tab and click "Enable Device" found under the Device Status section; then press "OK." (Note: You may have to follow prompts, as indicated through an enabling device wizard. If you do, continue to click "Next" and follow the prompts until the process has completed.) Test the hardware. If an error is shown. Go to the General tab and click "Troubleshoot" found under the Device Status section then press "OK." Follow the prompts to solve the issue. If an error is still shown Go to the Driver tab and click "Update Driver." Follow the prompts until the process has completed and then test the hardware. Hope this helps.
Jan 03, 2013 | E-Machines Computers & Internet
Tip
How to Install Drivers to your computer ?
A device driver refers to a program (software) normally developed by the hardware manufacturer to allow it to interact with the computer system. This driver program is used by the different components and applications in the machine to execute a specific task like printing, DVD reading and writing, or connecting to the Internet among others. Device drivers are generally specific to the underlying Operating System and hardware, which means that the correct version must be installed to ensure proper operation of the supported device. You can do this by either re-installing the original driver for your device or to upgrade to new drivers.
Here are the steps on how to reinstall a device driver:
  1. Log on to your computer as an administrator
  2. Click Start, right-click My Computer, and click Manage
  3. Under System Tools, click Device Manager
  4. In the right pane, expand any of the categories to find the hardware you need to reinstall. Right-click the device, and then click Uninstall
  5. In the Confirm Device Removal dialog box, click the OK button
  6. If you see a message asking if you want to restart your computer, click Yes. You can also manually restart your computer
  7. After the restart, Windows should automatically detect and reinstall the hardware.
Upgrading drivers for pre-existing devices
  1. Open Windows Device Manager. In the Device Manager locate the device you wish to update the drivers for.
  2. Right-click the device and click Properties.
  3. In the Properties window click the Driver tab.
  4. Click the Update Driver button.
  5. In the Hardware Update Wizard point Windows to the location of the updated drivers on your hard disk drive.
  6. Once drivers have been installed, reboot.
After you computer has restarted, Windows will use the previous version of your driver. If you're still having difficulties getting the device to work properly, it's possible you're encountering a hardware issue and not an issue with the drivers. Refer to the troubleshooting steps for your hardware device for additional help and information.
on Jun 22, 2010 | Computers & Internet
Tip
on Apr 19, 2010 | Computers & Internet
My dvd rom is not working becouse an error in driver HPDVDRAM GS30
Optical drives are more forgiving.
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install.
Dec 12, 2012 | HEWLETT-PACKARD HP ENVY 15 Series Notebook...
Gigabyte GV-R925128DE gv-r925128de driver windows 7
Usually go to website of card. They offer drivers for download. Go to "device manager"- find your card. Click on REMOVE THIS DEVICE. Reboot. When rebooting- OS SHOULD recognize NEW HARDWARE WIZARD appears. Found new hardware, if it wants- let go online to update drivers. GOOD LUCK!!
Aug 09, 2011 | Gigabyte RADEON 9250 AGP8X 128MB DVI...
No sound
Try the device manager in windows to see if there are any devices that are missing drivers or are having problems (or even disabled). To get to the device manager in Windows XP, right click on the My Computer icon and choose properties on the pop-up menu.
Click on the hardware tab and click on Device Manager button. Look for any yellow exclamation points or red x's on any of the devices. Also look for unknown devices.
If there are any of the above, correct these first. If not, look for the entry for sound, video and game controllers. Click on the "+" to expand the folder. If you have the drivers for the sound device you have installed, then you can try removing each of the devices under the sound, video and game controllers section. Reboot the machine and reinstall the drivers for your hardware when the "found new hardware wizard" starts.
Dec 17, 2009 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
I have downloaded driver for philips 170c monitor but when i go to zip file there is no driver there
These are the steps you need to follow to install the driver: Download from the link below:
Philips 170c Monitor
It is a zip file so you will need to unzip it into a separate folder. Once the files are unzipped you need to locate the 170C8.inf setup information file. Once you have located that file right click on it and you will see the option to Install. Click that and it will ask you to open it. Choose open.
If that fails you can do the following:
Installing a new device
1.Open Windows Device Manager. In the Device Manager make sure the device you're attempting to install is not already listed from past install attempts. If the device is found highlight it and remove it from Device Manager to prevent any conflicts during the install.
2.Once Device Manager looks ok reboot the computer.
3.As the computer is rebooting an install new hardware wizard should appear if Windows detects the new hardware using this wizard you should be able to point Windows to the folder containing your drivers either on the CD, diskette, or the folder containing the files you downloaded.
If Windows does not detect any new hardware open Control Panel and double-click the Add hardware icon to run the hardware detection wizard. During the steps you will have an option to tell Windows you have a disk containing the drivers for your new hardware device, at this point Windows to the directory containing the drivers for your device.
Once drivers have been installed reboot.
Nov 10, 2009 | Philips 170C4FS 17" LCD Monitor
On my dvd/cd in the device manager there is a ! in yellow how do i fix it help me please
yeah all you have to do on this is on device manager and uninstall the drive....then go to actions and add new hardware...the drive should be back up in device manager or should say that the device installed properly...if it says the drive didn't install then you have a defective drive and it needs to be replaced....if you have a warranty call them as they will cover this issue.
Apr 16, 2009 | Computers & Internet
No sound, will not recognize any driver.
Under hardware manager untinstall the sound device and reboot. When back into windows do not allow the Found New Hardware Wizard to run. Go to HP's Website and download the appropiate sound driver for your system.
Nov 29, 2008 | HP Pavilion ZV5340US Notebook
Acer Crystal Eye Web Cam
try reinstalling your camera driver
Mar 11, 2008 | Computers & Internet
ASUS P5VD2-MX SE Motherboard Logo
4,257 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
