Question about Hotpoint 24 in. DWF32P Free-standing Dishwasher
Hotpoint Aquarius Dishwasher DWF31
My Hotpoint Aquarius Dishwasher DWF31 does not heat up and just continues to wash with cold water. The LED display that normaly shows the time now shows 2H which I think may be an error/problem code. Does anyone know what it means. Thanks Steve
  • Steve Fincham Jan 16, 2007
    Element had blown, but it is very difficult to get to and at £99 it is not worth fixing
MY DISHWASHER TASTES OF SALT AFTER EVERY WASH .I HAVE RINSED IT THREW AND IT STILL THE SAME
Posted on Jan 12, 2010
  • gary151158 Jul 21, 2011
    THERE IS NO SOLUTION HERE, AND AS I HAVE THE SAME PROBLEM I WOULD LOVE TO KNOW OF ANY FIX
Water in cycles is always cold
You need to check the heating element continuity using a multimeter. If there is continuity then check voltage at the time of the heating , if there is no voltage then the control panel is a suspect including the relay to the coil.
Dec 29, 2011 | Hotpoint Washing Machines
Hotpoint aquarius will not heat water
Although I do not know your particular machine I strongly suspect that the heater element is malfunctioning/broken. Even if it is a hot and cold fill it still requires the element to heat the water up to the correct temperature for the selected wash. If it is cold fill only it certainly needs the element all of the time- apart from rinses!
Sorry but it depends now on who you have at hand to repair as to your next step.
John C
Feb 09, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hot point aquarius 1100 - does this have a heating element for cold water feed ? or does is need direct hot water feed ? (there is a inlet at back for both hot and cold so presume no heating element ?)
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Dishwasher Hotpoint 7885 Aquarius Ultra Plus
sounds like the heater for sure. engineer job.
Jan 25, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius dwf30 dishwasher
you can plumb into hot but there are some snags
first hot water pressure is often a lot lower than cold so the machine may take a long time to fill
second if the water is too hot it will destroy the resin of the water softener and you will see brown marks on the crockery.
third it a bit uneconomical as you will use a lot of hot water
May 18, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint Aquarius DWF31
to isolate fault,remove bottom front panel,turn off main water,put a tray under machine, remove inlet pipe frompump at front of machine. for a second to see if you have flow that far. If so trouble is in machine. Dig the filter out of th pump entry .It could be blocked
Nov 04, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Long cycle times
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. About the led: If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Dec 30, 2005 | Bosch 24 in. SHU6802UC / SHU6806UC...
Hotpoint 24 in. DWF32P Free-standing Dishwasher Logo
1,665 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
