Question about Kenmore 64952 Electric Dryer
Cant get front of dryer back on
The top has screws, its an old whirlpool, the bottom has some sort of clips and i cant figure how to get the bottom attached
    President:
  • Kenmore Master
  • 2,651 Answers
Yea fun! the clips hold the small holes cut into the door itself, it a real pain in the but sometimes ti get them on , youll need to try to hang one side the n work the other side, dont try to do both at once, a little patience they will fit together, im with you though why they cant find a better design!!! they still use them on the brand new dryers
Posted on Nov 25, 2008
Change belt
Take 2 screws out of the top where the filter goes in so the top can lift up. Slid the top forward to get to get the front of the top off the clips on the top of the front panel. If that don't work use a putty knife to push the clips back. Slide the putty knife in the crack to find the clips. Lift top up and secure it. Mark & remove the wires from the door switch . Remove 2 screws holding the cabinet to the front panel ,pull forward and lift on front panel to remove from bottom catches. Set front panel aside, remove old belt & replace. Grooves in belt go against drum.
May 10, 2014 | Whirlpool Dryers
Water inlet valve -how do i install it.
on the back of the washer are two spring clips fastened by hex head screws. remove the screws. Under the front of the top in each corner are spring clips. use a putty knife and locate the clips and press towards the back and lift that corner. it should come off. now do the same on the other corner. once the front is free, tilt the top up and pull up. the clips in back will release and you can rotate the top out of the way
Aug 30, 2007 | Maytag Neptune FAV6800AW Top Load Washer
The bar things inside the dryer drum (there are three of them) one has come almost all the way off. and one is loose. looks like its screwed from the other side.. cant figure out how to get inside. it...
Unplug the dryer. Open the door and remove a total of 4 screws, 2 on each side of the door opening. Two screws each hold a clip in place and the other two hold the dorr hinges. When you remove the screws on the door hinge, it shouldn't fall off, but be prepared for it to do just that. The door should come off by lifting the hinges upward and pulling the door away. The remaining part of the front panel is held on by 2 clips located toward the top sides of the u-shaped front panel. Pull the panel forward to release the clips and lift the panel upward to clear the two tabs and slots on the bottom. On each side of the cabinet, there is a blackish colored metal bracket that holds the top in place. Remove the fasteners that holds these brackets and remove the brackets by sliding them upward and away. The top should now lift up. You now have access to the fasteners that hold the baffles onto the drum. If , for some reason, you should want to remove the baffles, carefully note the different sizes of the baffles and what order they came off.
Here is the parts list for the drum of your dryer:
http://www.repairclinic.com/Maytag-Model-MDE3500AYW-ID-508609-Drum-Or-Tub-And-Related-Parts
Good luck from Detroit, MI.
Jul 18, 2011 | Maytag Dryers
I CANT FIGURE OUT HOW TO GET THE TOP OFF A DRYER AMANA MODEL LEA60. SEEMS LIKE SOME CLIPS ARE HOLDING IT AT THE FRONT OF THE DRYER ABOVE THE DOOR
you will need to pull the front panel off. there are screws on the inside of the dry door, may be two on the bottom corners, gently pry up on the top corners with a flat tip screwdriver, disconnect dry door switch. Place panel to the side and lift top up. Remember to unplug the dryer first. hope this helped tim
Sep 03, 2010 | Amana Dryers
Hi, i removed the front panel on my maytag a511...now i cant get it back on. I can't see how the top clips work.
the top clips are hanging type.. start with the top clips below there respective recesses in the units top, then tilt the bottom of the front out till it gets to about a 35-45degree angle and the clips should hook onto the top panel and then allow you to swing it shut and replace the 2 screws at the bottom..
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Whirlpool LSQ8000 Top Load Washer
I HAVE A OLD MAYTAG DRYER 25+YRS AND I CANT GET THE TOP TO POP OFF. ANY SUGESTION ON HOW TO GET IT APART?
If it is that old, look at the bottom of the front panel, about three inches off the floor for a phillips head screw on each side. Remove the screws, swing the front panel up a bit and unhook it from top and set to the side. Now, you can remove the screws holding the top onto the side panels and swing the top back.
Apr 20, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Dryer model # LDE313
at the bottom of the front panel you have two screws, remove those and swing out at bottom and drop off
Feb 06, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Dryer(WED5300SQ0)won't start
remove the lint filter, youll see 2 screws, remove the screws and with a small putty knife you cant pop the top using the clips approx 6inches in form both sides where the top meets the front panel, the top will then lift back giving you acess to replace the switch part number (3406107), very common incident
Jan 19, 2009 | Whirlpool WED5300S Electric Dryer
Leak
bad pump..take some news paper and slide in from bottom you will notice that the drip is coming from the left side more,,..if you can get behind unit theres 2 green clips on the right and the left remove these,,if you cant get behind remove front panel ..and remove from front...slide lid forward than remove lid switch connection right front corner,,now the tops off...remove the 2 screws holding washer front panel..now your in ,,to put back reverse...att'' always unplug unit first
Sep 30, 2008 | Whirlpool LTE5243D Top Load Stacked...
I have a Maytag Neptune dryer that has one of the agitators? that have come loose and am trying to figure out how to get to it to tighten it back up. It's an MDE5500AYW. Thanks
THE FRONT OF THE DRYER IS REMOVED BY OPENING THE DOOR AND REMOVING THE TWO SCREWS HOLDING THE HINGES TO THE FRONT PANEL. ALSO, REMOVE THE TWO SCREWS ON THE OPPOSITE SIDE OF THE OPENING. PULL THE FRONT PANEL TOWARD YOU AT THE TOP. IT WILL BE HINGED AT THE BOTTOM. ONCE YOU HAVE IT TILTED TOWARD YOU, PICK IT UP OFF THE BOTTOM HINGES.
THERE ARE TWO RETAINING CLIPS HOLDING THE TOP DOWN AT THE FRONT CORNERS. THESE CLIPS ARE HELD ON BY A 5/16TH HEX HEAD SCREW. REMOVE THE SCREW AND CLIP AND YOU CAN LIFT THE TOP. IT IS HINGED AT THE BACK AND YOU CAN RAISE IT UP AND BACK OUT OF THE WAY. YOUY NOW HAVE ACCESS TO THE OUTER SIDE OF THE DRUM. ROTATE EACH OF THE BAFFLES TO THE TOP AND TIGHTEN EACH SCREW AS THEY COME TO THE TOP.
Apr 22, 2008 | Dryers
Kenmore 64952 Electric Dryer Logo
43 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
