Question about Ingersoll Air Tools & Compressors
Ingersoll rand model M75 over heating
I have a problem of heat generation in the compressor above i changed all service kits send to me from manufacture but still the problem exist, our technical team do some modification by shifting the air cooler instead of oil cooler the problem solved but i feel this is not the correct way to solve, please advise me to find solution
best regards
dabi
    Scholar:
  • 65 Answers
Hi, you may have already checked these, but just in case,
Over heating compressor:
Oil cooler is dirty
Clogged oil filter
Rotor blades sticking or broken
Insufficient oil in the unit
Defective thermostatic bypass valve
All compressor units generate a large amount of heat. In some instances the design of the unit=location and other possible variables may effect the ability of the unit to cool itself. A modification as long as it works, is safe, hasn't effected the performance of the unit, and hasn't voided the warranty, may be the best necessary solution.
Posted on Nov 25, 2008
  • Oil temp.goes more than 108
Posted on Mar 07, 2011
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Hi Guys, I have a Ingersoll Rand Compressor 7/41. Machine runs perfect but I have noticed that the Exhaust & Manifold is glowing red hot. I know they heat up but this is excessive heat. Any idea what...
The muffler may have a blockage in it? Is the exhaust inabdormally quiet? That's the culprit! Someone has stuffed something in the exhaust pipe exiting the compressor housing body!
Jan 16, 2015 | Ingersoll Rand Air Tools & Compressors
My 30 hp ingersoll rand screw compressor overheats even though I've changed the filters, Oil, cleaned the cooler
thats a very expensive compressor to be looking here or anywhere for answers as to why it's over heating... I would be contacting I.R. in a hurry and be ready to pay the service fee...
Dec 24, 2013 | Ingersoll Rand Air Tools & Compressors
I have a 500hp ingersoll rand compressor. I don't
Maybe you have residual coolant still in the lines from the leak you have already fixed and you just need to thoroughly blow them out? If the coolant is not just water maybe you need to rinse them out? Good luck!
Nov 29, 2012 | Air Tools & Compressors
I need a manual to rebuild a Type 30 Model 2475 ingersoll rand air compressor. Thanks
Dear Joe Bell,
This is Rodciel L. Camacho of VISMIN compressed air care center we are specialize in ingersoll rand air compressor.
You mean a overhauling kit?The part number of that is 34319469.
Hope i can help you..
May 07, 2012 | Ingersoll Rand - Rand Type - 30...
I have a Ingersoll Rand en6f75 compressor. Does it have to run in a particular direction as I cannot see any direction arrows on it.
We provide tech manuals for all of our products at www.irtechpubs.com. We also supply technical information on our website www.ingersollrandproducts.com. Hope this is helpful.
Ingersoll Rand Employee
May 13, 2011 | Ingersoll Rand - Rand Type - 30...
My air compressor a, 2 stage is over heating on the one cylinder that is the 2nd in line to the tank change the oil checked the filters and has good ventilation. One of the cylinder`s hotter than the other...
Sounds like the cooler cylinder has reed problems and is not working correctly. The heat is typical in a reciprocating compressor. Both heads or cylinders should produce the same amout of heat. Pull the head on the cooler cylinder and check the reed valves in the head.
Nov 15, 2009 | Ingersoll Rand 231C-KS - 1/2" Super Duty...
40 hp ingersoll rand rotary screw air compressor keep shutting
I have a ingersoll compreesor that keeps shuting down on high discharg air temp
Nov 12, 2008 | Ingersoll Rand Stationary Air Cooled...
Air Tools & Compressors Logo
353 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
