Question about Sharp Office Equipment & Supplies
I HAVE AN ERROR CODE L6 ON A SHARP AR-163 PDIGITAL IMAGER.
  • 25 Answers
L6 is a problem in the laser sistem. The polygon motor doesn't work. It is reparable if you can get it out of the machine to open it and lubricate it. If it doesn't get ok it can be changed, just the motor and the small printing board. GOOD LUCK.
Posted on Dec 01, 2008
I am getting on sharp 5320 copier L6 and E7 codes
L6 - Polygon motor lock detection
E7 01 Duplex model memory error/ Image data error
02 LSU trouble
06 Image data decode error
10 Shading trouble (Black correction)
11 Shading trouble (White correction)
16 Abnormal laser output
F2 02 Toner supply abnormality
Mar 13, 2011 | Sharp AR-5320 Black and White Copier
ERROR CODE L6 - HELP PLEASE, THAN KS
L6 in Sharp copiers stands for main drive problem. In this case scenario it is probably the main motor or a link to it like the drive brd.
Feb 23, 2011 | Sharp AR 163 Copier
My sharp AR-5316 is displaying an error code L6. please what could be the possible fault and solution. mzm from dubai
Error code L6: Polygon motor lock trouble Details : The polygon motor does not rotate. Possible Cause :
  1. Polygon motor unit failure
  2. Polygon motor connection harness trouble
or disconnection
  1. MCU PWB failure
Solution:
  1. Replace the polygon motor.
  2. Replace the MCU PWB.
Oct 14, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-163 Copier, How to Reset/Solve the error Code U2-40
how to clear red sing on tonal problem for sharp ar 163
Sep 16, 2010 | Sharp AR 163 Copier
Sharpe ar-163 with error code u-240
Hello sir; The error code you display is CRUM communication error.
Feb 05, 2010 | Sharp AR 163 Copier
Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Aug 19, 2009 | Sharp AR-M205 Copier
Sharp AR 163 display L6 error
The error is for the polygon motor if you have done the test for the motor and it doesnt work I think thereis the answer because they spin so fast the motors will eventually go if it had been a little noisy p[rior to this then it has a read or seize error if you know how to take it out youcan manually gently spin it to see if it is stuck just make sure you use a clean dry cloth to cover it prior to turn as you might mark the mirrors.. Good Luck A
Jul 01, 2009 | Sharp AR 163 Copier
I HAVE AN ERROR CODE L6 ON A SHARP AR-163 PDIGITAL IMAGER. WHAT IS CAUSING THIS ERROR AND CAN IT BE REPAIRED IN-HOUSE?
Apr 18, 2008 | Sharp AR-M160 Laser Printer
Sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
94 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
