Question about Logitech X-220 Computer Speakers
Im fixing my logitech x-220 speakers
And i need to solder the wire pins to the plug in, for the long wire connected to the 2 little speakers i was wondering if theres a schematic or diagram that can help me????
if so thanks it would save me alot of time and money
2 Suggested Answers
  • 27725 Answers
SOURCE: I need to solder the
hope this helps
Posted on Jun 09, 2011
Broken green pin on logitech x230 can this be replaced
if the green pin is what plugs into your computer, a traditional, headphone 1/8th inch headphone jack, it can be replaced, however there is some soldering involved. Radio shack sells the replaceable ends for just a couple dollars. the only problem is knowing which wires to connect to which points on the new end. i would have to see the wire with the insulation stripped off to be able to tell you which are which
Oct 18, 2012 | Logitech X-230 Computer Speakers
Logitech z3 wiring
I have a logitech z3 subwoofer with a mini-DIN-9 connector socket. It also has a volume control and 110V power cord. As best as i could trace the circuit, and using the TDA7377 stereo bridge amplifier chip datasheet, the pinout for the mini-DIN is as follows (untested):
1: L in (to vol.)
2: R in (to vol.)
3: Power (12V from transformer)
4: Standby (5V to play, 0.05mA; 0V to standby)
5: L out
6: R out
7: Ground
8: Ground
9: Ground
Connecting 3 to 4 with a large resistance (~20K ohms) should enable speaker. Pins 1 and 2 might be swapped; pins 5 and 8 might be swapped. Mini-DIN socket pin holes are numbered right to left, bottom row to top row:
9 8 7
6 5 4 3
2 1
Sep 03, 2012 | Logitech Z3 2 Speakers
My speakers aren't getting any power. I feel confident I have traced power all the way to the switch. Would anyone have a schematic diagram for Logitech x-240 speakers?
Hello little richi,
I would suggest plugging your speakers into another outlet first to be sure that your speakers are the problem. I would then suggest to check and see if you can remove the power cord, which I would assume is universal and can bought at many retailers, and install a new one.
If the switch was the problem, this situation becomes more technical. You most likely would have to buy a new plug. There are electronics retailers such as Jameco and Newark. We're not talking about places like Best Buy and Walmart here. Jameco and Newark sell plugs that you would have to solder on to the wire. The plugs should be real cheap. If you know how to solder, all you would need to do is solder the wires on to the plug.
Jul 20, 2011 | Logitech X-240 Computer Speakers
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
X-220 cable is slightly damaged and not making constant contact with sub-woofer mate. Is there a repair where I can replace or cut open & fix the 9 pin cable? To me, the obvious problem is that the...
nothing is wrong with the woofer the connect is broken at the strain relief and the cable needs to be replaced.
You can replace the connector if you know the pinouts. You will need the connector and the schematic.
you may be able to find the pin outs configuration here.
As for the connector this may take a search online.
Aug 07, 2010 | Logitech X-220 Computer Speakers
Logitech Pure-Fi Anywhere Portable Speakers for Apple iPod . It keeps shutting off after a few minutes. It's plugged into a wall outlet.
Many have reported the same issue, reset the pure-fi with the reset switch (on bottom) while it is turned on, then put your iphone/ipod at 75+ % of volume before/while playing.
Feb 21, 2009 | Logitech Pure-Fi Anywhere Portable...
Broken D-sub cable
I would advise against a direct solder inside the unit. I would go and purchase a replacement connector from a Radio Shack or other electronics parts store. Solder wires to this, then plug in, should fix problem.
Apr 03, 2008 | Logitech Z-2300 Computer Speakers
Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Jan 15, 2008 | Altec Lansing VS4121 2.1 Channel Powered...
Logitech X-220 Computer Speakers Logo
751 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
