Question about Canon BJC 4300 InkJet Printer
Green light flashing
I have a printer that has its light flashing green and isn't responding to the computer. When turned on the cartridges do a clean then stop in the middle of the printer as if I am going to remove them. When I press the green cartridge button to return the printer head to the right-hand side, it just stays still and beeps at me. What do I do???? I have already updated the driver, removed the plug?? Help!
  • 1 more comment
  • Anonymous Mar 16, 2008
    When i turn my cannon bjc 4300 printer on i get one bleep and the green light stars to fash continously. I cant perform any tasks like cleaning etc. The cartridge holder stays in the centre of the printer and not on the right as it should. I cant get any help from anyone so i would appreciate any help.Thanks
  • Anonymous May 25, 2008
    sience installinh sp3
  • Anonymous Jul 07, 2008
    The light is flashing green, and the cartridge stops in the middle. The printer doesn't respond to the computer which shows error in the printer.
    What is wrong with my printer?
The print head is toast. Replace it.
Posted on Sep 09, 2008
    President:
  • 2,961 Answers
To pin it down to a hardware fault, you may need to remove the printer from the usb port, uninstall driver and re start pc. Check your printer and faxes folder to make sur there are no other canon printers listed, if so delete. Re install printer driver, then when prompted connect printer to a different usb port and see if windows recognises your printer and is installed ready to use. Try again and if the same problem you know it's the printer thats faulty
Posted on Jan 03, 2007
SOURCE:
Red and green lights flashing, won't print or respond to commands. Problem started when cleaning heads and subsequently testing with the print pattern. Monitor says a general printing error and suggests...
The heads are clogged. Unplug the printer remove the cartridges and dump them (never use the same brand of it or the same ink),pour some cleaning fluid there and leave it to soak. If you have some empty cartridges fill them with cleaning fluid and use them.
Oct 04, 2009 | Epson Stylus Photo 1290 InkJet Printer
My samsung ML2010 printer has Error button flashing green
your printer is not inisilize properly. it is a logic card problem.so pls you can repaired it from printer vendor.
Sep 02, 2009 | Samsung ML 2010 Laser Printer
Epson Stylus CX3600 error
remove the cartridges then, the press and hold all the available buttons on your printer where it could cause a machine resetting...
you could also remove the cartridges then wipe the circuitry of the cartridge... (the gold-like connector)
then turn off your printer without putting back the cartridges... (leave it turned off for 5 minuets)
turn your printer on then it should be ok
(post back if it doesn't work)
Jul 07, 2009 | Office Equipment & Supplies
Canon Pixma iP2000 wont print black ink?
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Jun 02, 2009 | Canon PIXMA iP2000 InkJet Printer
Printed pages come out blank
Hello please try this
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Jun 01, 2009 | Canon BubbleJet i550 InkJet Printer
GReen light keeps flashing and my printer wont print
two options
1)either any of the printer cartridge is faulty.remove the cartridge and clean it with tissue paper.
2)or the printouts are pending in printque.delete all the printouts and then try .
any one of the above options will solve the problem.
if cleaning the cartridge does not solve that means it faulty so replacement of cartridge is necessary.
Apr 01, 2009 | HP Deskjet D2360 InkJet Printer
BJC55 Printer not printing
There are some possibilities due to the above phenomena. Let's discuss about it:
1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
Hope these help.
YBC (/\)
Nov 01, 2008 | Canon BJC 55 InkJet Printer
Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
Power & Yellow Resume Button flashing constantly & will not print
Ok please try
1. Turn off printer
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon i560 printer
I have similar problem. I found this solution that may help you. My problem insists tho.
>>> 5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
May 28, 2008 | Canon BubbleJet i560 InkJet Printer
Canon BJC 4300 InkJet Printer Logo
193 people viewed this question
Clive
Clive
old marine
old marine
