Question about BenQ DC1300 Digital Camera
Upload pictures to desktop
Hi,I'm using Windows XP professional service pack 2. I cant upload my images to the desktop. It does not give me any error messages. When i connect the camera to the USB cable the camera comes on as usual but no further activity takes place. I have tried re-installing the software and drivers but that did not work either. Please help me out. Thank you
  • 1 more comment
  • Aziz Harianawalla Jan 03, 2007
    No the camera always came on automatically.I did not have to do it manually.
    I already tried uninstalling all the softwares and drivers and reinstalling them.In fact it first gave me the problem after i had formatted my PC
    The camera does not come up as a storage disk.The memory chip cannot be removed either.
    It worked.Thanks. I just changed the USB port and it transferred immediately.
    Thanks alot!
  • rajesh2jsr Feb 08, 2008
    sir,
    I have bought Benq 1300 camera but flash light is not becoming ON even though camera is in flash light ON mode. Pls guide me.
    Regards
    Jamshedpur
    President:
  • 2,961 Answers
Do you have to switch the camera on manually?, as it may just be indicating that it is connected to pc. Try completely uninstalling the software and drivers. Disconnect camera and re install drivers, then try connecting to a different usb port. Check in my computer to see if the camera comes up as a storage disk.
Posted on Jan 03, 2007
  • andrew pester
    andrew pester Jan 03, 2007
    Do other usb peripherals work, have you installed updated usb 2 compatible drivers on your motherboard.
    Check that plug and play is working, go to Control panel> Administrative tools> Services, then look down list to plug and play(this should be set at automatic), then further down list look for Universal plug and play(this should be set at manual).
    If these are not the settings right click on them and set as above.
SOURCE:
Do I need special softwear to add my pictur to my profil on web site.
There is no need for sodtware to upload Picture to your profile on Web site. You can just click on Browse option and give the full path of the picture where it is located and simply clik on upload.
Mar 19, 2010 | Microsoft Windows XP Professional With...
Cd key of windows xp professional service pack 2
Get the product key from the back of your CD case, or on the back of your computer.
Mar 15, 2010 | Microsoft Windows XP Professional With...
Hi my desktop comp which has xp pro suffered a powercut whilst switched on and now will not boot up.when switched on i can press f8 and get safe mode screen but when i select any of the options the screen...
you are using windows XP Professional and some file are missing , so just repair your windows XP Professional with XP Bootable CD Service pack 2
Nov 01, 2008 | Computers & Internet
HELP ME
hi there my friend,
we have the hard way and then we have the easy way...
the hard way is to bootup with your bootable xp cd .follow the installation guide ..then.put in your key when you get the chance to ..and finish the installation. then apply service pack 2 to your installation .. and you're done...
the easy way would be to make a Slipstream Windows XP Service Pack 2 CD....which you can use each time you need to fix your system.
1 - Download the (full) "Network Install" of the Service Pack (English version [266 MB]), and save it to a directory (folder) on your hard drive (in my case D:\XP-SP2). Other languages can be downloaded from the Microsoft Download Web site.
Note: do not use spaces in the folder name!
2 - copy your Windows XP CD to your hard drive. Just create a folder (I used \XP-CD), and copy all the contents of your Windows XP CD in that folder.
3 - , open a Command Prompt (Start > Run > cmd), and go to the folder where you downloaded SP2 (cd \foldername). Type the command: servicepack filename /integrate:drive/path. In my example the command is WindowsXP-KB835935-SP2-ENU /integrate:D:\XP-CD.
Extract SP2 files
If you get the error:
This service pack can't be integrated error
This is caused by the fact that your Windows XP CD contains updates that will be automatically installed when you run setup. This type of CD's will usually be from larger OEM suppliers (like Dell, HP, or others).
You cannot use this type of CD to create a slipstreamed SP2 install.
First, the files will be extracted, and next they will be integrated in your Windows XP files:
Updating Windows Share
When ready, you should get a confirmation. Windows XP Service Pack 2 has now been Slipstreamed into your original Windows XP files.
Slipstream Completed
Creating a Bootable CD
For this part I used IsoBuster and Nero Burning ROM 6
After you install IsoBuster, you can choose to use only the product's free functionality for what we want to do, IsoBuster will look like the image below (you need to have your original Windows XP CD in the CD-ROM drive).
Start to extract the boot loader from the original Windows XP CD. Using IsoBuster, select the "folder" Bootable CD, and right-click Microsoft Corporation.img. From the menu choose Extract Microsoft Corporation.img, and extract it to the folder on your hard drive where you have your Windows XP files (D:\XP-CD in my case).
Extract Boot Image
Next, start Nero Burning ROM, and choose CD-ROM (Boot) in the New Compilation window. On the Boot tab, select Image file under Source of boot image data, and browse to the location of the Microsoft Corporation.img file. Also enable Expert Settings, choosing No Emulation, and changing the Number of loaded sectors to 4 (otherwise it won't boot!)
Nero Boot Settings
The ISO tab should be configured correctly as shown below:
Nero ISO Settings
If you have an older version of Nero you won't have the option Do Not Add ";1" ISO file version extention under Relax ISO Restrictions. You won't be able to boot your new CD, so update Nero!
You can configure the Label tab to your liking, I would however recommend that you keep the Volume Label the same as on your original Windows XP CD. Here are some (English) Labels:
* Windows XP Professional: WXPCCP_EN
* Windows XP Home: WXHCCP_EN
* Windows XP Professional OEM: WXPOEM_EN
* Windows XP Home OEM: WXHOEM_EN
Nero Label Settings
Next press New, and from the File Browser window, select the files and folders from your slipstreamed location (in my case D:\XP-CD). Now drag & drop the selected files in the ISO1 window.
Copy Files
Next, burn your new CD.
Burn
You now have a Bootable, Slipstreamed Windows XP Service Pack 2 CD!
Apr 28, 2008 | Computers & Internet
Windows xp 2002 sp4
Windows XP, the newest service pack for windows XP is SP3
Windows 2000, has SP1 SP2 SP3 SP4
There is no SP4 for XP.
If you need more asistance, let me know. Good luck.
Mar 31, 2008 | Microsoft Windows XP Professional With...
Hello
the black screen at windows startup implies that u have a probleme with ur software package(service pack 2)
so get a fresh copy of the softwares u have mentioned
then 1st install windows serice pack 2 from the bootable disk
after that when windows starts install ms office professional.
below is the link to download windows xp sp2 and ms office2007 professional(better u use opera 9.25 version or higher version for download)
For windows xp sp 2-
http://www.mininova.org/get/1178630
For ms office proffesional-
http://dl.torrentreactor.net/download.php?id=1406943&name=MS+Office+2007+Professional+Plus+%2B+Expression+Web
after downloading xp sp2 ,burn it on disc using nero and then install from cd
Feb 27, 2008 | Microsoft Office XP Professional + Service...
Temporary internet foder
http://www.microsoft.com/windowsxp/sp2/default.mspx
You can download microsft service pack 2 doe windows xp there click the link. Any more questions please ask.
Dec 24, 2007 | Computers & Internet
BenQ DC1300 Digital Camera Logo
Top BenQ Cameras Experts
Damen Wong
Damen Wong
Vincent_G
Vincent_G
Daniel Dollive
Daniel Dollive
Are you a BenQ Camera Expert? Answer questions, earn points and help others
