The connection that i use is VODAFONE.
If you mobile displays Restriction Code, then it is locked with some network and requires a code to be entered, to allow your mobile to use any network. Restriction code for your Nokia 3110c model mobile can be got at Unlocking4u.com which gives easy instructions to unlock your mobile.
SOURCE: nokia 6300,vodafone help with restriction code please
i got a nokia 6300 from england and i want the restriction for it to be used in jamaica
SOURCE: restriction code for nokia 6300 locked in fido
The security code, if you did not change it is mentioned in the user manual book. For Nokia cell phone, it is usually 12345.
This is the code the phone asked you to enter when you change your SIM card.
The code only asked once for every SIM card, unless you reset your phone. To disable this code, enter menu settings, Security, Security Level, change it to memory or none. To change this you need the security code.
SOURCE: REstriction code nokia 3220
Model: Nokia (3220 )
IMEI: 353779008244461
Network: 23415000
#pw+097 493 313 556 102+1#
#pw+792 500 312 007 110+2#
#pw+895 541 216 367 057+3#
#pw+246 345 562 465 151+4#
#pw+717 590 336 507 307+5#
#pw+743 510 762 137 125+6#
#pw+116 194 130 403 305+7#
SOURCE: Nokia 6300 Australia Vodafone requesting restriction code
Handset Unlock - Instructions
Please find below the instructions to unlock your handset.
Handset Unlock Procedure for IMEI:
353508029865248
Your unlock code is:
426850229882845
Manufacturer/Model:
Nokia_6300
Nokia 6300
PHONE UNLOCK PROCEDURE
PLEASE READ THE INSTRUCTIONS CAREFULLY BEFORE YOU ATTEMPT ANY
UNLOCK PROCESS
This procedure unlocks the handset from being network restricted from only
using SIM cards from Vodafone Australia. In
case of difficulties, please refer to the FAQ listed below
1.
Take note of the unlocking code shown above
2.
Insert a Non-Vodafone Australia working
SIM card.
3.
Ensure the phone is charged and then switch the phone
on.
4.
Optional
Step: If the SIM card has a PIN, enter your PIN number. (See FAQ below)
5.
The phone will then display a message. The most common
is “Phone
Restricted”. Select
“undo” by pressing the middle
soft-key button. (Different message? See FAQ below)
6.
Carefully read step 6 before
attempting to enter the unlock code. This step has the potential to PERMANENTLY
BLOCK YOUR PHONE!
Enter into the phone #pw+ followed
by the 15-digit unlocking code then +1#
(Unlocking code is shown above). Do not
enter the 15-digit IMEI number by
mistake
To enter +
press the * (star) key two times
To enter p
press the * (star) key three times
To enter w
press the * (star) key four times
For Example: If your 15-digit unlocking code is 123456789012345, enter the following in
sequence: #pw+12456789012345+1#
(When entering the unlocking sequence it
disappears? See the FAQ below)
7.
Then press “OK”
8.
The handset will display “Phone
restriction off”
unlocked after successful entry of the unlocking code. This will be confirmed if
you can make and receive calls with the Non-Vodafone Australia
SIM card. (You will need reception and phone
credit with the different network provider)
SOURCE: restriction code for nokia 6070
nokia 6070 cellular Phone. IMI NO 351881/01/692838/205398398.MADE IN HUNGARY.PLESE SEND RESTRICTION CODE AT MY ID [email protected].
