Question about Compaq NC8000 Notebook
My note book will not powering up.
When i press the power button fans,blue tooth indicator,ac power indicator will on.those working for some few seconds only.after those things also power off.even itz not power up the DVD ROM even.please help.thanks
  • wp20 Nov 25, 2008
    I have exactly the same with the nc8000.
    Screen is black, LEDS on, fan on, after 10 s all off.
    It falls on the floor some days before, the problem after starting 10 times it comes to boot windows then all off and the same again. May this have to do with bios+battery fail?
  • HaoQ Dec 26, 2008
    the same problem
    Sergeant:
  • 177 Answers
Try to open the battery and connect your laptop to adaptor, then try to switch it on again. If nothing improves then there could be motherboard issue
Posted on Nov 25, 2008
My laptop won't turn on. What do I do?
A good place to start would be to take the battery out and disconnect the ac charger. Hold down the power button for 10 seconds. Replace the battery and/or ac charger, press the power button. Also see if your ac charger has a light on it to indicate power. Take note if anything lights on on the laptop and/or hear any fans spinning. That will help you jump to the next troubleshooting step.
Jul 28, 2014 | Dell LATITUDE Computers & Internet
Elite book 2640 blue light light on,yellow light flashing,screen blank
yellow light sounds like charge indication.If you press the power botton the fan should spin and you should be able to open the DVD by pressing the button on the tray.These are 1st steps to check motherboard function.If there is RAM installed remove battery after turning off power supply.Open memory door and reseat RAM.Replace cover then battery - power on.Any picture?Try an LCD monitor - no picture? Try different RAM or 1 stick at a time,remember to remove battery or RAM will be damaged.Still no picture - remove battery and try with AC adapter only.Still no picture - remove AC hold down power button for 30-sec plug in AC only and press power button.Still no picture - check CMOS battery if it uses a CR2032 button cell it may be flat.This can cause a no boot situation.If the CMOS has a plug or is soldered to the board that should be OK.The button cell may be hidden in the chassis anyway and to change it will require disassembly.So replace it when doing the cleaning.Still no picture - GPU is faulty.The unit should be disassembled and a reflow of GPU done,as well as cleaning all dust and fluff from the fan and other cooling system components.Airflow restriction of the cooling system is the cause of overheating and GPU issues.Google disassembly for your laptop and reflow method for GPU.If you have no experience with disassembly a step by step guide is crucial.Breaking parts is easy so extreme care is very important.
Apr 10, 2014 | HP EliteBook 6930p Notebook PC
Basically i plugged in the ac adapter to it, pressed the power button and the power light comes on for 2-3 seconds then the power light shuts off. lcd screen never turned on or show anything, fan never...
>>> Please leave feedback so I can continue helping You & Others
The middle blue led is the charging indicator, sounds like you have (at least) a bad battery, remove it, plug in AC and try again, if no good, remove the HD and repeat, if no good, remove/replace the ram and repeat, if still no good, your mainboard is cooked.
Thanks,
Adam.
Feb 19, 2011 | HP Pavilion DV9429US Notebook
MacBook Air 11" won't power
1. Verify AC power presence with MagSafe LED indicating on or charge state.
2. Verify battery as being partly charged, with orange/amber LED on MagSafe power connector.
3. Reset SMC
Resetting the System Management Controller (SMC) The System Management Controller (SMC) is a chip on the logic board that controls all power functions. If the computer is experiencing any power issue, such as not starting up, not displaying video, sleep issues, or fan noise issues, resetting SMC may resolve it. To reset SMC: 1. If computer is on, turn it off by choosing Shut Down from the Apple menu. 2. Connect power adapter to computer and to a working power source. 3. On built-in keyboard, press (left-side) Shift-Control-Option along with power button just once. Important: Use Shift-Control-Option keys on left side of keyboard. Note: When the LED on the MagSafe connector is orange/amber, resetting the SMC will change it to green for a few seconds, indicating that SMC was correctly reset. 4. Wait 5 seconds and press power button to start computer. Note: If bottom case is removed, you can alternately reset SMC by disconnecting both power adapter and main battery, and holding down power button for 5 seconds.
Power Adapter Issues 1. Connect AC adapter's MagSafe connector to the computer. The LED on the connector should be green or orange/amber. 2. Verify power cord or duckhead is firmly attached to AC adapter. Check that duckhead is not damaged. 3. Verify AC power source is supplying AC power. 4. Check for dirty or stuck pins on the MagSafe connectors, both on the adapter and the computer. 5. Reset SMC by pressing the (left) Shift-ControlOption(Alt) keys along with the power button once.
Jan 29, 2011 | Apple MacBook Air
How to pair Motorolla 550
Please allow me to help you with you Blue tooth head set.
Step 1
First power on the headset you do this by sliding the call button towards the microphone.
After a few moments, the indicator meaning the "light" will be steadily lit in blue to indicate the headset is good to go in pairing mode.
Step 2
1. On your phone press the menu button then locate connection or device "phones are diffrent" at this point you need to turn on the blue tooth on your phone.
2. The phone should find the Motorola H550
3. Select OK or YES to pair you headset with your phone.
4. Enter the pass key: 0000
5. Press ok
Hint: Once the phone is paired with the headset the indicator will flash blue.
Now if the unit does not pair then you might be using another unit with this phone so please make sure you disconnect all blue tooth units and try the steps again.
If you have any questions WE can help please get back with me.
Thanks for using Fixya.com "We have a solutions for everything"
I hope this solution was VERY HELPFUL!
Have a Great day
Oct 29, 2010 | Motorola Mobility H550 - Bluetooth Headset...
My Canon i250 printer suddenly began to print blue not yellow on a yelow hightlighted document. I have installed a fresh colour cartridge but the probelm remains. Please can you help.
1. Disconnect printer from AC power (take out AC cord or power off your power strip). Disconnect USB PC cable from printer.
2. Press and HOLD the POWER button (untill step 7).
3. Reconnect power cord (turn on power) to the printer.
4. The indicator should be green.
5. Press and release the RESUME button , the indicator should be orange.
6. Press and release the RESUME button again, the indicator should be green.
7. NOW Release POWER buttons.
8. NOW Connect the printer to PC (USB cable).
9. NOW...I opened "Printers" and saw that a "copy" of my printer (i250 or i350) had been made. Make that COPY your default printer and all should work...
Nov 18, 2009 | Canon i250 InkJet Printer
All I receive is a blinking power light when I press the power button. This occurs whether I have it plugged in or try starting with just the battery. I get know sounds from anything, fan, hard drive,...
Issue can be a mainboard lockup. Please perform full discharge/power cycle
- Unplug AC adapter and all other attachments (If any, such USB drive etc)
- Press and hold the power button about 7-10 seconds
- Put the AC adapter back and turn it on
If issue due to temporary circuit lockup unit will turn on
If issue persist please post more by indicated more symptoms, such as heat, pattern of the blinking light etc.
Good Luck
Jul 24, 2009 | Toshiba Satellite A15-S127 Notebook
I need instructions how to connect my h350 blue tooth to my lg cu400 cell phone
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Note: The blue light will flash as you press and hold the Call
button. Continue holding down the Call button until the blue
light is steadily lit.
Note: If you let go of the Call button before the blue light is
on and steady, ensure that your headset is off before trying
again.
The default PIN or passkey is 0000 (4 zeros)
You need to enable bluetooth on the phone and go into pairing mode, search for devices or similar
HIH
Jul 12, 2008 | Motorola Mobility Bluetooth Hands Free...
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Compaq NC8000 Notebook Logo
284 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
