Question about Canon i 450 InkJet Printer
Spring w/2 tiny rollers loose
Top L-shaped roller track popped out along with 1 tiny spring & 2 tiny rollers. My problem is this. On the bottom of the top L-shaped roller track (assuming that's probably not the proper part name but we will assume it is here) there lies 16 slots,(2 rows of 8) each slot holds 1 tiny spring & 2 tiny rollers that look like tiny, white, plastic wheels with tiny metal teeth encircling them. Out of 16 slots it seems that 12 of them are to be occupied & 4 of them are to be vacant. Now, with the printer in front view, If you were to look down at the the L-shaped track lying correctly in place, this is what I know, starting from the front (row farthest away from you)left (left hand side) row the numbers 1, 2, 3, 5, 6, 7, & 8 slots are occupied and the number 4 slot is vacant. On the back row again, starting on the left side numbers 2, 5, 7, & 8 are occupied & numbers 1, 3, 4, & 6 are vacant. So, since 12 of the slots seem to need to be occupied and I only have 11 currently occupied, which of my vacant spots is supposed to be occupied? I think It's the front number 4 slot. I just want to know if thats right & if not which slot is correct. I don't want to take it to a shop for something so simple as this. Please help me out. Thank you! Austin
On my i455 all the rear slots are occupied. The front only has 2,5,7, 8 occupied. It works fine that way. I think the rear is more critical than the front to proper paper feeding. Good luck
Posted on Oct 04, 2007
Xerox 6180mfp repeating pattern
They are caused by a component in the toner cartridge.
Originally the cleaning roller was a plain roller, but at some time the 'bean counters' decided they could save a tiny bit of money on each cartridge by using a spiral foam roller instead. The foam also seems to be of a different type, and doesn't age well.
There are two solutions.
1. Replace the cartridge that is producing the coloured squiggle/
2, dismantle an OLD cartridge and if it has a plain (non-spiral) foam roller, swap that (along with it's supports - the new type are a different size).
Either of the above will cure the problem, but a new replacement cartridge may also show the problem in time, as it WILL have the spiral cleaning roller.
Nov 15, 2012 | Xerox Phaser 6180N Laser Printer
How do you change the belt
The front roller (usually a metal cylinder) is spring loaded. The rear roller (usually a rubber cylinder) is fixed and is driven by a belt from the motor. You need to push the front roller against a fixed object (like a benchtop) pretty hard to compress the spring about 1/2 inch. It should "catch" in the compressed position. Belt will now be loose and easy to reeplace. Then, to "un-catch" it, on most models, just stick a screwdriver behind the front roller bracket and pry it forward. It should pop right back into place. Good luck.
Oct 13, 2012 | Black & Decker BR300 3''x18'' Belt Sander
I have an HP 8500 premier with 2 paper trays. When I try to print from tray 2, the paper feed rollers don't touch the paper. I can pull the rollers down, but they spring right back up. on tray 1 the...
it touches the tray according to he size needed so if u want in the second tray can keep the size greater then a4 and chnage the settings so it takes from the second tray .................
Oct 27, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Clothes catching inside at top of drum
IT sounds like you have a roller that is broken or the drum is off track...when a roller breaks or the support bracket that the roller is attached to has a screw loose and has shifted position and I surmise based on your description that the front left roller is affected or the drum is off track up toward the front of the dryer...that would make the front of the drum drop creating the situation you described. The only way to get to this problem depending on the brand...is to remove the top of the dryer...or the back of the dryer...and remove the drum...to access the rollers.....be careful to observe closely how the belt is attached to the spring loaded arm (tensioner) that keeps the belt tight...and replace it the way it came out. Any problems get back to me and I can walk anyone with good mechanical skills through exactly what to do.
Hope this helps....please rate me...the Fang
Mar 25, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
1991 Toyato Previa sliding passenger door
there are three (3) rollers
1 at the bottom
1 on the body
1 at the top this is the one giving you problems you will find that the roller is missing and or broken you can pick one up at the wreckers
Dec 01, 2008 | 1991 Toyota Previa
Vertical dots on print output
1 1/2 inches apart would correspond to the diameter of the primary charge roller. You have one chrarge roller inside each toner cartridge so you need to determine which color the dots are and then replace that cartridge.
Oct 22, 2008 | HP LaserJet 4600dn Color Printer
LG DIshwasher
hi Problems with the dish racks usually occur because the racks have been jammed back into the tub housing after they're fully loaded. Careless handling can exert enough force to crack or break the roller wheels or throw the racks off the tracks. The solution is easy: Stop jamming the racks.
The repair is easy, too. Remove the racks by pulling out the tiny metal pins that hold them in the tracks. Or simply lift up on the racks and pull them out of the tracks. Then reinstall the racks on the tracks so that they roll smoothly. If the rollers are cracked or broken, replace them with new ones of the same type. The rollers may be friction-fit to their hubs. Pull them off for replacement. Or, if they are held by tiny spring clips, pull the clips out with pliers, or pry them out with the tip of a screwdriver. If you can't pull the rollers off for replacement, remove and replace the entire rack.
Sep 12, 2008 | LG Dishwashers
The bottom rack of the dishwasher is always coming off the "track" or what passes for one. The wheels seem too small or the rack isn't wide enough Makes it very diificult to push in or pull out.
A noisy wash cycle or water that won't drain are problems that, for the most part, can be handled yourself. We'll discuss how you can pinpoint these water-related problems in the next section.
tha...........
Clothes get caught between drum at front of dryer
the drum has either worn out its felt(front), a fabric bearing, or the roller(rear) bearings, or both, and dropped enough to make a gap. new rollers are3 about $15 /pair, felts between $13 & $90 depending on model.
Generic replacement is simple, and really while you got it apart, do both, the strain of twisting off axis will make the remaining good end fail shortly
The generic steps may not be correct for the actual dryer model.
Felt seal
for most dryers,
Go buy HiTemperature silicone adhesive (tube)
tools required couple pairs locking pliers/visegrips screwdrivers
Unplug dryer
remove the front cover, either
  • couple screws at the bottom and spring clips to pop off with a screw driver OR
  • couple of spring clips to hold the top lid on, then screws top and bottom of both sides
    examine the case to find the exact mounting
unclip cables from door switch
set front panel aside
unhook drive belt from tensioner pulley
pull drum forward and out
remove old felt
scrape off old adhesive
put adhesive per instructions (some 2 surfaces some 1) on drum/felt
clip felt in place on drum with visegrip at 1 point
stretch felt around drum, gluing and clipping in place with vicegrips as you go
allow glue to set
reassemble in reverse order
Roller bearings
for most dryers,
tools required needle pliers/visegrips screwdrivers
Unplug dryer
remove old rollers:
  • pry triangular circlip from axle post
  • discard circlip
  • remove and discard roller
  • install new roller
  • install new circlip
    ALWAYS replace rollers in pairs
wow took longer to type than it actually takes to do it
Jul 22, 2008 | GE Dryers
Canon i 450 InkJet Printer Logo
old marine
old marine
