Question about Canon MultiPASS C3000 All-In-One InkJet Printer
Printer Driver and Manual for a Canon MultiPass C3000
My operating systmen is Windows ME. I can't find the driver for the printer. Also, I know I got a printer manual for this device from the Canon website about 4 months ago, but I lost the link to it and canon.com doesn't list it. I don't have the software for the drivers. I bought it used, cleaned it up and have been using it for copying and it works great! Now that I have a PC, I'd really like to use its full potential. Thanks
  • 3 more comments
  • John Colby Jan 05, 2007
    "Sandrew" Thank You for you assistance with trying to find a printer driver for my Cannon Multipass C3000. I haven't arrived at a solution yet, but I DO have the driver now, plus the manual which requires Adobe to read, which I also downloaded. Looks like I have some reading to do. The Installation wizard is looking for a .inf file which this .exe and the manual file does not have. I don't mind the hassle or the time I'm taking to get to the resolution. Eventually I hope to have this printer/copier and fax combo doing all three. I bought it for $5.00 U.S. at a thrift store, then cleaned some of the rollers, bought a cartridge and watched as copies started to come out better and better. It had a continuous thin black line running vertically down each page, but that seems to have cleared itself up on its own. I will let you know the eventual outcome. Regardless though, I still have an excellent copier that I use all the time, at less than a fire sale price. Plus a fax. God Save The Queen
  • John Colby Jan 07, 2007
    SSSANDREW:
    We're making progress!!! Not quite all the way "there" but tantalizingly close. I've got the Mulitpass Desktop Manager running in the "background" now when I start up Your instructions were right on target. So, the driver is loaded and ready for an "experience" with the printer, but this is what I get:
    The Multipass hardware could not be initialized.
    the connected device may not be the same as the Multipass device that was installed.....
    I've changed out the parallel cable to the printer, turned the printer off then on, printed out the USER'S DATA LIST which, to me doesn't have any relevant data (but surprisingly does have the correct date and time - must have a good battery), created a directory with subdirectory, printed to file in additon to printer and now have a maternity ward of 5 more baby MultiPass icons in my printer directory. Thankfully, the check mark identifies the father. I also have the manual now which I can download with Adobe, but like most real users, they make good door stops if they're hardcopied, because we're functionally illegitimate when it comes to instructions in thick volumes.
    The desk top manager is for an older version of Windows, of course, and for older software, because I don't have an "export" option in Word. I remember those though. Especially in Lotus 1-2-3. The help file in Word for Export isn't what's needed.
    I've got a thrift store rug and am wondering if it would be appropriate to use as a prayer mat?
    Which way is Mecca from 12th & I Street in Sacramento?
    Call me Hardy (Coletti)
    I'm on America's Least Wanted List and don't like to tell.
    Hardy
  • John Colby Jan 08, 2007
    SANDREW:
    Here's the results of the Multipass Diagnostics. I DID follow your link. Everything is set up OK as far as I can tell, except for this:
    10:18:08 Start of test.
    10:18:08 MultiPASS Diagnostics version 1.03.
    10:18:09 Start of test.
    10:18:09
    10:18:09 Windows Version...
    10:18:09 Checks Microsoft Windows version and mode.
    10:18:09 Windows version 3.95.
    10:18:09 Windows Version OK.
    10:18:09
    10:18:09 Port Assignment...
    10:18:09 Checks LPT assignment for MultiPASS.
    10:18:09 BIOS reports system has 3 parallel port(s).
    10:18:09 MultiPASS is configured to use LPT1.
    10:18:09 MPDIAG reports system has 1 physical parallel port(s).
    10:18:09 BIOS and MPDIAG report different parallel port counts.
    10:18:09 Port assignment OK.
    10:18:09
    10:18:09 Driver/Software Installation...
    10:18:09 Checks if parallel port driver software is installed and can be loaded.
    10:18:09 Parallel protocol VxD loaded.
    10:18:09 Software Installation OK.
    10:18:09
    10:18:09 Software Versions...
    10:18:09 Checks parallel port driver software versions.
