Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Prime bulb need replaceing - Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
  • 149 Answers
Buy a replacment primmer assy. One tube on the primmer is longer make a note where it goes...the one thats sucks (Inlet) goes to the carby return side.
Posted on Jan 15, 2009
How do I find the correct priming bulb and how do I replace the priming bulb?
priming bulbs are normally held in place by a ring around the base with 2 or three screws
remove that ring and the bulb comes out of the seat
take it to a mower shop as most bulbs are the same
if that is not the case ,take the carby to the mower shop and they will fit a new one for you
Oct 18, 2015 | Briggs & Stratton Electrical Supplies
Does not prime
Make sure that the priming bulb is not broken - if so replace. If bulb is good then the carb check valve is no good and the carb has to be replaced.
Jun 05, 2015 | Garden
My prime bulb looses pressure and first start is hard. I have to remove fuel line from filter and cover with thumb prime re install then first start takes time.
Does the engine run fine after it starts? Most common problem with primer bulb losing prime is an air leak in the fuel line or primer bulb. Air leaks don't always leak fuel. If there is an air leak between the primer bulb and gas tank there is no pressure, only vacuum. If it is not a major leak it might not leak without pressure but it will allow air to enter the fuel line. If it is a very minor air leak it could allow air to replace the liquid in the fuel line over time, but so little air once it is primer again that the fuel pump can over come it with volume of fuel.
Primer bulbs do not stay firm, as they are when initially pumped up, after the engine is running. There are check valves in the primer bulb that hold pressure in the primer bulb and throughout the fuel line to the engine. Once the engine starts the fuel pump creates vacuum drawing fuel into the engine diminishing this pressure and releasing the check valves. At this point the primer bulb is just another segment of fuel hose allowing fuel to pass through it as the fuel pump demands. The primer bulb functions much better when the outlet side is higher than the inlet side. This position makes it easier for the check valves in the primer bulb to seat and release as needed. If the primer bulb is functioning properly and is positioned with the outlet side higher than the inlet it should not be necessary to cover the end of the fuel hose with your thumb to get it to prime.
If the engine is hard to start after being fully primed there could be a problem with the fuel system on the engine. Some engines are hard to prime once air has entered the system, especially fuel injected models.
Dec 19, 2014 | Boating
Priming bulb failing to pull fuel from tank. Pumping bulb makes bubbles in tank. I can prime motor by pumping bulb when unit is tilted on the bulb side. Once put upright, it burns gas in bulb and dies....
hi there clubgy
sounds like you need to go through the carby and rekit it , make sure all the passages are clear and replace the welch plugs and check passages under them too and replace the purge prime valve assy that the primer bulb and flange connect to as you mentioned pick up and return lines are ok with no cracks or splits , make sure the tank breather is ok as well as the tank filter not blocked / restrictred thats about all i can think of
take a look and let me know
cheers pauly46
Sep 10, 2011 | Poulan 30cc 2cycle Backpack Blower
I bout a 22" push mover last year.The priming bulb on this has been torn and it is difficult to start it.It should not tear or get damaged so easily.Please help. Harjinder S Sabherwal
I agree the priming bulb should be more robust or somehow protected. You could replace the bulb, but soon have the same problem again. A simple work-around is to buy a can of spray instant-start (spray ether sold in auto parts stores). Spray this into the air filter each time you start the mower cold, thus avoiding the need to prime it.
Aug 27, 2010 | Mtd 22" Yard Machine Push Mower
Replace poulan 2150 chainsaw prime bulb
You can use this site to find a Poulan service center or order parts:
May 30, 2010 | Garden
Primer bulb won't prime
it sounds like the filter on the fule line is cloged try to remove the filter and then try to prime the trimmer. it it does you need to replace the filter. just about any filter that will fit will do.
Jun 05, 2009 | Troy Bilt Tb70ss Gas Trimmer
Problem with are 2001 everude boat motor model# 9.9eidevl 45ic
The fuel line priming bulb acts as a check valvue. The bulb is more than likley bad. Cheap to replace.
Apr 25, 2009 | Light Outboard Motor Boat Bass Fishing...
I have a Saeco Incanto RS Espresso Machine. The prime light is on, but the machine won't prime. Very little water of steam comes out of the wand.
You need to manually prime it using the priming bulb that came with it. Instructions are in the manual. Remove water tank. Fill priming bulb. Hold priming bulb on water inlet. They don't inter-connect, so just hold it on there as best you can. Turn the machine on, turn steam knob on, and gently, slowly squeeze the bulb to force water into the machine. It works best when the machine is cold, because you want to get liquid water in there, and not have it displaced by steam.
Jun 30, 2008 | Saeco Incanto Classic Espresso Machine
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
199 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
