Question about Mitsubishi WS-55411 55" Rear Projection Television
Mitsubishi WS-55411 part of a ''bubble'' at the top of screen
At the top of the screen there is a yellowish shadow of the lower halve of a "bubble"  that gives everything at the top of the screen a yellowish color.
 When the picture is paused, the outline of the lower half of this "bubble" can be seen.
1.  what is this2.  can it be cheaply fixed?3. how much should repair cost ( a range of cost...)
  • 153 Answers
I think it wouldn't cost too much because it needs only resoldering on the color circuit and no replacement of components needed.
Posted on Nov 25, 2008
Mitsubishi WS-5541 light blue glow
I know these sets pretty well--worked on a lot of them when new and later--one of two possible ideas=
1. Either a odd convergence problem==confirmed or denied by going into the convergence menu (in customer menu) and selecting advanced which will bring up a grid of lines--if see the same issue (I will attach a photo of a Mitsubishi with this problem) it can be fixed.
2. Some sort of issue with the circuit board on the end of the Blue tube(you are missing blue=black) but usually in this set if that happens it is uniform and on both sides of the screen, not the top.
Let me know what you find.
I doubt it is convergence, but does not hurt to look--if the missing area was perfectly rectangular I would suspect up/down centering adjustment.
There is one other possible thing to try--we will leave it for last--set has 3 hidden menus and one is OPTION menu which allows a hard reset of entire set--sets everything back to factory except convergence adjustments which are stored in another area.
Apr 06, 2012 | Mitsubishi WS-55411 55" Rear Projection...
How do I remove the front panel on my Mitsubishi 55411?
Heres the info after removing the screws the screen frame has to lift up slightly then it comes right off.10_29_2011_12_27_20_pm.jpg
Oct 29, 2011 | Mitsubishi WS-55411 55" Rear Projection...
Ws-55411 getting a code 22 short circuit were do i need to look for with this problem do you have idea ?
Check the pico fuses on the board. If one or more tests open, then likely the STK chips need to be replaced. This would mean a convergence failure.
Feb 19, 2011 | Mitsubishi WS-55411 55" Rear Projection...
I CAN GET PROPER COLOR ON MY WS-55411 MODEL
Try to describe better, is picture 3d looking or what is your problem?
Make a comment here OR IF YOU RE-POST THE QUESTION MARK IT "attention SD TECH" AND I will assist you.
I know the model indicated very well.
SD TECH
Sep 06, 2010 | Mitsubishi WS-55411 55" Rear Projection...
Hi I need a replacement bulb for my WS-55411 Mitsubishi. Can you help me find the right bulb and it's part number? The screen blacked out and sound still works so I assume I need a new bulb. When I shop...
Your model doesnt have a bulb since its a rear projection TV . It has three picture tubes, However loss of video with audio still working is usually caused by a vertical output failure.
Jul 28, 2010 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi WS-55411 55 in. Rear Projection Television
2 possibilities. Either your convergence IC's are going bad, or you need to remove the front panel of TV where the speaker grill is and you will find a small box with 6 control knobs on it. Mark each knob so you can set it back to its original position if you forget, the set might turn off if you adjust too high on either color, if so, set knob back in original position and turn tv back on and try again.The if it works reallign your convergence and that should do it.
Jan 28, 2009 | Mitsubishi WS-55411 55" Rear Projection...
4 pin or 6 pin
It has neither. It is not firewire capable.
Jul 17, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi 55 inch Rear Projection w/ Green tint
C.V.G ADJ AND SERVICE MODE ? GREEN C.V.G BAR ADJ POPARLY?
YES , SO POPARLY NOT SAVE 50HZ & 60HZ
NO, SO CVG I.C DEF, ITHER PRT LANCE LOOSE
Jun 13, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WS-55411 55 in. No Power up
Error code 12 means normal operation. On these models we have found that a switch is bad on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on set. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. You can use an ohm meter to find the bad switch.
Jul 04, 2007 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi WS-55411 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
