Question about Hoover Washing Machines
Hoover 1300 washing machine door wont open - Hoover Washing Machines
  • white28broom Nov 25, 2008
    eventually door did open after several attempts no water in machine
  • Hoover Master
  • 3,463 Answers
Hi.
The door will not normally open if there is water left in the m.c. check pump, and make sure the belt is o/k, as some hoovers do not let you open the door if the belt has come off. Please leave feedback.
Thanks.
Posted on Nov 25, 2008
  • Barry Coates
    Barry Coates Nov 25, 2008
    Could still be caused by water left in m/c
    Even though it is not visible it can cause a problem
    If it does it again, lay drain hose down into a shallow container and see how much water runs out, if there is a substantial amount ,then that is your problem. Check pump, and or filter.
  • Lynne
    Lynne Jun 13, 2014
    Thank you but it did not help
How can I open the door on hoover Quattro washing machine.
if its a front loader remove lid and plug u can get the door open from top with a long screw driver and a bit of patiace
Mar 01, 2015 | Hoover Washing Machines
My hoover dynamic wash 7+ door indicator flashes in spite of door being closed properly and machine wont start
the door interlock has failed and needs too be replaced
you can find this easily changed out part on ebay or from spares suppliers
you usually need to take the top off the machine
power off and open the door and remove the two screws at the lock
reach down and take out the interlock mecha
plug in a new one and put it back and screw it back on
very easy...
Feb 08, 2015 | Hoover Washing Machines
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Door wont open
plz put the model of your hoover washing machine and if there is an error appear on the display
Feb 06, 2013 | Hoover Washing Machines
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Apr 24, 2011 | Hoover Washing Machines
Hoover Washing M/C Door Jammed
we had the same problem on ours, a techy came out to it and hit the washer above and the the right of the door handle, and hey presto the door opened, have done this myself since, works everytime
Nov 03, 2008 | Hoover AAA160 Front Load Washer
Hoover performa 1300 door latch
my hover performa 1100 door latch will not open can anyone help
Sep 04, 2008 | Washing Machines
Hoover Washing Machine Door wont open. Please help the door opener feels slack! How do I get it to open. Its a hoover nextra. Thanks Lisa
Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Aug 05, 2008 | Hoover Washing Machines
HOOVER LOGIC 1300
you need to access your drain pump and check it for an obstruction but when you pull the hose off keep in mind it might have a lot of water in it i usually use a shop vac and pull all the water out through the drain hose before removing the hose or opening the pump sorry i cant be more specific but ive never cleaned the pump on a hoover
Mar 23, 2008 | Hoover AAA140 Front Load Washer
hi there this is a common fault you will need to replace the control module and selector switch/timer
Dec 01, 2007 | Hoover H130E Front Load Washer
Washing Machines Logo
595 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
