Question about Optoma H30 Multimedia Projector
Everything/everyone is purple on a H31 optoma pic
I turned on my unit this morning and everything is purple. I changed my cable, and no help. I looked inside, and can see green light and blue light , but no red light. I shook the unit gently and do not hear any noise. I even tried adjusting the color, and no help. I do not have a troubleshooting manual on the unit. So, if you can suggest some tips on this problem, I would sincerely appreciate it. Thank-you, Eugene
  • lgcelio Dec 22, 2008
    I also started today with this problem, I turn the projector off and on again and it's normal for some time, but after 10-15 minutes the purple comes back. If I find anything I'll repost. Good luck
    New Friend:
  • 3 Answers
My Optoma EP739 started exhibiting color-banding and strong color shift after years of great service. After trying other suggestions that didn't work, here is the FIX for my unit. I have not seen this posted anywhere else.
Problem: After 10-20 minutes of use, color-banding and then a strong shift to purple/green with almost no red. If the unit is turned off for 5-10 minutes to cool and then powered-up again the problem goes away, only to come back in another 10-20 minutes. Enabling the "High Altitude" setting in the Setup Menu helped for a while (a week or two) since it forces the main cooling fan run at high speed always, but then the problem re-appeared.
Reason: Overheating. The electronics are overheating. Like several people have suggested: First step: Open the unit up and blow-out/vacuum all of the accumulated dust. Assure BOTH fans (there is a small drum blower directly cooling the lamp and a larger regular fan that circulates air through the entire unit) are operating and clear of debris.
Once you have done that, then look for the REAL issue. With the front panel (i.e.the panel with the hole for the lens) removed and looking into the projector from the front examine the metal heat shield on the right side above the lamp. In my unit, because of years of service and heat, the aluminum lamp housing had deformed slightly, tilting this sheet metal heat shield directly INTO the air stream from the fan. This restricts the airflow enough to reduce cooling capacity. This metal shield should be high enough above the lamp to be TOUCHING the plastic case. If it is bent down and is halfway into the air stream then it restricting the exhaust airflow, causing the overheating.
Fix: Bend the heat shield back up so that it is not in the exhaust airflow. It must be ABOVE the airflow, protecting the plastic case from the heat of the lamp. This simple remedy fixed the issue for me. My projector has been running 2-3 hours a day for 10 days now with no banding issues at all. That's it. Simple fix.
Posted on Feb 10, 2013
  • 3 Answers
Hi, genelewis! Well good news for me, and also hope for you; I got my projector to work correctly again, at least it has not had the problem for a couple of days of probably 10 to 12 hrs use of movie watching, before it could not go an 1hr without the purple issue.
I was looking at other sites and this one with other projectors and it sounded like just dust in the projector... after just about 3 years now without a cleaning I think it needed some maintenance, so I carefully took the bulb out (1 black screw on the bottom) and opened the projector (7 metal screws in total), and after some investigating on any wiring that may interfere (only on the inside back of the white top cover, were the inputs are: a wire band and some small metal sheets that kind of grab the top) I pop the top, not that hard.
After that I just carefully used a can of compressed air to blow away from the projector any dust I could reach and in some of the crevices I saw, being careful were the mirror is (were the bulb was); I was tempted to get the glass that covers it off to get some dust off but the screws are small and kind of hard to get out, so I left that alone. Cleaned any dust accumulated on the air intakes with a clean soft cloth and closed it up again. I did not want to touch anything else unless this did not work, but this did the trick! I'm happy with my H31 once more.
I hope this helps you, good luck. Let me know if you need some more details
Posted on Dec 28, 2008
  • lgcelio Jan 16, 2009
    Bad news, after a week or so, the problem came back. But I found something else, if you change it to the bright mode on the color comes back. So there is something going on inside...since I don't thin I'm brave enough to open that much up, I'll keep it in bright mode until I get the guts or just send it out for repair.
Optoma h31 stopped suddenly. I replaced the bulb, but the power button isnt flashing green, and I cant turn the unit on.
The little metal plate on the projector next to the bulb housing is not fully depressed (pressed down). The plastic cover is suppose to have a plastic piece protruding from it which is to depressed the metal plate when the cover is placed back on. If the metal piece is not pressed down, the projector will not light.
Feb 10, 2011 | Optoma H31 HOME THEATER PROJECTOR...
No picture
Hi, Possibly either of 2 reasons: 1. Your player is not sending any signal to the Optima meaning it is the one in question and not the projector; or 2. Your Optima lost its input signal, go through the signal source selection menu, try manual selection & set it to where your source/player is connected. Hope this works out for you, if not pls post again . Good luck and kind regards.
Aug 03, 2007 | Optoma H31 Multimedia Projector
I just put a new bulb in my Optoma H31, but still get Lamp Fail
have you check that the bulb you installed is the right bulb for your unit?
have you check by replacing your bulb it correct position?try to unplug the power cord and lug it again and turn on.
Oct 09, 2009 | Canon RS-LP02 Projector Lamp for LV-X6
Optoma h31 was unable to power up
It can have two problems. One is that the lamp has gone out and needs replaced. Refer to your troubleshooting section in your manual. Also can be bad capacitors in the power supply circuitry or Voltage Reg. IC. Either should be left to competent repair individual.
Jun 24, 2009 | Optoma H31 Multimedia Projector
Optoma H31 - Turns itself off !
sounds like the projector lamp to me. the rated hours are always up to the published hours and never "this is what you will achieve." I would suggest getting a lamp as you will need one shortly by the sounds of it. In many cases the projector does this as it is programmed to protect itself from the lamp shattering inside the projector. Let me know if you would like a quotation for a lamp as we ship internationally. Regards Kevin Andreassend. http://www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
Mar 28, 2009 | Optoma H31 HOME THEATER PROJECTOR...
Can I buy and replace a clourwheel unit for my optoma H31 myself??
There is no "color wheel" in these units. These projectors use a series of LCD panels and filters to create the picture as far as I know. That optical unit will not be cheap. WHat is the rpoblem with the unit that leads you to believe this needs to be replaced?
Dan
Sep 10, 2008 | Optoma H30 Multimedia Projector
I have the optoma h31 projector and the color turned purple. We assumed it was the bulb and put a new one in. The color is now still not right and the picture sorta bounces
I had a similar issue with my EP739, the problem would start after about 3 or 4 minutes and then get gradually worse and worse..
The most strange thing I noticed was that white looked fine. And if you opened the configuration menu in the projector it appeared that blue was labeled green and green blue..
Some sites suggested cleaning the machine of dust, which I tried using a can of compressed air... This did not fix the problem at first.. but when I had it apart I studied the colour wheel for a little while and wondered if some how the machine was synching to it incorrectly somehow.. So I blew out the colour wheel location sensor (It's kind of obvious being the only component mechanically connected to the color wheel. Much to my delight, this fixed the problem...
So my solution to the flickering / colour fading / colour swapping issue with DLP projectors was to clean out the dust from the colour wheel location sensor..
In fact, if I did it again, I would ONLY clean the sensor, and leave the rest of the dust alone. Blowing dust around has the potential to cause other issues, especially if it winds up inside the optics system.
- Nate
Apr 27, 2008 | Optoma H30 Multimedia Projector
No HDMI video signal to projector
cheak out put on samsung to set it at 720 hdmi out ect might nee dto use red green blue or s video to see menu
Feb 05, 2008 | Samsung DVD-VR357
Optoma H30 Multimedia Projector Logo
518 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