    10:18:09 CIS1284.DLL, Parallel Port Service Provider DLL, v2.58Sx
    10:18:09 CIS1284.386, Virtual Bi-directional Parallel Port Device, v2.31
    10:18:09 Software installation id: MultiPASS CFX-L4500IF.
    10:18:09 Software versions OK.
    10:18:09
    10:18:09 Attempting to "open" parallel port.
    10:18:09 Attempt to "open" parallel port failed.
    10:18:13 End of test.
    I'm not sure if you got my last transmit so here goes. I'm pretty sure the problem isn't with the Multipass setup installation, but port assignment, but I ain't that smart:
    10:18:09
    10:18:09
    10:18:09
    10:18:09
    10:18:09
  • jessica_22 Oct 16, 2008
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    MY HP LAZER JET III printer isn’t printing at
    all. The computer indicates that the “device isn’t LPT1 ready”. WHEN I perform a
    service self test on the printer and it prints the vertical lines with no
    problems. The front panel self test doesn’t work, however which component do
    you suspect is giving you the problem?
    Problem Solver:
  • 9 Answers
Yedya gandichya driver cd sambhalta yet nahi tar printer kashala gandit ghalayla ghetlas
Posted on Mar 05, 2009
I'VE INCLUDED MY SYSTEM SETTINGS BELOW. I DON'T THING THE PRINTER IS THE PROBLEM, but then again....not all the lights in my belfry are lit. Conflicts sharing IRQ 10 Intel 82801AA SMBus Controller IRQ 10 AC'97 Driver for Intel(r) 82801AA Controller IRQ 10 ACPI IRQ Holder for PCI IRQ Steering IRQ 5 Realtek RTL8139(A)-based PCI Fast Ethernet Adapter IRQ 5 ACPI IRQ Holder for PCI IRQ Steering I/O Port 0x03F6-0x03F6 Intel 82801AA Bus Master IDE Controller I/O Port 0x03F6-0x03F6 Primary IDE controller (dual fifo) I/O Port 0x01F0-0x01F7 Intel 82801AA Bus Master IDE Controller I/O Port 0x01F0-0x01F7 Primary IDE controller (dual fifo) IRQ 11 Intel(r) 82810E Graphics Controller 4.12.01.2604 IRQ 11 ACPI IRQ Holder for PCI IRQ Steering I/O Port 0xFFA0-0xFFAF Intel 82801AA Bus Master IDE Controller I/O Port 0xFFA0-0xFFAF Primary IDE controller (dual fifo) IRQ 14 Intel 82801AA Bus Master IDE Controller IRQ 14 Primary IDE controller (dual fifo) IRQ 9 SCI IRQ used by ACPI bus IRQ 9 Intel(r) 82801AA USB Universal Host Controller IRQ 9 ACPI IRQ Holder for PCI IRQ Steering IRQ 15 Intel 82801AA Bus Master IDE Controller IRQ 15 Secondary IDE controller (dual fifo) I/O Port 0x0376-0x0376 Intel 82801AA Bus Master IDE Controller I/O Port 0x0376-0x0376 Secondary IDE controller (dual fifo) I/O Port 0x0170-0x0177 Intel 82801AA Bus Master IDE Controller I/O Port 0x0170-0x0177 Secondary IDE controller (dual fifo) DMA DMA 2 Standard Floppy Disk Controller OK DMA 3 ECP Printer Port (LPT1) OK DMA 4 Direct memory access controller OK I/O 0x0000-0x000F Direct memory access controller OK 0x0010-0x001F Motherboard resources OK 0x0020-0x0021 Programmable interrupt controller OK 0x0022-0x003F Motherboard resources OK 0x0040-0x0043 System timer OK 0x0044-0x005F Motherboard resources OK 0x0060-0x0060 Standard 101/102-Key or Microsoft Natural Keyboard OK 0x0061-0x0061 System speaker OK 0x0062-0x0063 Motherboard resources