Question about HP Computers & Internet
Flickering screen on laptop - HP Computers & Internet
  • Nick Sharp May 11, 2010
    when the screen flickers do you mean it goes from being on to off so to speak, and if so when the screen is "off" can you see anything on the screen if you say shine a torch up to it.
    If this is the case it could be a problem with the backlight on the panel.
  • tekdj May 11, 2010
    What type of laptop and has any water or damage occurred? THanks
Try left clicking on desktop screen, go to properties, then to settings, then click advanced settings and reset your monitor refresh rate to 60hz.
Good luck.
Posted on Dec 03, 2008
Hp g6000 screen
Please explain the events that lead up to your screen flickering ... in detail, from the time you turn the laptop on. Does the splash screen flicker?
Sep 07, 2013 | Computers & Internet
Lg r405 laptop screen flickering
most likely a loose connection if it is flickering.. if there are red squiggly lines usually means driver issue.. and if there are blue banding lines, typically means the chip is overheating/desoldering.
Mar 07, 2013 | LG R405 LAPTOP LCD SCREEN 14.1" WXGA CCFL...
Upper sise of screen flickering problem
Technology b> A laptop's display assembly consists of an LCD panel, an inverter board and a backlight lamp. The inverter board supplies power to the lamp which lights up the LCD screen as it generates images. Light from the lamp is then uniformly distributed over the panel to create images. b> Cause b> Flickering is commonly caused by a damaged or malfunctioning inverter. Because a faulty inverter is not able to supply adequate power to the backlight lamp, the screen goes dim each time the backlight loses power. In some cases, flickering may also be caused by a faulty connection between the inverter and backlight lamp. Diagnosis b> Resolving a laptop screen's flickering problem entails correctly diagnosing the problem and replacing the faulty component. You may diagnose the problem by hooking up the laptop to an external display unit, such as a projector. If the external display has the same display problem as the laptop's LCD screen, it is indicative of a motherboard or video card problem. If the external unit displays bright, crisp images, the problem is probably caused by the backlight or inverter. b> Solution b> You may repair a laptop screen's flickering problem by replacing the inverter board or backlight. Order parts from a trusted supplier and replace the component by referring to your product documentation. b> Hope this helps.
Jan 21, 2013 | Lenovo IdeaPad S300 59359327 Silver Gray...
Lenovo PC screen is flickering, how to solve it
u can take it to a fixer bcause its flickering bcause there is a connection between the whole set and the screen which must be disturbed
Jul 24, 2012 | Computers & Internet
Screen flickering
it sounds like the backlight inverter is on the way out. if the laptop is under warnty get it back to the shop and get it send away for a new screen
Jul 17, 2010 | Dell Vostro 1510 Laptop
The screen flickers periodically without any reason. If i giggle the screen or pull the screen down the up it staops.
The flickering happens because the flex of your laptop is getting weak.
The flex connects the screen of a laptop to the motherboard it is through it that data is passed to the screen.
It is found in all laptops and the more you open and close the laptop,it gets weaker and weaker.
The best thing to do to stop the flickering is to change the flex.You can also loose the laptop,remove the flex and fix it back properly but that may not stop the flickering permanently.
Note;if you cant loose the laptop yourself please get an expert to do it for you
Thank you for visiting fixya
Mar 12, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
How to solve laptop nx7300 screen flickering
sir try un-installed your video card then install angain.
Feb 22, 2010 | HP Compaq nx7300 Notebook
Flickering of the screen
just open the system and reseat the display cable...
Sep 20, 2009 | Acer Extensa 5420-5687 Notebook
Acer Laptop Screen Flickering
The flickering screen indicates that it is a backlight problem with either a faulty inverter or inverter connection problem. The inverter is usually located at the bottom edge of the LCD screen, and may have one or two connectors (one for the video info. and one for the inverter power or a combined connector) attached to the motherboard under the case near the top edge of the keyboard near the hinges. Reseating these connectors may solve your problem.
Jan 29, 2009 | Computers & Internet
My laptop screen is flickering
That could be ths connector that connect the LCD to the Motherboard in the laptop. Ive seen something similiar wherein i took down the screen, cleaned up the connectors and it worked like new...... for a few weeks then it went back and started he flickering again. We finally fixed the problem by replacing the screen. Apparently the connector behind the screen was giving trouble. Have someone check the cable from your LCD to the board but I think you might need to fix the connector or replace the LCD screen. Regards, babb
Apr 19, 2007 | Evesham Voyager 5800 Notebook
Computers & Internet Logo
194 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
