Question about LG L1915S 19" LCD Monitor
LG LCD monitor goes in power saving mode
LCD monitor is switched on and shows a green light but immediately it goes in power saving mode and throws a yellow light.
  • 153 Answers
That means theres no signal coming from the PC. either the PC is not booting up or the VGA coard is faulty.
Posted on Nov 25, 2008
Press fn + F5 buttons, screen will appear
Posted on Dec 21, 2008
  • Jeannette Bennett Jan 01, 2012
    this did not work fer me..
Stop my lg flatron w2053tq monitor going immediately into power saving mode
How old is your monitor? You may have some bad capacitors. At any rate, you'll have to take the monitor to a Technician for troubleshooting. Good luck.
Feb 28, 2015 | LG Flatron W2053TQ
Monitor automatically clicks into power saving mode
Laptops often have a function key which switches from laptop only, external monitor only, laptop & external. One of the top number keys, along with the function (fn for short) must be pressed simultaneously to step through these.
Where these keys are at, may differ from laptop to laptop.
Nov 28, 2007 | LG L1915S 19" LCD Monitor
My lcd screen switch goes green and a message appears "going to sleep" and the switch light goes yellow
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
May 10, 2014 | CTX S762A 17" LCD Monitor
Power saving mode
Power saving modes are automatic for some LCD monitors some have setting like after 20 ,30 mins to an hour the computer monitor itself will go into standy saving modes like power led switch indication go to yellow led lighting or the monitor of the lcd screen go blank if ur computer have no pictures for displaying as a screen saver modes.Power saving modes it best for uses if ur computer it on all day long.If u don't touch the mouse or a keyboard the monitor will go in the power saving modes for less electricities consumption for less stress for the monitor electronic components for working to hard for the monitor not to malfuctions sooner or the monitor life cut too short because the computer it on all day.
Oct 12, 2012 | Computers & Internet
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
Monitor goes black immediately after waking from sleep, at the same time the power light changes from green to yellow. Image is just visible on black screen when viewed with a torch, After a wait of about...
Common problem in this model is bad DC filter caps, that will be the first place to look.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 01, 2010 | HP Pavilion F1523 15" LCD Monitor
LCD Monitor will power in and when connects to modem the power button is green then turns orange, what is the problem?
When the monitor button turns to yellow that means the monitor is on standby mode. Try rebooting the the computer after you have connected it to your modem. If the light goes to yellow again check that the computer is on and that all the cables are connected properly. HP Computer monitors are a little confusing, Sometimes depressing the power button again while it is yellow will turn it on and should so green.
Jul 21, 2010 | HP Vs17 17" LCD Flat Panel Monitor
New LG 2452T keeps going to digital power saving mode
i had the same problem.
connect the monitor with the analog cable and shut down your pc.
while it is off unplag the analog cable and place the digital one(dvi).
this should fix your problem m8 ;)
Feb 28, 2009 | LG Flatron L2320A 23" LCD Monitor
LG L1915S 19" LCD Monitor Logo
1,088 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
