Question about LG GSA-2166D DVD RW Dual Layer Burner
Problem installing the device,keeps restarting the pc
When i plug in the device and it shows the 'found new hardware' in the tray it suddenly switches off the pc and restarts and repeats that while it's plugged.I tried plugging the device while the pc is off or like a plug-and-play device or even in different usb ports but it made no difference.I even downloaded service pack 1 in case of a problem with the usb drivers but still makes the same.I have windows xp.Does anybody has any idea of what i can do?
  • Mar Meti Jan 03, 2007
    i installed service pack 2 and the drivers and then connected the writer but still the same problem...
    President:
  • 2,961 Answers
You will probably have to install Service pack 2 to overcome this problem, which you should install for security reasons anyway. If a driver came with the DVD writer, this should generally be installed first, then the writer connected into a USB port.
Posted on Jan 03, 2007
  • andrew pester
    andrew pester Jan 03, 2007
    It must either be a faulty drive or your motherboard is not able to supply the required amount of voltage to the usb port, deending on how many peripherals are used and the output of your power supply or conflicing with another peice of software driver.
    Try the drive in another persons pc to eliminate hardware failure.
SOURCE:
My dvd rom is not working becouse an error in driver HPDVDRAM GS30
Optical drives are more forgiving.
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install.
Dec 12, 2012 | HEWLETT-PACKARD HP ENVY 15 Series Notebook...
I was using winXp & vista before win 7 ultimate, now when i am going to install bluetooth driver the massage is bluetooth device not found. please give me solution soon
first attach the Bluetooth to the computer and restart the computer when it shows new hardware found so it automatically scan for driver from system If it found the drivers already in the windows so it run you device if it not found the driver so it ask form you to install the drivers and if is not showing any hardware so go to the control panel and click on add hardware
Aug 04, 2011 | Computers & Internet
Can not Find in "My Computer" the DVD RW and DVD
Are the power and data cables plugged in from the DVD-RW to the PC?
If cables are plugged in ans secure, download the driver and install it on your PC. You might need to restart after that.
http://www.liteonit.com/DOWNLOADS/ODD/SOHW-1673S/firmware/JS0DN.exe
Mar 04, 2011 | Lite On DVD+/-RW LITEON SOHW-1673S BLK RT...
Windows xp says no drivers for this device
hi try this ... if you are installing a new device it is recommended that you install the software first then restart your pc and plug/connect your device !then go to Start,control panel , add hardware follow the on screen instructions add new hardware /yes i have connected the new hardware( then if you cant find the new hardware) just choose/ add new hardware device /search and install automatically !it should find the files for it to install properly
please rate this if found useful , many thanks it only takes 1 second
Dec 21, 2010 | Computers & Internet
I just had it from the shop and when I try to install the WD SmartWare Software, a pop up window apears saying "Windows can not find C:\ Program Files (x86)\ Western Digital\ WD SmartWare\ Front Parlor\ WD...
restart the PC, do not plug the device. now insert the software disk in CD rom. Plug in the device. lower right tray, toy will see found new hardware. now doubble click on it and then start installing diver from the CD rom by clicking and pointing next inside the intall hardware pop up menu. after installation, it will ask for restart. do it and then it should work.
cheers!
Sep 08, 2010 | Western Digital My Passport Essential SE...
I have windows XP. I bought a logitech quickam.
plug the web cam
insert your cd drive
go to control Panel
Add remove Hardware
click next
check yes I have Already connected the hardware.
click add new hardware device.
search for new hardware automatically.
Mar 06, 2010 | Logitech Webcam
Cannot scan documents
go to device manager look for imaging device (scanner) right click and uninstall. / click scan for hardware changes tab, found new hardware must be appeared and click next / select don't search, i will choose the driver to install / click show compatible hardware and choose scanner driver found and click next. and finish.
Feb 11, 2010 | Fujitsu M3091DC Path-Through Scanner
Installation of p3005
DOWNLOAD SHOW MY PC AND PLUG THE PRINTER AND IT WILL SHOW NEW HARD WARE FOUND AND PUT THE CD AND SEARCH AUTOMATICALLY OR MANUALLY UR DOING SELECT THE SOURCE FIND FROM CD. AND CLICK NEXT IT WILL SHOW THE MODELS AND CLICK NEXT CLICK CONTINUE ANY WAY AND AFTER COMPLETION RESTARTS.
AND GO TO CONTROL PANEL AND ADD HARDWARE SEARCH FOR NEW HARDWARE ATTACHED YOUR COMPUTER AND I HAD ALREADY CONNECTED THE DEVICE IT WILL SHOW THE DEVICE PRINTER MODEL CLICK AND PRESS OK AND SOLVE.
Jun 09, 2009 | HP xw4600 Workstation Linux Installer...
Webcam = Not working
When you installed the drivers, did you do so after loggin in as ADMINISTRATOR?? This is vital otherwise it will not work. Also a quote from the manual goes like this quote -"Exit the “Found New Hardware Wizard” by hitting the cancel button. Unplug the VGA webcam
from the USB. Insert the software CD into the drive tray. Follow the software installation
instructions. Once all software is installed (direct X, HP Web Cam drivers, ArcSoft
VideoImpression, ArcSoft Photo Impression), close the HP Webcam window and RESTART the
PC. After restarting the PC, plug in the VGA Webcam and run ArcSoft Video Impression to
capture a new video." unquote.
Hope this helps..................sodeep
Apr 30, 2009 | Computers & Internet
LG GSA-2166D DVD RW Dual Layer Burner Logo
69 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