OK 0x0064-0x0064 Standard 101/102-Key or Microsoft Natural Keyboard OK 0x0065-0x006F Motherboard resources OK 0x0070-0x0071 System CMOS/real time clock OK 0x0072-0x007F Motherboard resources OK 0x0080-0x0080 Motherboard resources OK 0x0081-0x0083 Direct memory access controller OK 0x0084-0x0086 Motherboard resources OK 0x0087-0x0087 Direct memory access controller OK 0x0088-0x0088 Motherboard resources OK 0x0089-0x008B Direct memory access controller OK 0x008C-0x008E Motherboard resources OK 0x008F-0x008F Direct memory access controller OK 0x0090-0x009F Motherboard resources OK 0x00A0-0x00A1 Programmable interrupt controller OK 0x00A2-0x00BF Motherboard resources OK 0x00C0-0x00DF Direct memory access controller OK 0x00E0-0x00EF Motherboard resources OK 0x00F0-0x00FF Numeric data processor OK 0x0170-0x0177 Intel 82801AA Bus Master IDE Controller OK 0x0170-0x0177 Secondary IDE controller (dual fifo) OK 0x01F0-0x01F7 Intel 82801AA Bus Master IDE Controller OK 0x01F0-0x01F7 Primary IDE controller (dual fifo) OK 0x0376-0x0376 Intel 82801AA Bus Master IDE Controller OK 0x0376-0x0376 Secondary IDE controller (dual fifo) OK 0x0378-0x037F ECP Printer Port (LPT1) OK 0x03B0-0x03BB Intel(r) 82810E Graphics Controller 4.12.01.2604 OK 0x03C0-0x03DF Intel(r) 82810E Graphics Controller 4.12.01.2604 OK 0x03F0-0x03F5 Standard Floppy Disk Controller OK 0x03F6-0x03F6 Intel 82801AA Bus Master IDE Controller OK 0x03F6-0x03F6 Primary IDE controller (dual fifo) OK 0x03F7-0x03F7 Standard Floppy Disk Controller OK 0x0400-0x047F Motherboard resources OK 0x0480-0x04BF Motherboard resources OK 0x04D0-0x04D1 Motherboard resources OK 0x0778-0x077F ECP Printer Port (LPT1) OK 0x0940-0x0947 Motherboard resources OK 0x0CF8-0x0CFF PCI bus OK 0xD000-0xDFFF Intel 82801AA PCI Bridge OK 0xD800-0xD8FF Realtek RTL8139(A)-based PCI Fast Ethernet Adapter OK 0xE000-0xE00F Intel 82801AA SMBus Controller OK 0xE080-0xE0BF AC'97 Driver for Intel(r) 82801AA Controller OK 0xE400-0xE4FF AC'97 Driver for Intel(r) 82801AA Controller OK 0xE800-0xE8FF PCI Card OK 0xEC00-0xEC7F PCI Card OK 0xEF00-0xEF1F Intel(r) 82801AA USB Universal Host Controller OK 0xFFA0-0xFFAF Intel 82801AA Bus Master IDE Controller OK 0xFFA0-0xFFAF Primary IDE controller (dual fifo) OK 0xFFA8-0xFFAF Secondary IDE controller (dual fifo) OK MEMORY 0xF8000000-0xFBFFFFFF Intel(r) 82810E Graphics Controller 4.12.01.2604 OK 0xFFE80000-0xFFEFFFFF Intel(r) 82810E Graphics Controller 4.12.01.2604 OK 0xFFC00000-0xFFCFFFFF Intel 82801AA PCI Bridge OK 0xF6A00000-0xF6AFFFFF Intel 82801AA PCI Bridge OK 0xFFCFFC00-0xFFCFFCFF Realtek RTL8139(A)-based PCI Fast Ethernet Adapter OK 0xFEC00000-0xFEC00FFF Motherboard resources OK 0xFEE00000-0xFEE00FFF Motherboard resources OK 0xFFB80000-0xFFBFFFFF Intel(r) 82802 Firmware Hub Device OK 0xFFF80000-0xFFFFFFFF Intel(r) 82802 Firmware Hub Device OK 0x0000-0x9FFFF System board extension for ACPI BIOS OK 0xA0000-0xAFFFF Intel(r) 82810E Graphics Controller 4.12.01.2604 OK 0xB0000-0xBFFFF Intel(r) 82810E Graphics Controller 4.12.01.2604 OK 0xE0000-0xFFFFF System board extension for ACPI BIOS OK 0x100000-0xFEFFFFF