Question about HP Officejet J5780 All-In-One InkJet Printer
Can not print anything and looks like printer isn't listed
I had to unplug my printer for a few moments since I did a little rearranging of my desk. I plugged it back in and immediately started using my computer which I wanted to print something and nothing happened. A little box popped up stating "No HP Devices have been detected." Under Programs, I found HP, clicked it but my printer model did not show up. I put the disk in and tried to "add a new printer" (though it's the same printer I've been using all along), and I still can't print anything. It seems like I have to start all over which I've tried but to no avail. Can you please help me? Thank you so much!
Merlen.
  • mctb13 Nov 25, 2008
    I really would like free assistance. I am still looking for employment. When I click print, it says it's being sent to the printer. The printer is on but I don't hear any sound of printing. Please help. Just before I read your email to try your Premium Assistance Plan, it looked like I was successful in setting up a printer but when I tried doing a "test page" like it said to do, nothing happened.
    Sergeant:
  • 236 Answers
I would suggest unplugging the printer, uninstalling the printer drivers.
Reboot, reinstall the drivers and then plug in the printer.
Posted on Dec 05, 2008
All time: I have stalled print jobs, my printers is hp deskjet D2460. I've tried so many things , but nothing, please help me or send me a program that can fix my provblem without unplugging my PC.
first remove the power plug and the usb from the printer wait for few minutes and place them back first the power then the usb then press start setting printer and go to printer propertes in printer page you will see the printer drivers which are instaled make the prinriter you are using as defult if you see no printer drivers then install the software which came with the printerall the printer software should be installed then go to the taskbar you will see the printer icon click them to open then delete all the contents then click to close then go back to the printer page right click the defult printer and click tgeneral in general you will see print atest page click it
Jul 03, 2011 | HP Deskjet 2460 InkJet Printer
Whenever I try to print something it says "unable to print 36". Ive restarted the printer and tryed to print something and for a couple of minutes it says cleaning then a few minutes later it...
Remove the printer cartridge and check for any jams. If you don't see any large pieces of paper jammed in the printer, they may be smaller pieces so take care to notice anything small that shouldn't be there.
Place the cartridge back into the printer.
You may also want to unplug the power, wait a moment and plug it back in to clear the error and see if the issue corrects itself.
Mar 02, 2011 | Brother MFC 490cw Color Inkjet...
I have an HP printer. There is a full page photo that will not print. When I try to cancel the job is states deleting but does not delete. It deletes other added print jobs but not that one which is...
You have to clear out all documents one by one in the print que before you can delete the one causing the trouble. On the bottom right side of your pc screen, find the picture of the printer and right click with your mouse on it. Open your print que and right click on each document and choose "delete" until therer are none left in the print que. If this does not clear that last document, then unplug your usb cord that connects the printer to your pc and wait a few moments, and then plug it back in. This should clear it out.
Sep 08, 2010 | HP Officejet J4680 InkJet Printer
Paper jam light is on
Look real close. It is difficult to see very small pieces of paper that coudl be lodged in many areas. Also if you take a clean cloth with a little rubbing alchol and clean the sensors, this may help
Jun 17, 2010 | Dell 1710 Laser Printer
Moved HPOfficeJet550 across the room. The printer will not print
check data cables, if you did not change ports try a different cable. remember that printer cables should not be longer then 25 feet. network cable are different. no error messages on printer display?
Feb 18, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Desk top computer can't commucate with Z600 lexmark printer
someone told me it has to do with the print spooler have you looked in to that?
Dec 24, 2008 | Lexmark Z600 InkJet Printer
Error 5100 for canon mp530
I would do all of the following and see if yo can clear this code. It is not on any Canon list of possible codes, so I have no idea what it means., but let's do this:
Turn off the printer and unplug it.
Remove the print cartridges. Look at them, are they leak free? Look into the cartridge holders. Are they clean?. Dried ink or blobs should be cleaned off with a little alcohol and a qtip.
Are the little wire holders bent or broken? Do they look exactly the same?
Turn the printer back on reinstall the cartridges.Check in your printer preferences/services and clean your cartridges.
Now turn it off again and unplug it. Open the paper jam door and gently push the paper roller forward until it clicks. At the same time, look for even the tiniest scrap of anything in there.
Close the paper jam door and plug your printer back in. Restart your computer.
If the problem is not solved. You may need to reinstall the printer. Do You have your original disc? Be sure to do a clean install. ( Turn off all running programs in the lower right corner including your virus control. Also go to Toolbar>tools>internet options>general>and delete all you cookies and temporary internet files.) Turn off and unplug your printer.
Reinstall the software. When it is finished if it has not told you to plug your print back in do so now. Restart your computer and turn your printer on.
I hope this helps. Good luck to you.
Aug 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Same issue after power loss...
The wonderful Asante tech support people talked me through this fix (for free), just the other day.
This is for system 10.5.x:
1. Delete that printer from your list of printers in System Preferences.
2. Make sure your computer, printer, and Asante box are all hooked up together and turned on.
3. Click + under the list of printers in System Preferences.
4. Click AppleTalk icon in top row of dialogue box that appears.
5. After a moment, click Bluetooth icon instead.
6. After a moment, unplug the power cord from your Asante box (but not from the electrical outlet).
7. After a moment, re-plug the power cord into your Asante box and, as soon as possible after the "TX" light comes on, click the AppleTalk icon again.
8. Within a few moments, your printer's name should appear. Highlight its name, then make sure all the information about it that appears is correct, then click "Add."
9. Everything should communicate beautifully. I had no further problems.
Jun 25, 2008 | AsanteTalk - Ethernet to LocalTalk Adapter...
I am unable to cancel a waiting docment that i do not want to print
I shut my computer down unpluged the printer from the back of the computer then put it all back went to look on the computer to check that I had the right printer on the computer that is how I fixed it.
Feb 26, 2008 | Computers & Internet
HP Officejet J5780 All-In-One InkJet Printer Logo
Ben Johnson
