Question about Hand Tools
Ryobi 18 volt batteries wont hold a charge
My semi-new 18 volt ryobi batteries will no longer ''hold'' a charge. how can I recondition or ''bump'' them so that they will work again. most of my hand and power tools use this battery. thank you for you help, (in advance)
  • 4 more comments
  • somebuddy2b1 Nov 25, 2008
    P100 18 volt, the number on the bottom of the battery is: G0451. hope this helps!
    they are ni-cads.
  • aubdavis Jan 31, 2009
    dewalt 18 volt ni mh wont hold a charge.
  • jgarry1001 May 01, 2009
    i have the Ryobi 18 v battery Ni Cd model # 1322401, for 3 years, and have not used either of the batteries for a total of more then 1 hour, , now they will not charge, the yellow charge light and the GREEN full charge lights are both on?? right away?
    maybe i should totally run the battery down with drill etc, then recharge??????
  • yadayada
    yadayada May 11, 2010
    In order to give the right info to your question I need to know the type of battery, nickel cadmium, nickel metal, lithium ion, not model but chemical type of the battery, it will say on the battery.
  • yadayada
    These are what type of battery, nic-cad?
Ryobi batteries are specific to each Ryobi model, so please write down which model number or the original battery part number you have. How old are the batteries?
I had the same problem with many bateries I had at home, like cell-phone batteries and also some power tool bateries. Did not have any Ryobi power tools tho, so don't hold me acountable if this doesn't apply to your hardware:)
Many batteries have the "memory effect" which means that if the battery was not completely empty when it was set to recharge it might now only recharge to the level it was emptied to, so for instance if you used the power tool for 10 mins and the battery emptied to, lets say, 90% capacity, it might occure that the next time you recharge the battery it will only charge to it's 90% maximum...doing that many times lowers the maximum recharge capacity. As I heard the new Li-Ion batteries do not have this problem.
I hope this makes some sence as my english is not that good and it was a bit hard explaining my thoughts:)
Posted on Nov 25, 2008
    Top Expert:
  • Hand Tools Master
  • 78,010 Answers
Why does my Ryobi 18v drill not hold charge?
chances are that your batteries are shot. If you do some searching in your local city, see if there is company that will rebuild battery packs for your drill. The packs are around 1/2 to 2/3 the cost of a new pack and they will have better batteries in them. The manufacturer does not put the best grade of batteries in their equipment. So a rebuild is stronger and will last longer.
Feb 20, 2011 | Ryobi 18v 1/2" Cordless Drill - P204 - 18...
Just received recondition Ryobi 18 volt chain saw. Motor runs backwards.
electrical motor was wired in reverse, If you you attempt repair assuming product was purchased from store ,your sure not to get a fund or in-store credit.
Dec 07, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
How to fix an old RYOBI 18 volt battery won't
take a hammer, and apply force. These batteries dont last forever... but i am serious about the hammer... you may be able to free up whats inside (if you know how a batterey works.)... also apply heat.. try to hit it from all angles than slam it down on the back and leave it sit... than try. I hope this works for you my dewalt batteries over the years have don this, and it works.. but BTW. it wont hold a charge for very long anymore.. the battery is pretty much garbage.
Oct 13, 2009 | Drills
Ryobi battery chainsaw 10" - How do I tighten the chain?
loosen the two nuts that hold the chain cover on. Once they are just loose, then use a flat blade screw driver to turn the slot that you see right next to the base of the chain. Once the chain is tight, retighten the two nuts.
May 23, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
Ryobi 18v One+ battery won't hold a charge. I have two of them and neither one will hold the charge. The charger is the Ryobi 18v charger plus.
Does it not hold a charge, or will the charge not indicate "fast charge"? I had to apply a initial jump charge on the battery to get it up to 20 volts, then I put it in the Ryobi Charger, and it started charging it.
Mar 29, 2009 | Ryobi 15" Electric Factory Reconditioned...
18 volt batteries
Yes you can, as long as the batteries are the same style and fit the older Ryobi tools. The Ah rating is a capacity rating. The higher the Ah, the longer the battery will last so the 1.7Ah will just last a bit longer than the 1.5Ah batteries, but yes you can use them on older 18v Ryobi tools. I do it all the time.
Mar 01, 2009 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
12 volt re-chargeable battery won't hold charge
Yepp, you can replace it..BUT...its more expensiv to buy a new battery then it is to buy a new hand drill...almost.
If you want to replace it i sugest you go to the store where you bought your hand drill and buy one there.
Good luck to you
Feb 12, 2009 | Ryobi 15" Electric Factory Reconditioned...
Can a bad ryobi 18 drill ruin a new 18volt ryobi battery
If the drill has a short in it, then yes, it could short the battery out. Probably in the trigger switch.
Jan 24, 2009 | Ryobi Multi-Volt Battery Charger
Ryobi 18 volt battery wont charge
no its best just to replace them
Dec 27, 2008 | Hand Tools
Hand Tools Logo
5,220 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Bill Boyd
Dan Apthorp
Are you a Hand Tool Expert? Answer questions, earn points and help others
