Question about Solis Palazzo Espresso Machine
Solis Palazzo Steam problem
I had it fixed about a year ago, have been using it for about three months. Same problem as before - steam stops and water light flashes telling me to ventilate. I ventilate but the steam still runs out about 30 seconds after starting. There is plenty of water in the resevoir. I have a feeling it is some sort of valve or regulator, but I haven't a clue about the innards of this thing. No one in San Diego can work on it, and it costs a small fortune to ship it to the northwest.
  • marius_b_han Apr 02, 2009
    i have problems, can someone help me? please
  • Anonymous May 18, 2009
    Were you able to find a local repair company?
  • 1,089 Answers
Hi
Sounds like your flow meter is restricted with the usual chip of bean. The flow meter spins when the pump is moving water. There is a small opening in the intake side of the flow meter and this creates a jet of water that spins the flow meter. When the flow meter is spinning the machine is happy, but when the intake gets restricted the water doesn't spin the flow meter and the machine says ventilate. It wants the flow meter to spin and be happy. You could possibly fix it your self if your handy, other wise let the pros do it.
Posted on May 24, 2009
Super automatic espresso machine leaks water into drip tray and onto counter when I use the frother
The stream valve is leaking and probably needs to be replaced. If you remove the top cover it is visible.
Sep 12, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
Manual
Hold the coffee button down from the moment it is pressed till the water in the cup reaches the desired volume, then release. It will now save that volume amount to memory.
Jun 13, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
Container leaking water
Ther is tank seal that is at the base of the machine where the tank goes on . it will dry up , waer out and leak overtime.
Apr 20, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
Solis palazzo not producing coffee
I think the blockage might be at the brew unit, remove unit and check the screen under the red o-ring, connected to that is the chute that leads to the espresso spout. That tube might be blocked, there are 2 screws holding that piece together, be careful when you remove them do not lose the spring and ball in the fitting. Clean tube and reassemble.
May 24, 2012 | Solis Palazzo Rapid Steam Palazzo Fully...
While coffee is moming out,water is coming out as well underneath the machine and the steamer Steamer doesnt work. While trying to use the steamer, i noticed that steam is eveyrwhere. How can i fix this...
http://www.juraprofi.de/Solis-Ersatzteile/Dichtungen-O-Ringe/Solis-Dichtung-fuer-die-X100-Bruehgruppe::9015.html
Try this piston seal, it should fix it?
Jan 22, 2011 | Solis Palazzo Espresso Machine
Solis Palazzo steam valve knob spins and will not close valve all the way. Knob seems to be stripped.
There is a pin on the valve the knob fits in. The pin might be broken. You probably just need a new valve.
Sep 23, 2010 | Solis Palazzo Espresso Machine
Steam valve is starting to leak when closed. Does the valve use O-rings that can be replaced?
Yes it does, but it might be easier to replace the complete valve, than the pins and the o-rings.
Dec 01, 2009 | Solis Palazzo Espresso Machine
Does not warm up
HI
If you don't have any other lights on, it could be 1 of 2 things. Your boiler is bad or your power board is bad. Can you get steam or hot water?
Oct 25, 2009 | Solis Palazzo Espresso Machine
Steam/water valve leaks water, only fills coffee to 50%, help? I have completely removed steam valve assembly to clean and reassemble. Leak persists, suspect o-rings?
Hi
If your water valve is cream or black colored, you need a new manifold. They will get hair line cracks if you steam, but don't cool them down after steaming by running cold water through them. If you have one of the new brass(silver) manifolds it could be your O-rings but i doubt it.
Oct 07, 2009 | Solis Palazzo Espresso Machine
Solis Palazzo Espresso Machine Logo
189 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
