Water is not coming out hot enough for coffe or tea from my tefal quick cup
  • 833 Answers
I'm assuming that you've mis-classified your question.  If you have a one cup water heating unit, put a mixture of half vinegar and half water into the unit.  Turn it on and heat it.  Leave over night and then rinse out thoroughly.  This will break up and remove any lime scale.
Posted on Nov 26, 2008
  • 306 Answers
It won't be hot it's like tap water. Did you see the drain for the furnace?
Won"t brew the coffe right and hot water coming
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
Jul 22, 2011 | Keurig Platinum B70 Coffee Maker
Tefal quick cup kettle water coming out in slow spurts,have changed filter but no improvement.
If you are in a hard water area you may need to descale the heater element. Try adding 1 cup vinegar to 3 cups water and run the machine should clear up the scale. Rinse thoroughly before use.
Sep 12, 2010 | Tefal Kitchen Appliances - Others
Hello tefal quick cup water is no longer hot only
we had to return our first one for the same problem Gavin. Tefal (surprise surprise) claimed that nobody else had EVER had that problem. 2 years down the track though, and i've discovered that mine turns itself on at random intervals, and floods the kitchen bench. My advice - get a refund while you still can...
Mar 03, 2010 | Tefal Kitchen Appliances - Others
Tefal quick cup
Press the Hot and Cold button for 3 seconds,
The red indicator light will start to blink,
Release the hot and cold buttons and while the red is still blinking, press the and hold the hold water button, Once the desired amount of hot water is reached release the hot water button.
Now press and hold the hot and cold water buttons simultaneously for about 3 seconds.
The red light will stop blinking to the end of the programming.
Repeat the process for the cup quanity selector for the cold water.
------------------------------------The end -------------------------------------------
Feb 28, 2009 | Tefal Kitchen Appliances - Others
Tefal quick cup- no longer heats water well
press red button 4 times quickly should reset & poor between 85- 92 deg
Jan 31, 2009 | GPS
Tefal Quick Cup
ALERT :- Tefal Quick Cup can TURN IT SELF ON. Tefal know about this but it is a potential fire hazard. Mine turned itself on and dispensed the water reservoir over my kitchen. Dread to think if I had been out shopping what could have happened. Tefal know about this problem but are not doing anything to advertise the fault!!
Jan 19, 2009 | Kitchen Appliances - Others
Tefal Quick Cup not heating water
press the hot button on off 5 times and on the 6th let it run a cup full. This will re set the temperature
Dec 15, 2008 | Kitchen Appliances - Others
Problem with tefal quick cup, has started to mix hot and cold water when you try to get a cup of hot water
Very strange problem for an air conditioner. I think you've posted this is the wrong category.
Jul 27, 2008 | Heating & Cooling
Water is not hot enough for tea
Try using the cup heater to warm the cup before hand. Use a thermometer to measure the temp of the water coming out. If it doesn't reach 80 degrees, then the thermostat may need to be replaced.
Dec 14, 2007 | Saeco Royal Professional Espresso Machine
Keurig Special Edition B60
I assume your coffe maker used to produce more coffee for each use. Roughly 6 ounces per large cup, and now is only making 3 oz. cups.
If your coffee maker is sputtering and not able to "suck" enough water to fill your cups of coffee it is most likely due to cavitation caused in the little pump due to a stoppage, which is most likely lime or scale buildup somewhere in the pump line.
To fix it, don't take your coffee maker apart. Get a bottle of distilled white vinegar, and pour it straight into the empty water resevoir. Press brew with no coffee pod so you are just running the vinegar through the system. Pour the vinegar out of the cup and back into the resevoir. Add some ice to cool it off. Repeat about 10 times. This should clear out the toughest lime scale clog.
After you notice the cups are filling full of water, Replace the vinegar with fresh water. Run about 5 or 6 cups of fresh water through the system to get rid of the vinegar.
Make coffee/tea/whatever.
Oct 06, 2007 | Keurig Special Edition B60 Coffee Maker
Heating & Cooling Logo
210 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
