Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Malfunction detected c2557
Urgent
  • waluj Mar 05, 2009
    C2257 CODE IS DISPLAY
  • waluj May 11, 2010
    OUR PROBLEM IS STILL HAPPENING
This is a problem whit the black toner make sure there is toner left and that the cartrigde opens when you insert it in the copier. try to remove the tape covering the tonerpipe on the backside of the toner cartridge.
Posted on Nov 27, 2008
  • ndabam43
    ndabam43 Nov 14, 2014
    can u give me a model of the toner and the specifications
2 Suggested Answers
darck_teck
  • 22 Answers
SOURCE: BizHub 250 Malfunction Code C2557 - HELP!
ok il start by saying that my english is veryyyy bad.
ok so the developer is guarantied for 80000 copies but i seen 200k with a new dev. (developer type dv310) after some of the developer is lost in the copying proses the ac-dc sensor detects that the concentration is rong and it shows the C2557 error thats wen the error is shown by the copier . solving it is simple you can replace the dev. and run F8 mode if it dosent work manually ajust the acdc to a lower value (lower value means that is les tonner in the dev. hyer value more tonner obviously ) , 0r leave the old dev. in it and ajut the acdc to about 180 (you can ajust to 180 take out the tonner botle make some black copies(30) and put back the tonner bottle and adjust to a lower value that works) . The problem can also apear if the copier docent supply tonner so check that first . Entering the service menu is simple pres utility > (toch screen) original size> (kepad) stop>0>0>stop>0>1 the password from the manufacturer is 00000000 , in the service menu select tech mode in ther yowl find the different start modes F8,F... , and you have printer select printer and acdc adjustment , pres C to clear the value and via keypad enter the desired value . THE REST IS UP TU YOU MY FRIEND . CAUTION IF YOU DONT HAVE ANY IDEA ABOUT A LASER COPIER DONT EVEN ENTER THE SERVICE MODE CAUSE YOU CAN DO MENY WRONGS IN THE COPIER . GOOD LUCK
Posted on Nov 10, 2009
Solution for konica minolta 250 malfuncion detected c2557
C2557 for Toner Density Control abnormality in Developer.
Try in this sequence..
1-Check Toner, if Empty, Reset code and install new toner bottle.
2- if not from above, Then replace Developer and Developing Unit.
3-if Not, then check Hopper Unit, Clean Sensor and Solenoid.
Jul 19, 2017 | Konica Minolta Office Equipment & Supplies
Malfunction detected pls call your technical represenative C2557
What is your Make or Brand and the model of your machine?....Steve
Aug 18, 2015 | Office Equipment & Supplies
Why am i getting a C2557 malfunction error on my Konica 4068
Drum and developer need to be replaced. Along with clearing required counters and the F8 procedure ran
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 05, 2015 | Konica Minolta bizhub Office Equipment &...
Code eror bizhub c252
Code: C2557 Code C2557 Description Abnormally low toner density detected Black TCR Sensor
• TC ratio in the developing machine, which is determined by Toner replenishing amount control mechanism, is 5 % or less for a given number of times consecutively. Remedy 1 Perform image troubleshooting procedure if image density is low. 2 Clean the TCR Sensor window on the underside of the Imaging Unit if dirty 3 M7 operation check PWB-M CNDM3-10 to 13 C-21 4 Reinstall Imaging Unit. 5 Change Imaging Unit /K. 6 Change PWB-M. 7 Change PWB-MFP.
Feb 01, 2015 | Office Equipment & Supplies
Error code 2557
C2557: Abnormally low toner density detected black TCR sensor.
Detailed Error code explained below.
Possiable solutions.
* Open and close the front toner door.
* Restart the machine by turning off the LCD screen power switch, then by the main body switch located behind the access panel above tray 1 indicator light.
* Call Konica to get a tech out.
C2557 Abnormally low toner
TCR sensor
• When sampling data is determined in TC
ratio calculation control, TCR sensor output
is higher than a predetermined value for a
predetermined number of times in a row
even though there is toner in the sub hopper.
Feb 19, 2014 | Konica Minolta Bizhub C550
Errorc2557
It is my pleasure to guide you.
Konica Minolta 250 Error C2557 is Toner Density sensor problem
Problem: code C2557 - Abnormally low toner density detected Black TCR Sensor
Sounds like something a technician should take care of. Most of the information I could obtain says that the
Solution: Replaced 4038-R729-00 Hopper Drive Assy (C250 part compatible with C252 )
Good luck and please post back that you are successful, giving thumbs up, or if I can be more helpful.
Jun 13, 2011 | Konica Minolta bizhub C250 All-In-One...
Malfunction is detected c2557
Entering the service menu is simple pres utility > (touch screen) original size> (kepad) stop>0>0>stop>0>1 the password from the manufacturer is 00000000 , in the service menu select tech mode in ther yowl find the different start modes F8,F... , and you have printer select printer and acdc adjustment , pres C to clear the value and via keypad enter the desired value .
Feb 04, 2011 | Konica Minolta bizhub 250 All-In-One Laser...
My Minolta Bizhub-200 prntr. has a C2557 error code. How do I clear it?
moz-screenshot.pngmoz-screenshot-1.pngC2557 - Abnormally toner detected black tcr sensor.
Reinstall image unit black
Reinstall toner cartridge
Change Image unit
Change toner carridge.
Jan 09, 2010 | Konica Minolta Bizhub-200 Minolta Printer
My NEC IT 2530 copier machine is coming up with an malfunction detected call for service C2557. I need to get the copier machine working.
C2557= ATDC sensor failure.
Did you run the machine out of toner? Or if you or a service tech recently replaced the developer then you need to perform the F8 adjustment in the service mode. Either way you will need a service technician.
Oct 20, 2009 | Office Equipment & Supplies
I can even reach the "service mode".
The screen shows the error (c2557) and I can not access to anyother function.
Nov 11, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
1,047 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
