Question about RCA RS2640 CD Shelf System
Strange buzzing noise
I hadn't touched my stereo since the day before yesterday. I turn it on today, and to my surprise, I get a strange buzzing noise. I change source input on the reciever, to try and see if maybe I had accidentally changed that. I switch through all of them, and still get the strange buzzing noise. I noticed that when I unplug the speakers, it disappears. When I plug them back in, it comes back. I even tried unplugging the thing and plugging it back in. I also tried messing around with the Bass and Treble and that wasn't the problem. It can be heard at any volume, even in mute. When it is on mute, the sound comes in and then comes out exactly like how the light on the display of the reciever does that says "Mute". I stripped the wires of the speakers and reattached them to see if that would work and that didn't help either. Also... When I change dimmer options, the buzzing sounds slightly different on each of the 3 different options. So if you guys could help me out with this, I'd appreciate it.
    Scholar:
  • 72 Answers
Sounds like a bad filter cap in the power supply.when you change dimmer switch the buzz changes slightly because of a different power sraw on the power supply. If you are not versed in electronic repair. Get an Estimate. Or if unit is old get yourself a new one. Good Luck
Posted on Jan 03, 2007
    New Friend:
  • 3 Answers
I took mine apart and found what I BELIEVE is a bad cap in C805/C806. (It appears to have kind of exploded for some reason...it was in a very warm operating enviroment). There is another in C512, but I think that one is just showing the residual internals of the above caps. I just ordered a pair of the 50v/100uf caps....I hope this fixes it! Ireally like this little stereo!
Posted on Jun 04, 2013
SOURCE:
I have a Baumatic BDI631 integrated dishwasher which has started making a strange noise when the water is coming out. It is washing fine but makes a buzzing noise when discharging the water which soun
It sounds like something's trapped in the pump touching the impeller. Drain the machine, isolate the electrics and see if you can access the pump, you may find a piece of debris or small article in the pipework.
Jan 05, 2015 | Baumatic Dishwashers
I have a 2006 H3 and I just noticed red fluid leaking from the front end yesterday but today there is no leak. I did hear a strange hissing or whistling like sound when I accelerated. Is this somethin
Most likely one of the transmission cooling lines which go from the transmission to the side of one or the radiator expansion tanks has rusted through. It is making that noise because you are driving it with no transmission fluid in it. If you continue to drive it you will break the trasmission.
Mar 18, 2014 | 2006 Hummer H3
Philips TV making a strange clicking noise
A model number would be helpful to answer this but:
This clicking sounds (no pun) like either a mechanical relay in the set's power supply or possible arcing somewhere in the set.
These sets also have a shutdown feature that if engaged may sound like a tic-tic sound.
Let me know model number which is not indicated on this question here.
Jun 03, 2012 | Televison & Video
The machine is making strange noises when grinding
when first started up turn the steam valve open to get out air ... job done i hope or you need it repaired ... bsc appliances 07779933829 we repair via postal service anywere .
Jul 20, 2010 | DeLonghi EAM3400 Espresso Machine
A new hard disk drive, Hitachi part
Hello there DLBurkhart.
Here's your geek-steer ...
"...is emitting strange whining sounds every now and then ... Is this strange noise a sign of an impending problem?" == EVERY strange HDD noise is ALWAYS a sign of impending failure.
Peform a "Check Disk" on it ...
chkdsk DRIVE_LETTER /X /R
  • There should be NO surface errors if it's new(er).
  • Regardless, if it's new, then immediately insist upon a replacement.
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 13, 2009 | Hitachi Deskstar T7K250 HDT722525DLAT80...
The touch screen stopped responding. Worked well all day yesterday but this morning quit working.
Perform hard reset. Turn unit off. Press soft reset and turn unit on at same time
Jul 31, 2009 | Palm Z22 Handheld
Dryer won't start 7yr old dryer, was working fine yesterday, today was making strange buzzing noise while running, stopped it to check, and now won't turn back on.DEAD
Sounds like a defective motor starter contactor. DO NOT continue to try to use the dryer or you'll burn the motor out. The motor starter is built into the motor, but most are replaceable without replacing the entire motor.
Could also be the motor, but sounds like the motor is stuck in 'start' mode and never goes into 'run,' which would be the classic symptom of a stuck motor start contactor.
Jun 14, 2009 | Dryers
RCA RS2640 CD Shelf System Logo
439 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
