Question about IBM ThinkPad T30 2366 Notebook
Trouble resetting error code on my t-30,error code reads 0176
Tring to reset my IBM ThinkPad T30 2366 PC,ERROR CODE READS 0176 AT START UP?
  • mdurain Nov 27, 2008
    no i can not get to the bios to do this.
  • hofdog350 Mar 22, 2009
    i have the same problem only thing is the code is 0176 the system has benn tampered with and i cant enther the bois because when i try to it comes up with the message wat to i do?
    Sergeant:
  • 177 Answers
Error code 0176 concerned with System Security. The system has been tampered with.
Try to enter the bios setup. Save the bios setting and exit. Lets see if it resolves your problem
Posted on Nov 25, 2008
Error 0176 ibm
Lots of issues with 0176 error. Could be caused by a dead cmos battery or the system thinks it has been tampered with. I found a couple of clues for you;
The T41 Hardware Maintenance Manual gives the following instructions in case of error 0176:
"Run BIOS setup utility, and save the current settings by pressing F10."
To get into BIOS, you need to press the F1 key when you see the splash screen. I suppost that the splash screen on a T41 will display a ThinkPad or IBM logo, and something similar to "to interrupt normal start procedure, press the blue thinkvantage button".
The idea that a new motherboard might be necessary comes from the T41 Hardware Maintenance Manual. It says that in case the first instruction, i.e. get into BIOS and save current settings, doesn't fix the problem, a new motherboard should be installed.
You could try the following:
Disconnect the AC adapter from the notebook, disconnect all other cables. Remove the battery pack. Press the power button ten times in one-second intervals. Then press the power button again, and hold it pressed down for 30 seconds. Then install the battery pack again, connect the AC adapter. Press the power button.
Re: 0176 Security - The system has been tampered with
The padlock came up after removing the BIOS-battery. It is a security-feature and cannot be bypassed.
Removing the BIOS battery does not remove the supervisor-password but locks the system, if one hat been set to protect the computer from illegal use.
So either try to get the SVP from the previous owner ore replace the board.
Mar 20, 2014 | Lenovo ThinkPad R60 Notebook
0176 code error what can i do to fix the problem
What were you doing to get this error code? When does the error appear?
Apr 09, 2012 | IBM ThinkPad X30 2672 Notebook
0176, enter CMOS setting or BIOS setting we do this but error not removed
0176 System Security. The system has been tampered with.
  1. Run BIOS Setup Utility. Then save current setting by pressing F10.
  2. System board
Feb 10, 2012 | IBM ThinkPad T42 Laptop
Bios pass lock 0176 IBM THINKPAD R51 ERROR Experts
Okay friend so you are in front of real problem now, bypass of BIOS pass system is not impossible but really really hard.... In order to do this you must follow next really detailed instruction, check this link:
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Do it as follows, just give yourself time, and I wish you all luck you can get! Seyaa around! :) Alex
And please rate my solution :))
Apr 13, 2011 | Computers & Internet
Says sytem been tampered with code 0176
0176 error meaning the system cover had been opened. To fix this error, you need to enter CMOS setting or BIOS setting. press F10 to save before exit. Then the error will be gone.
Did you ever open the system cover before this error happened?
Sep 12, 2010 | IBM ThinkPad T30 2366 Notebook
THINKPAD R40 TYPE 2682
search the internet, most BIOS manufacturers leave a back door for problems like this.
Sep 18, 2009 | IBM ThinkPad R40 2722 Notebook
Error no 0176
Change the bios battery.Remove the notebook battery and then you should see the bios battery.Maybe you should have to disassembly the complete pc because it is a little dificult without disassembly.
Apr 13, 2009 | IBM ThinkPad R40 2722 Notebook
Problem with audio in ibm thinkpad t30,2366-y1b model
T30- no sound altho SOUND MAX drivers installed...
Try Control Panel, Sounds, Sounds (tab), choose a sound toward bottom of list. press the BLACK PLAY ARROW...if BLACK SQUARE appears at the arrow, your sound is installed $\& probably OK...
NOW,,,insert a musiv CD. then press the VOLUME BUTTON, (2nd one over from the THINKPAD button, & you should get sound aplenty !!
Dec 13, 2008 | IBM ThinkPad T30 2366 Notebook
IBM T21
i have the same problem. actually its a common problem for many T21 and other old IBM laptops.
i searched that you have to take all power (batery, adaptor)
press the power 10 times and press it for 30 secs then reinsert the battery or adaptor and try to power it on.
they say its done to discharge a certain capacitor that got overcharged after overcharging the battery.
that worked for me before but now my T21 wont start any more with this process.
May 20, 2007 | IBM ThinkPad T21 Notebook
IBM ThinkPad T30 2366 Notebook Logo
1,918 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