System board extension for ACPI BIOS OK PORTS/PARALELL Name LPT1 IRQ Channel IRQ 7 DMA Channel DMA 3 I/O Port 0x0378-0x037F I/O Port 0x0778-0x077F Driver c:\windows\system\vmm32.vxd (, 1,019.88 KB (1,044,352 bytes), Not Available) PORTS/SERIAL Name COM1 Status UNKNOWN Name COM2 Status UNKNOWN Name COM3 Status UNKNOWN Name COM4 Status UNKNOWN COMPONENTS/PRINTERS (The default is set to the Canon Multipass) Canon Bubble-Jet BJ-10e Canon Bubble-Jet BJ-10e LPT1: Not Available Canon MultiPASS C3000 (Copy 2) Canon MultiPASS C3000 Printer LPT1: Not Available Canon MultiPASS C3000 (Copy 3) Canon MultiPASS C3000 Printer LPT1: Not Available Canon MultiPASS C3000 (Copy 4) Canon MultiPASS C3000 Printer LPT1: Not Available Canon MultiPASS C3000 Fax Canon MultiPASS C3000 Fax LPT2: Not Available Canon MultiPASS C3000 Printer Canon MultiPASS C3000 Printer LPT1: Not Available PROBLEM DEVICES PCI Card PCI\VEN_8086&DEV_2416&SUBSYS_0012107B&REV_02\BUS_00&DEV_1F&FUNC_06 28 COMPONENTS (AT THE TIME I PUT THIS TOGETHER, I HAD A FLASH DRIVE PLUGGED IN) Generic USB Hub USB\VID_0443&PID_002F\INST_0 Generic USB Hub USB\VID_0416&PID_5518\INST_0 HID-compliant consumer control device HID\VID_0443&PID_002E&MI_01&COL01\0000USB&VID_0443&PID_002E&MI_01&0001USB&VID_0443&PID_002E&INST_0 HID-compliant consumer control device HID\VID_0443&PID_002E&MI_01&COL03\0002USB&VID_0443&PID_002E&MI_01&0001USB&VID_0443&PID_002E&INST_0 HID-compliant keyboard HID\VID_0443&PID_002E&MI_00\0000USB&VID_0443&PID_002E&MI_00&0000USB&VID_0443&PID_002E&INST_0 HID-compliant mouse HID\VID_045E&PID_0009\0000USB&VID_045E&PID_0009&INST_0 HID-compliant system control device HID\VID_0443&PID_002E&MI_01&COL02\0001USB&VID_0443&PID_002E&MI_01&0001USB&VID_0443&PID_002E&INST_0 Intel(r) 82801AA USB Universal Host Controller PCI\VEN_8086&DEV_2412&SUBSYS_24128086&REV_02\BUS_00&DEV_1F&FUNC_02 Memorigh Flash Disk SCSI\MEMORIGHFLASH_DISK______2\USBSTOR&DISK&VEN_MEMORIGH&PROD_FLASH_DISK&REV_2.00&USB&VID_0204&PID_6025&INST_000 Microsoft USB IntelliMouse USB\VID_045E&PID_0009\INST_0 USB Composite Device USB\VID_0443&PID_002E\INST_0 USB Disk USBSTOR\DISK&VEN_MEMORIGH&PROD_FLASH_DISK&REV_2.00\USB&VID_0204&PID_6025&INST_0 USB Human Interface Device USB\VID_0443&PID_002E&MI_00\0000USB&VID_0443&PID_002E&INST_0 USB Human Interface Device USB\VID_0443&PID_002E&MI_01\0001USB&VID_0443&PID_002E&INST_0 USB Mass Storage Device USB\VID_0204&PID_6025\INST_0 USB Root Hub USB\ROOT_HUB\PCI&VEN_8086&DEV_2412&SUBSYS_24128086&REV_02&BUS_00&DEV_1F&FUNC_02
Posted on Jan 07, 2007
    President:
  • 2,961 Answers
Click on this link for your driver, about 8th one up from the bottom of the list http://www.printer-drivers.com/companies/191.htm?acd=3&rvd=5&thx=9&bng=7&o=4 As for the manual, iv'e had no success, but here's the canaon web site http://software.canon-europe.com/
Posted on Jan 03, 2007
  • 1 more comment
  • andrew pester
    andrew pester Jan 03, 2007
    After a furthur search click on this link for both manual and driver, although don't know if Win ME is there, if not try WIN 2000 drivers.
    http://www.usa.canon.com/consumer/contro...
  • andrew pester
    andrew pester Jan 05, 2007
    Don't use the wizard, disconnect printer, run the .exe driver installation and then re-connect printer when prompted or after installation has finished.
  • andrew pester
    andrew pester Jan 08, 2007
    did you install the drivers from canon usa, the third link down on my solution?
Driver Canon Multipass L60 For Xp
According to Canon the Multipass L60 is not compatible with Windows 2000 or XP.
The trick is using the Multipass 6000 driver for windows 2000. This printer is compatible with the MPL60. You need to edit the driver-inifiles (both copies of mpmaster.ini). as follows:
[Setup]
ModelName=MultiPASS L60
SGModelName=Canon MultiPASS L60
BaseName=MultiPASS
PrinterName=Canon MultiPASS L60 Printer
Version=3.01
NTonly=1
[DeviceID]
MFG=Canon
MDL=MultiPASS L60
Please rate me
Nov 19, 2010 | Canon MultiPASS L60 Laser Printer
We have lost our printer driver of canon multipass c70.
kindly downlaod the driver from this link just choose the operating system and start downloading.
http://software.canon-europe.com/products/0000558.asp
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 13, 2010 | Canon MultiPASS C70 All-In-One InkJet...
Need a Canon Multipass L6000 driver
There are drivers available here for limited operating systems (Windows Me, 2000, NT, and XP).
Feb 25, 2010 | Canon MultiPASS L6000 All-In-One Laser...
How to download free driver to Canon MultiPASS C70 Driver please tell me
here is the link for your driver from canon site
select the operating system you installed and download it.
let me know if it helpful to you
Dec 07, 2009 | Canon MultiPASS C70 All-In-One InkJet...
I changed catridge but still says "change cartridge".
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Canon MultiPASS C3000 All-In-One InkJet...
Driver?
ok my friend
here u can download the drivers from this website
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=7174#DownloadDetailAct
just click on the (Drivers & Downloads) button (to the middle right side).
select the operating system that u have (windows vista ,XP).
and start the download
install the drivers
enjoy printing
cheers
Sep 04, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Canon Multipass c20 driver for XP
MULTIPASS C20/C50 ON WINDOWS 2000/XP This device is not compatible with Windows 2000 and Windows XP as a multifunctional device. For this product, Canon advertises compatibility with the following operating systems: Windows 95, 98, Millennium Edition (Windows ME).
Printing functionality may be possible by following the steps below.
Step 1 – Install a compatible printer driver.
1. Start the ‘Add Printer Wizard’ from the Printers folder (Windows 2000) or the Printers and Faxes folder (Windows XP).
2. Ensure that the ‘Automatically detect my plug and play printer’ tick-box is not ticked. Press next.
3. When prompted, ensure the printer port is selected on to LPT1. Press Next
4. When the list of manufacturers and models is displayed, click on Canon, and then BJC4200. Press next until the installation is completed.
5. The printer driver should now be installed.
If you are using the BC22e photo cartridge, you will need to download the BJC4200 driver from the www.canon.com.au website.
Step 2 – Setting the Multipass machine to Printer Mode.
1. On the Multipass keypad, press Function, followed by 0.
2. Press the left arrow key until you see Dos Printing.
3. Press Start twice.
If you have successfully completed the above instructions, you may now find that you are able to print to the Multipass machine. To restore the Multipass back to its original mode, press Function, and then Printer Reset.
Feb 06, 2008 | Canon MultiPASS C20 InkJet Printer
Hook up
hi i am a certified Canon4.gif repair tech for this printer. if you follow the link below this will take you to Canons support site where you can download the software for your printer. hope this helps
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Nov 13, 2007 | Canon MultiPASS C3000 All-In-One InkJet...
Canon MultiPASS C3000 All-In-One InkJet Printer Logo
807 people viewed this question
old marine
old marine
